メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
The antenna cable connects the antenna to the antenna connector.
  1. Turn the power switch, the leftmost knob, counterclockwise to off. Turn the power switch, the leftmost knob, counterclockwise to off.
    • Turn the power switch, the leftmost knob, counterclockwise to off.
  2. Turn the device around and firmly pull the power cable plug to remove it from the radio. Turn the device around and firmly pull the power cable plug to remove it from the radio.
    • Turn the device around and firmly pull the power cable plug to remove it from the radio.
  3. Unscrew the securing cap counterclockwise from the antenna connector. Unscrew the securing cap counterclockwise from the antenna connector.
    • Unscrew the securing cap counterclockwise from the antenna connector.
  4. Gently pull the antenna cable to remove it from the back of the radio. Gently pull the antenna cable to remove it from the back of the radio.
    • Gently pull the antenna cable to remove it from the back of the radio.
終わりに
danperoni
メンバー登録日: 2013年10月18日
485 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 11-37, Amido Fall 2013 Cal Poly, Team 11-37, Amido Fall 2013人のメンバー
CPSU-AMIDO-F13S11G37
4 メンバー
9のガイドは作成済み
コメント1件
I dislike that kind of antenna plug. To easy to put together wrong. Better to find a pl259 plug that gets soldered. YouTube must have a video on it somewhere.
rrmanning06 - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 16
今までの合計 1,552
