メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Kenmore Elite HE3は、Kenmore社製の洗濯機です。Whirlpool Duetと同一の製品です。
meaning of OE code
getting OE code and does not drain/spin
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
@ronhurley the error code "OE" is a "Drain error " and it is initiated by your washer not having fully drained in 10 minutes. Most common cause is a clogged filter. Check your "coin trap" filter for retained objects, like missing socks etc.:-)
To clean it
1. Take off the lower front panel
2. Turn the pump filter cover counter-clockwise by hand and remove. Place a bucket or pan underneath it since you will get water spilling out of there.
3. With a set of long pliers, remove the filter. Clean that of any debris etc. and replace it when cleaned.
4. Replace the filter cover and lower panel.
The other thing that could be going on here, is that the drain pump is not working and needing to be replaced. The service manual will have instructions on how to do that. There is also a decent video on here.
There will be plenty of water. So please make sure that you have lots of buckets and towels etc. to catch the water. It will be a stinky, dirty flood
You can download the service manual from from here.
画像
画像
画像
このアンサーは役に立ちましたか?
スコア 6
10 件のコメント:
Have cleaned outf ilter blow hose clean still same fault
さんによる
I followed this and didn’t fix anything. I am guessing the pump is clogged or not running at all...good luck
さんによる
Worked for me , I just hope it stays working! Thanks
さんによる
I had to replace the drain pump, 20 something bucks on Amazon. Not to hard but can be challenging for some. Fixed the problem.
さんによる
Thank you so much. This did the trick!
さんによる
5件以上のコメントを表示
コメントを追加
回答を追加する
rhurley52 さん、ありがとうございました!
統計データ:
過去 24時間: 16
過去 7 日: 62
過去 30 日: 282
今までの合計 122,499
