メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
VTech製のVTech Safe And Sound DM221は、ベビーモニターと親機で構成されるデジタルオーディオモニターです。
Two Monitors Not Linking
Why are my monitors not linking?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
4 件のコメント
Because V-tech monitors are crap. We got two and both won't link. The company won't do anything about it either.
さんによる 共有
Can I pair the camera to a Motorola monitor?
さんによる 共有
I paid 300 for a monitor I have to reset every other day? Don’t waste your money buy something else
さんによる 共有
Frustrating is what it is. Grant it we just got the $20 unit that just has 1 parent unit so I can’t expect nothing too great but it worked great for a year! . Maybe it senses that my daughter is 1 years old now and can tend to her own self
さんによる 共有
コメントを追加
4件の回答
最も参考になった回答
Monitors Not Turned On
Press and hold the power button for 2 seconds to turn on the baby monitor. Repeat the same process for the parent monitor until the screen display lights up.
Monitors Not Within Range
Move the parent monitor closer to the baby monitor, but do not get closer than 3 feet from the baby monitor.
Monitors Need to be Reset
Reset the monitors by turning them off and unplugging them from their electrical power. Wait 15 seconds and then plug them back in again. Turn on the monitors and allow up to a minute for the monitors to synchronize.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
On the bottom of my camera (owls) there is a pair button. The monitor has a menu; scroll to the pair camera. Hold down the pair button on the bottom of the camera while selecting pair camera on menu. Push and hold both buttons at the same time until they pair. I had to do this about 4 times. Make sure when you press the button on the bottom of the camera a green light starts flashing. Hope this helps
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Mine still is not pairing..is there another way to do it
さんによる 共有
コメントを追加
1. Remove all cameras from menu option
2. Reset all units by unplugging from outlet source and remove battery from parent unit
3. Wait a few minutes
4. plug everything back in and turn on
5. Add camera in menu option. Parent unit will begin to search
6. While parent unit is searching press pairing button on bottom of baby unit top right corner (small skinny screwdriver or pencil is needed)
This worked for me and paired the camera unit in less than a minute and now is working again
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Can I pair my ZTE mobile phone to vtech baby monitor
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Krystal さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 51
今までの合計 82,432
