メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
マザーボードとCPUの修理ガイドとサポート。
Intel DG31GL Motherboard Audio problem
Hi I'm Anzar. I have an intel dg31gl motherborad which has audio problem in win7 32bit os when I installed correct drivers from intel site still doesn't work it shows realtec high definition installed but sound icon shows in red saying No audio output device installed and I tried update windows shows already installed and then I disabled audio from bios and restarted the pc and then enabled still doesn't work. Are there any other way to solve this?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
3 件のコメント
I hv intel mother board .. I hv all sound port includion a new sound port device ...i also install the drivers properly ...i also see al sound icon ..they are vibreting but no sound come from any port ...what is the solution plzz
さんによる 共有
sound drivers is not installed
さんによる 共有
I have found out it's the issue with realtek sound chipset not the drivers. Every intel dg31gl has same problem. And I changed the motherboard.
さんによる 共有
コメントを追加
3件の回答
ベストアンサー
If you need to configure or set up your computer motherboard’s CMOS, BIOS, or chipset, see the Motherboard CMOS Configuration and Setup page for instructions.
This sounds like a driver problem, you may need to purchase a new sound card.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I thought of not installing sound card and try to fix it but it works on usb soundcard
さんによる 共有
コメントを追加
最も参考になった回答
First make sure you did re enable audio in the bios and when you are in windows open device manager and click on "sound,video and game controllers" and uninstall all your audio devices and restart your pc. if that does not work then let me know.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Sir st3v3w I tried what u said re enabled audio in bios and tried opening windows and on device manager uninstalled sound, video and uninstalled all sound drivers and restarted the pc and tried reinstall still doesn't work. And I tried installing what is that called the Microsoft universal audio something downloaded from Microsoft website and still didn't work.
さんによる 共有
I had been searching to solve this solution everywhere and online for past 8 months and I didn't replace my this motherboard. So thought of without replacing can be solved
さんによる 共有
sound,video and game controllers is not show in Device Manager
さんによる 共有
コメントを追加
I have found out it's the issue with realtek sound chipset not the drivers. Every intel dg31gl has same problem And I changed the motherboard.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Bro not working
さんによる 共有
コメントを追加
回答を追加する
Anzar さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 24
今までの合計 4,521
