メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Wii Uは、Nintendoが提供する、GamePadを使用してゲームをプレイできる携帯端末と組み合わせたゲームコンソールです。デバイスは非常にモジュール化されており、コンソールの修理は簡単です。
Replacement ribbon cable clamp?
So today I decided to replace my gamepad screen, since my old one had a scratch that make a area of the screen untouchable. Seems while in the process one of the ribbon clamps came off.
here it is.
I found it, but while trying to put it back on it snapped in half. it looks like this one.
Here.
Anyone know if (and where) I can find a replacement, or a way to make it work? Everything works fine except for touch, which is what this cable is for. I hear electrical tape can work, but I don't know what exactly to do with that.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
5件の回答
ベストアンサー
Position the ribbon cable onto the conector and then use white tak...its like blue tak but kind of sets harder!...to keep the cable pressed down.
This worked for my one!
You might have to try a couple of times before you get it to work!
Take a look at my YouTube video...
https://m.youtube.com/watch?v=mNbxeLlpaO...
http://www.amazon.co.uk/WHITE-TACK-BLUE-...
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
Would love to see this youtube video. I just tried and got nothing :/ Is the ribbon supposed to lay on top of the connector, or under? It slips in under so i figured thats the right way to do it.
さんによる
Just doing my vid today... i'll post on YouTube tomorrow and I posted the link asap.
さんによる
Awesome, thanks!
さんによる
great solution, thanks!
さんによる
コメントを追加
最も参考になった回答
The ribbon cable socket is desoldered from the logic board. It can be soldered in place but this have to be done by a pro. Find a place that repair iPhones and ask them to do the job.
このアンサーは役に立ちましたか?
スコア 2
8 件のコメント:
Isn't the socket what the ribbon cable goes into? I'm just talking about the gray thing that clamps down on it, unless that's what you're talking about.
さんによる
OK, doublechecking at the first pict I think that it's the cable that need to be replaced. The connector is desoldered from the cable and seat now in the socket. Not sure that the connector can be soldered to the cable.
さんによる
Looks more like the grey clasp is broken off. It provides downward pressure on the cable and allows it to make contact.
さんによる
oldturkey, is it the same type of socket than the keyboard backlight socket on a MBP ? You insert the cable in it and push down a lever to secure the cable ?
さんによる
The cable's fine, the angle just makes it look weird. I am talking about the gray part that clamps down for pressure.
さんによる
3件以上のコメントを表示
コメントを追加
I need this answer too. Chrisall76 did you ever get something to work?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Nope, had to buy a new gamepad.
さんによる
コメントを追加
Does electrical tape work?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
i taped it with gorilla tape... but when i had to replace the touch screen the tape didnt work anymore.... im trying hot glue next
さんによる
コメントを追加
i did the same to the clasp that is for video....the one in your second pic. i put tape on it....keeps going off. i started to put hard things on top of the ribbon with tape for pressure and still comes off. some said glue but i dont like that idea because one it can cover the pins and two what if you need to replace stuff and it cant come out. i was wondering if the clasp was replaceable too
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Fixed this whith white tak...
さんによる
コメントを追加
回答を追加する
chrisall76 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 32
今までの合計 12,299
