メインコンテンツにスキップ
The Inspiron 15-3521 has an optional touch screen feature and has a 15.6" display. This laptop is also complete with a matte finish and keyboard complete with number pad.
40回答 すべてを表示
Why is my laptop not charging?
I have the power cord plugged in and my computer will turn on but when I take it out, the computer shuts off.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 26
3 件のコメント
dell 3521 battery red light billing what a problem give me answer plz?
さんによる
Hey there! do you still have this problem?
さんによる
I have tested 2 original AC Chargers and don't turns on. I don't know battery status, until charging problems aren't solved I don't will bought any battery. Where they recomend me buy a AC connector and how can i change it?
Thanks a Lot!
さんによる
コメントを追加
16件の回答
最も参考になった回答
remove the battery and wait for life 2 min . plug it back and restart the computer . make sure you wait for like 5 min once you plugged in . just sit back check the power cord and wire . checkout this article for any other steps -fix laptop which is not charging while plugged . thanks
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
A laptop can lose its ability to hold a charge due to battery deterioration. To fix this, try turning off the computer and remove its battery and AC adapter, and re-install them after 10 seconds. Hold down the power button of your laptop for 30 seconds to see if it reboots and holds a charge without the AC adapter plugged in. Sometimes, it may be a battery issue, such as dust accumulation or battery deterioration, so try to remove the battery, remove the dust with a microcloth and re-install the battery, or completely replace it. In addition, check to see if your AC adapter is the correct one for your laptop- it may be made by a different company or contains different wattage that your laptop requires. If the battery and AC adapter does not seem to cause the problem, you may have to re-install the driver. For Dell users, this option can be found in the device manager tab > battery settings > Microsoft ACPI-Compliant Control Method Battery > Right-click Uninstall driver > Accept changes and install the driver again
Hope that helps!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Check this link to troubleshoot
http://www.dell.com/support/article/us/e...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I have to same problem. I have purchased a new battery and ac adapter--to no avail. BIOS cannot be upgraded because battery either shows it is not charging or is not recognized.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
how to bios apdate
さんによる
The blue light will not turn on
さんによる
コメントを追加
I had same problem for years with Inspiron 1501 and 2 years ago bought a new battery. This did not fix the problem and I left the new battery in and put the old battery in the attic. Today I found the old battery, re-inserted it and the problem is solved.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
check the charger
change the battery
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Dell Inspiron15-3521
New battery, new charger, I have done EVERYTHING possible to fix this problem and it still does not charge.... and because it is now down to 5% , the update for the BIOS ( which I am told would solves the problem ??? ) will not allow the download, until charged again ... what a joke this all is
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
sounds like a dead battery remove battery i think you can get to it with out taking the back off turn it upside down you will see a compartment with two slots pull apart and remove battery, you can go online and buy a cheap one get make and model of old one and order.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
As other people have mentioned, it could be because of a problem with the battery. If it was me, this would be the first thing I check and diagnose. The battery may have lost its ability to old it's charge, or to charge at all.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
probably need a new battery or search it up on YouTube how to fix it;)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I just bought a new charger and a new battery and the battery will not charge. What am I doing wrong?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I am having this same problem with my Inspiron 5558. It is not the adapter or the battery (still holds a good charge when I CAN make it work)
If I repeatedly unplug the adapter from the laptop and plug it back in, it eventually will charge normally. At first, this would take a couple of tries, maybe up to 5 or 6. Now, it takes many, many attempts, over a hundred on one occasion.
I have reloaded BIOS and driver. It is definitely a software issue, because when it is in "plugged in, not charging" state, it also runs slow and stuttering. Video is jumpy and audio crackles, even when playing a file directly from the hard drive.
Is this firmware of some kind? I have seen a lot of mentions of this kind of problem online, so it has to be something standard with the Dell package. Dell support suggested I buy an $82 battery from them. Baloney.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I have the exact same problem
By any chance were you able to find a fix?
さんによる
Earlier i was able to make it work by rotating the cord which goes in
But now even that has stopped working
Any help would be appreciated
さんによる
コメントを追加
If you can boot your computer and you have power issues, the best step is to run the internal Dell diagnostics. To get into diagnostics, hit F12 when the Dell splash screens shows, look for the option for diagnostics tests. Generally, it will test everything or you can select which parts to test. For power issues, you want to see that the ac adapter shows up correctly (if it shows up as 1 watt then it is either a bad ac adapter or a bad mother board) and you will want to see if the battery tests as healthy.
If your laptop is still under warranty, you can call Dell tech support and they can help you diagnose the problem and set up repair.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Well, I just read all these comments because I have the same issue, and reading them got me thinking. It randomly charges to full 100% and then can be unplugged for at least a day. So it's not the battery. But it is getting less and less, the more I fiddle with the plug, it will work sometime. So I cut maybe a 1/16 of an inch off of tip of the rubber plug, with a razor, just cut it against the metal plug, rolled it inbetween my fingers. Basically to plug it in a little deeper, and low and behold, it's now charging on the first try.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
You may need to replace the Dell Inspiron 15 (3531) DC Jack because of a faulty connection.
https://www.youtube.com/watch?v=01dNiIfd...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Charger pin is bent probly
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Katherine Browder さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 23
今までの合計 30,414
