メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
AppleのMagic MouseはAppleによって製造・販売されているマルチタッチ式マウスです。2009年10月20日に初めて発表され、発売されました。
MOUSE is not working
My mouse suddenly stopped work. The batteries are new but the green light does not turn on and does not work. Is there a way to fix it. I appreciate your assistance. Maria
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
my magic mouse has stopped working on a mouse pad, but works fine on a table. Weird. No problem with my wife's mouse which is identical. any explanation? for this?
さんによる 共有
コメントを追加
2件の回答
最も参考になった回答
I had the same issue. I used a Q Tip and some rubbing alcohol and cleaned all four battery contacts with the wet alcohol. Then I used the other end of the Q Tip (the dry end) and dried the terminals completely. I replaced the metal back and turned on the switch and the green light turned on right away. Hope this helps!
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
This simple solution worked for me, thanks! My v1 Magic Mouse has been working perfectly since I purchased it in 2009. Today it suddenly stopped working. I removed the batteries and examined the terminals. I discovered that the + terminals were cloudy, especially the one on the left. I used a Q Tip and a tiny amount of Deoxit contact cleaner to clean the terminals. Nice and shiny again. Put the batteries back in, turned it on, and all is well. Very glad I can keep using this peripheral.
さんによる 共有
コメントを追加
First try restarting the computer that uses this mouse. If it fails to start working:
un-pair the connection... restart machine again... then repair the mouse with the computer. You should be good to go. If not, then you either need to check to see if you need to do any updates...
Worst case scenario, the hardware in the mouse went bad. In which case you can either do a tear down and attempt repair... or search macsales.com or amazon for a replacement. With Black Friday around the corner deals are all over the place. I believe I saw one as cheap as $30.
I'm not sure that it would pertain to this situation...
If you want to try a SMC reset prior to a teardown or replacement... make sure that you have a backup of your drive and the data on it. Then do a search for " SMC reset" and the model of your Mac computer. Click on the link that leads you to the apple forums. There you will see a full example of how to do a SMC reset.
Sometimes things like SMC resets and even PRAM resets tend to knock out any weird "cobwebs" that tend to bother Macs.
Happy computing and good luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Maria Santos さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 34
今までの合計 2,198
