custom binary blocked by frp lock
?????? i cant used
i traid factori reset but not word
fashit the batery
the cellular said (keanel is not seandroid enfoacing custom binary blocked by frp lock
この質問は役に立ちましたか?
?????? i cant used
fashit the batery
この質問は役に立ちましたか?
For phones that say custom binary blocked by FRP lock after root / flashing modified binaries:
You need to put the phone into download mode by keep holding power + volume down and home until you get the light blue screen then enter download mode.
Then you flash matching Samsung firmware on there. Either 6.x or 7.x using downloaded firmware from either updato or sammobile website.
After that you may also need to do a factory reset in recovery mode as well if it still does not boot.
Once it boots go through setup and enter linked google account login as prompted.
Now to bypass FRP lock you use the instructions on this thread:
http://forum.gsmhosting.com/vbb/f777/uni...
Make sure you downgrade from 7.0 to 6.0 if you are on Nougat first before doing the frp bypass trick.
You also need 6.0 android google account APK so that frpbypass rootjunkie APK works.
Do some research if you can't work it out.
このアンサーは役に立ちましたか?
After blue screen my phone screen showing:
Downloading.....
Donot turn off target
Now what I have to do?
Use Odin software to flash the Samsung firmware onto the phone.
Guide here:
Downloading.....
majeed
enabled is working
Just created an account to express my thanks and gratitude for your post, Ben. It was really helpful and helped my situation greatly. I can't thank you enough.
Flash original firmware in odin. Boot up device. Enable developer settings. Select OEM option, enable. Now you can flash custom firmware without tripping the security.
このアンサーは役に立ちましたか?
Where do I get the original firmware?
Downloading.....
Hi,
you should use Samsung Smart Switch "emergency recovery feature" and it will work fine again. You'll lose all your data but the device will work again
このアンサーは役に立ちましたか?
i tried it doesnt works for me
perhaps Samsung has changed something within this process. TRY to send it in as a warranty issue.
https://youtu.be/HprnsOIbpJo custom binary blocked by frp 100% solution all samsung done by one click
このアンサーは役に立ちましたか?
custom binary blocked by frp lock https://www.crazyhax.com/solved-custom-b...
このアンサーは役に立ちましたか?
If you want to unlock custom binary blocked by frp lock then you need to download odin app which will help you to unlock custom binary.
このアンサーは役に立ちましたか?
1.Download Update Rom
2.Flash Your Mobile Phone
3.Solved Your Problem
このアンサーは役に立ちましたか?
I have fix my issue with samsungcombination.com where you can get firmware file and combination file
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 4
過去 30 日: 19
今までの合計 192,459
14 件のコメント
I have this promblem too it has a warning sign and says custom binary blocked by frp lock and no matter what I do it wont leave that page. it started when I rooted my phone, when I rooted it, the phone shut off then did the warning screen. PLEASE HELP FIX
Diontae Berry さんによる
I got the same problem with my G S6 edge. I have been up for countless hours over a week searching for a fix. Were you able to resolve your issue?
Iz Reyz さんによる
any link please for this solution....
Asif Cricketer さんによる
I wanna kill this guys grammer and then kill him
Luke Newton さんによる
bakht sher さんによる
9件以上のコメントを表示
