メインコンテンツにスキップ
Model A1418 / Mid 2014 / 1.4, 2.7 & 2.9 GHz Core i5 もしくは3.1 GHz Core i7 プロセッサ
50回答 すべてを表示
SSD slot on logicboard or not
So on the 2013 model there is an SSD (blade) slot on the logic board even if you ordered the iMac without ssd or fusion.
is that also the case with this 2014 model? can anyone confirm?
pictures on the iFixit manual says its not, but then again this model does not have a teardown to dubble check.
could anyone confirm what the status of the SSD blade socket is on the logicboard?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント
Ok, thanks...
this is the answer i was looking for...
さんによる
No guys! It is not! I bought iMac 21.5 Mid 2014, i5 1.4Ghz, intel hd 5000, 500gb hdd, and I can confirm there is no Pcie slot! I do not know how to check logic board model on terminal, maybe there is some with slot?
さんによる
juliusgoncarukas - I stand corrected!
Yes, this is one that if bought with a solo HD does not have the SSD blade hardware populated on the logic board. It also has soldered RAM
iMac 21.5" 1.4 GHz i5" (Mid-2014)
さんによる
コメントを追加
1 件の回答
ベストアンサー
Not sure I follow you here. First this is the IFIXIT guide to gain access to it: iMac Intel 21.5" EMC 2805 SSD Replacement.
Apple failed to populate to needed hardware on only the very first version of the newer 'Thin Series' 21.5" iMac (EMC 2544) back in 2012 and only in the lower end model which it then finally stopped doing once people complained.
So the bottom line here is: All of the 2016 and the most current version of the 21.5" have the SSD slot hardware present
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Stefan さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 5
今までの合計 757
