メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2009年に発売された自動掃除機、iRobot Roomba 560。
ERROR 10 - without a good reason
I am hoping one of you techno geeks (like me) may be able to help me with solve a Roomba ERROR issue.
I mod Rooba 560/650s to act as a powerful UVC sterilization robot.
I pull all the motors, blowers and brushes and replace it with a custom UVC bulb.
If its bacteria or Viruses . . . .we kill it. (after two passes)
Overall - it works great . . .
[b]PROBLEM: we are getting ERROR 10's when we try to run it in a larger open area - say 20 X 20.
IT is definitely NOT a wheel issue or jam as the code would indicate.
This is some other issue that stops the robot in its tracks and ERROR 10's.
I am thinking it just gets to far from its base OR it went to far without seeing a wall or obstruction. I am trying NOT to add a virtual wall or obstructions to make the robot happy. Perhaps there is a small circuit I can add to make it think it has seen a wall or obstruction?
Can anyone help me figure out why my Roombas (Germbots) error out like this.
More - over - I am willing to give a $500.00 finders fee to anyone who comes up with a solution for me. (for real)
Bruce Winkler
608-215-0031
germbot
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
Gives that error when the wheel is somehow stuck and also (like in your case) when trying to clean a big room. When the room is to big for the Roomba to sense obstacle or walls you need to use your virtual walls in order to shrink (virtually) the Roomba "room size".. this will fix your issue.
Let me know if it works for you.
Charlie
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
I have a large room ( hangar for an airplane)
I don’t want to add a virtual wall what do I do?
さんによる
コメントを追加
I have this problem to
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have this issue too. It doesn’t like large open spaces. That’s the best I can come up with. I may have to create obstacles for it to avoid so I don’t have to restart it every 5 minutes
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Bruce Winkler さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 26
今までの合計 3,474
