メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Mach Speed Technologies社が製造したTrio Stealth G4は、7.85インチHD画面を搭載したタッチスクリーンタブレットです。このデバイスはWi-Fi、Bluetooth、Google Playに対応しており、クアッドコアプロセッサ、フロントカメラ、リアカメラといった機能を備えています。
How do I reset my password?
I forgot my password and can't get into my tablet. How can I reset it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 11
9 件のコメント
One of them told me to go to my setting or widgets but HOW WHEN I CANT LOGIN
さんによる
Power volume + only resets it. Still asks for password. Help please.
さんによる
Yea how wen it asksnfor password to do anything.
さんによる
there are many ways, hope it can help you:https://www.isunshare.com/windows-10-pas...
さんによる
Hi @ Elina ANN,
The Trio Stealth G4 is an Android tablet, not a Windows tablet.
さんによる
4件以上のコメントを表示
コメントを追加
2件の回答
最も参考になった回答
Hold down Volume + button and Power button at same time. When screen comes on let go of Power button. When the large Android shows on screen let go of Volume + button. Use Volume – button to scroll to Wipe Data/ Factory Reset.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Will this cause me to lose all my pictures and data? Is there any other way to reset just the password without resetting the entire device?
さんによる
Unfortunately you will loose your data. It is the security design, no point in having a password to protect your information if there is a way around it.
さんによる
I have a used Trio Tablet Mst-1041 and another smaller generic tablet that was given to me because the Passwords were either forgotten or corrupted & I am trying to do a "Hard reset' on both of them also.. When the Power button & Vol+ is used it boots into the normal window asking for PW.. When the Power button & vol- is used it boots into safe mode still wanting a PW. These answers here are not helpful at all, there must be another way to do hard resets on these tablets. Any viable answer will be highly appreciated since I really hate to throw away two perfectly working tablets just because of a stupid Password lockout.
さんによる
コメントを追加
If you have enabled Android Device Manager on your device, you can reset your password from the Device Manager website. Follow these steps:
  • Log in to Android Device Manager
  • Select your device
  • Select 'Lock'
  • Enter a new, temporary password for your device and click 'Lock'
  • Enter the temporary password on your device
  • Go to your lock screen settings and disable the temporary password you created.
If this doesn't work or you do not have Android Device Manager enabled, you will probably have to do a factory reset. Follow kris's instructions or check out the troubleshooting guide.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
How can you "Log" in to the Android Device Manager" when you cant even log in without the "Password" to begin with? The "Issue" is.. The "Question" is... How can you hard reset the Tablet to erase, factory reset or get around the the password requirement. Did you even read the question? Your response was not helpful at all.
さんによる
コメントを追加
回答を追加する
Dani Gutwein さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 28
今までの合計 7,727
