My rx/tx light turns red
When I key my mic the rx/tx light turns red. When I unkey it turns back green. I also cannot recieve anything coming in nor can I get out. Please let me know what you think
Your tx/rx light should turn red when you transmit and be green all other times. Your ant light should not light up unless the swr is higher than 3.0; then there is a problem. A common reason for the ant light to light up is that the antenna is not grounded properly.
Check out this page from Firestik for more information on swr and cb's.
If your ant light is on when you transmit, stop using the radio and fix the swr. You will ruin the radio.
Good luck and enjoy your cb radio!
このアンサーは役に立ちましたか?
the green light is suppose to be on whe cb is turned on .and red when keyed up.
My RX/TX turns red when I transmit as expected, Have no problem transmitting or receiving, My SWR as Advertised and Antenna light stays off, RX/RT light is green until transmit, Make sure that NB-ANL/ANL OFF
このアンサーは役に立ちましたか?
From what I was reading the NB-ANL/ANL help filter out the noise from the ignition system and other working parts of the vehicle that give off background noise. So, why do I turn this off??
このアンサーは役に立ちましたか?
I wouldn’t turn off the NB/ANL. It filters out a lot of noise.
Ok sorry don't have an answer I have another question, my rx/tx red when I key up like it's supposed to, but I have mine on cal to calibrate it but the needle doesn't move to cal ... it doesn't move at all for that matter ... what gives !!?
このアンサーは役に立ちましたか?
Check to ensure that you have selected "CB" and not "PA" on the face of the radio. If the radio is older, or has been mobile for some period of time, you may want to maneuver this switch back and forth a few times just in case it's has fallen prey to an internal contaminant.
このアンサーは役に立ちましたか?
I have had this issue in the past and for me the most common problem is the mic went bad. You could try replacing the mic and see if that helps. For some reason when the mic goes bad with the newer radios they won't transmit or receive.
このアンサーは役に立ちましたか?
過去 24時間: 4
過去 7 日: 29
過去 30 日: 109
今までの合計 48,157
1件のコメント
Mine does the same thing but no antenna light
Chuck さんによる
