メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
締切られた回答
Can the iPhone 6 and iPhone 6 Plus cameras be swapped?
If I were to procure a rear facing 6 Plus camera, could I install it in my iPhone 6 and have a customized optical stabilization camera? Would the software even know what to do with that piece?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
8件の回答
ベストアンサー
Sorry folks they are not the same size so I doubt it will even fit as the plus unit is the larger and has different mounting. See for your selves:
Yes the connectors are the same but we don't know the how the signaling is managed.
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
Thanks for the info.
さんによる
it works... just have to stick camera with double tape or some adhesive as 6 camera's size is smaller for 6+ camera housing
さんによる
what if we change the mounting for camera
さんによる
コメントを追加
この回答は他の質問に帰属しています。
supposing you could get the firmware working, the 19 pins I counted on the 6 cam was the same amount on the 6+, id be concerned about size too though im sure someone will measure that out soon enough.
Would be an interesting hack for sure.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Yes, I think it would be an interesting experiment to see how compatible it is and how much software would need to be altered?
さんによる
コメントを追加
Check out this question thread: Can the iPhone 6 Plus camera fit in the iPhone 6?.
As it looks now they are not compatible as the size of the units are different.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
この回答は他の質問に帰属しています。
A little off topic but 6 and 6s front cams are interchangeable FYI
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
See my post here:
Will the iPhone 6s front camera work on an iPhone 6?
Are you saying you can swap the front cam and rear cams both from a 6s, into a 6???
さんによる
front cams yes, not sure on rear cam but I don't think it would work.
さんによる
Rear camera NO, front camera yes. And i´m talking about 6 and 6s (not 6+).
さんによる
Are you sure that iphone 6 can use 6s front cam ? How abt the quality? If you have an instagram can u pliss dm me? @ssssssafwan
さんによる
So is the 6+ front camera interchangeable with the 6 front camera? I know the 6S front camera works on the 6, but how about the 6+ front camera?
さんによる
1以上のコメントを表示
コメントを追加
この回答は他の質問に帰属しています。
I really really doubt if looking at previous phones they made and there interchangablity.
Id say the connectors are completly different
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Not to mention I am sure the iPhone 6 firmware will not support the motor hardware inside the 6 plus camera. Even if you did get the camera in there working, it wouldn't work as it is supposed to.
さんによる
Do you have any evidence that the connectors are different or is that a guess? Also, how are you "sure" that the firmware will not support the motor hardware or is that also just a guess?
さんによる
Are they different? Could you look at them? And what about the size? If you took apart the tho phones, it would be possible to check these two things.
さんによる
コメントを追加
この回答は他の質問に帰属しています。
Any update on this, guys?
I'd love to have the 6 regular with a 6+ cam!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
この回答は他の質問に帰属しています。
Just hope is it a problem of thickness not allowing it fit in 6 vs 6+, otherwise cheap attitude of Apple regarding expensive price ...
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I could see this as an issue, dont know how we could get around it unless its only the bit that sticks out. meaning that the camera lens would simply stick out more on our 6s than before.
さんによる
seeing how the past iphone components were incompatible i highly doubt it. let us know what you discover though!
さんによる
コメントを追加
この回答は他の質問に帰属しています。
I can confirm at least with my case that an iPhone 6 camera works inside of an iPhone 6+. I did it on my personal device since my 6+ camera’s stabilizer broke and I had a non-working 6. It works at least for now so I am pretty sure its fine.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 490
