How can I tell?
I can't tell if I have a banana or avocado or maybe a dog? I might even have a mink pelt. I just wish there was a way to see if what I was holding and attempting to eat is actually a banana.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
In case you are blind, bring in a monkey, wait 5 minutes, feel for which item is missing.
このアンサーは役に立ちましたか?
What if it were a plantain?
Then it wouldn't be a banana.
Does the device emit a sound of any kind (while stationary)? Does it appear to have an on/off switch?
If it makes a sound, or has an on/off switch, it is NOT a banana.
このアンサーは役に立ちましたか?
is there a way you can post a picture of the device? it could be any of those. What are the specifications? or is it a knock off?
このアンサーは役に立ちましたか?
Just make sure that the device is yellow and crescent moon shaped. If it has legs, then it's probably not edible in that state. If it's green, it may be an avocado. Hope this helps...
このアンサーは役に立ちましたか?
if its green it also could be a cucumber, lime, or even a plantain. There are many options.
All of these green options are edible, however a lime is incredibly sour, and the anti-opening device in the lime will cause temporary blindness if the fluid is caught in the idea. A cucumber is extremely ovular. A plantain looks like a banana, but you may encounter bitterness. This is the anti-opening device.
the blindness will come from a lemon that has been died green.
That’s dyed green.
過去 24時間: 5
過去 7 日: 36
過去 30 日: 67
今までの合計 1,312
