メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Galaxy S6 Edge+ はGalaxy S6 Edgeスマートフォンの大型モデルです。 Problème charge
Front Glass Replacement for Galaxy S6 Edge+ Plus?
I have been looking for a replacement screen for the past 2 months. (Screen broke 1 month after buying the phone.. WITH A CASE ON IT!) It still works but Its a big eyesore.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
コメントを追加
10件の回答
ベストアンサー
If the glass gets damaged, the easier and safer solution is to replace the complete screen assembly since the glass, digitizer and LCD screen are bonded together tightly by the help of very strong adhesive, and it is very hard to separate neither of them for individuals. Though there is front glass replacement sold separately. The reason is that it is possible to remove the glass from the LCD, as long as you have special tools as well as professional skill. Otherwise, it is better to replace the whole assembly rather than just the glass. Here is the s6 edge+ screen replacement from the third party: http://www.witrigs.com/oem-lcd-with-digi...
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I wonder how much Samsung charges for a screen replacement because it is definitely cheaper than anywhere else for S6 edge and higher in Australia.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I can help you it it's easy as 1 2 3 add me on Facebook jp Joseph
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I agree with kristastic1990 ... however it might be cheaper to buy a second hand S6 edge on eBay and then sell your broken glass s6 edge back on eBay ... difference might only be $100 - $150 as people with the right machines will buy it to refurbish the glass only.
Please do not attempt to a glass only replacement. I have been a tech for 5 years with mobile devices and its just not a feasible repair.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
You'd better replace the whole AMOLED display, only replace the glass is very difficult and need some equipment. Here is about how to replace Samsung Galaxy S6 Edge + display. Samsung Galaxy S6 Edge Plusの分解方法
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
jpride56j5 how can I get intouch with you ? I've got a s6 edge plus that needs a new screen ? Thanks
さんによる
コメントを追加
I don't know how you have searched for replacement screen. My first suggestion for you is to replace the screen at Samsung store. It might cost a lot, but reliable. You can also just find a common repair store, which should be cheaper. Or, you can buy a replacement screen online and install it yourself. Alibaba should have the cheapest screen. But, sharpen your eyes.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
See for yourself! Repair stores refuse to even try to fix it! I wouldnt ask here if I didnt look before.
さんによる
コメントを追加
My Brother in Law says the 6 edge plus can't be taken apart, can I get the answer on this ? Yes we're fusing over it lol .
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
It can, but isn't the easiest of phones for disassembly, quite a bit of adhesive is used to hold the front and back in, and to service a lot of the stuff, the screen needs to be removed.
さんによる
コメントを追加
samsung s6 edge front glass change
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Yes
I want to replace samsung. S6 edge. Plus screen. Display
What. Will I do
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Samsung 6 edge plus replace screen
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
REYESRZA さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 28
今までの合計 27,602
