How to fix dead keys?
Several keys are dead: <left cmd>, plus <c> through <m>, <,>, and <.>. Is there a repair guide for the keyboard itself? How about replacement parts?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Sounds like you have had a short. The keyboard will need to be replaced. The part can be found on eBay usual about $25-$40. Make sure you get the one for your machine and with a back light (a little more). The cable that connects to the logic board is slightly different on some machines. It will take you a while to remove the approximately 85 tiny screws and put them back in. I use an electric screwdriver to remove them. The job takes me about 1 1/2 hrs to 2 hrs. to complete but I've done it a lot. Add an extra hour and try not to be disturbed. Here a guide for the 2010 machine but is the same for your 2011: MacBook Pro 13" Unibody Mid 2010 キーボードの交換
このアンサーは役に立ちましたか?
Hi,
my sdfghjkl keys do not work on a MacBook Pro 13 inch April 2011 (i5)
how can I test them?
how do I know which type of keyboard to look for on Ebay? I find it stupid to pay 200 USD or more to change the whole front!
このアンサーは役に立ちましたか?
I also have the same problem. Is yours already fixed? What did you do? Thanks
過去 24時間: 0
過去 7 日: 2
過去 30 日: 20
今までの合計 7,937
1件のコメント
OK, I found a bunch of YouTube videos showing the teardown plus a few showing a cleaning procedure for the keyboard (in particular, Louis Rossmann's replacement video. I am still interested in sources for the parts, chiefly the keyboard.
Arthur Ogawa さんによる
