メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Motorolaのミドルレンジからハイエンドスマートフォン、Moto Xシリーズの修理情報です。
Fix for headphone jack not working
For anyone who has come across an issue where plugging their headphones into their moto x and then the audio either stuttering between the headphones and the phone's speaker, or just not playing through the headphones at all. The issue is a small metal clip at the top of the inside of the jack. It gets worn away and pushed back and stops making contact with the rings on the jack. Here is how to fix that using a small piece of cardboard or other non-conductive material:
Hope this helps for anyone desperately trying to figure out how to save their trusty moto x.
EDIT:
The link above no longer works, so I posted a photo illustrating where to insert the spacer: http://imgur.com/a/3bHEc
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 6
9 件のコメント
You are the saviour ! My Moto E2 now works - only the left headphone speaker was working, now both are back in action !! Thanking you!
さんによる
Technical assistance charged me 60 Bucks to fix this, luckly i saw this before making any real. Thanks a Lot!
さんによる
Thanks so much! I'm pretty rough with my phone when I'm out running. I used a small piece of plastic and pushed it behind the contact after pulling it out with a safety pin. Works fine again!
さんによる
Awesome. It fixed my Moto G3 too. Thank you so much. Twas too easy
さんによる
Hey, is there a way you can update the link? When I click on it it takes me to a broken link! I would love to be able to fix my headphones :)
さんによる
4件以上のコメントを表示
コメントを追加
5件の回答
ベストアンサー
reply post so I can mark this as "solved".
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
can you descriibe the process? link doesn't work.
さんによる
I just updated the post with a new link:
さんによる
Can I use a safety pin to pull the clip
さんによる
Got a Motorola e6 plus and when I connect me headset the sound come out me phone but sometimes it just work but stop a few minutes later
さんによる
コメントを追加
最も参考になった回答
Sometimes there even a simpler solution, My headphone jack was having all sorts of issues. I took a flashlight to look inside and lo and behold pocket lint had built up inside the jack. I used a wooden toothpick to clean it out and had no problems after that.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Nevermind! I just saw the updated link! Sorry and thank you!
さんによる
コメントを追加
Brian, this link doesn't work anymore. Can you describe your fix or maybe post it elsewhere?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Sorry I never saw this! I've updated my post with a picture to illustrate what I was talking about:
さんによる
コメントを追加
How do I take off my back of my phone so I can get the headphone jack thing out of my phone so that way I can listen to my music and watch my movie
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
It's a workaround, not a solution.
We all have old phones around. Find one that DOES work with headphones.
Use HOT SPOT to connect to your Motorola.
Now run your music app on the old phone with streaming through the hot spot. Works great!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Bryan Woods さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 31
過去 30 日: 140
今までの合計 117,108
