メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2690回答 すべてを表示
Will the iPhone 6s front camera work on an iPhone 6?
I broke my front facing camera on my iphone 6. Will the 6s camera work on the 6? The 6s front cam is a few megapixels more than the 6 front cam and I'd like to try it. The connectors look in the same spot and same number of pins where where it plugs in, but the cable itself is a little differently shaped, but again, connectors are in the SAME SPOT.
See pic here:
https://i.ebayimg.com/images/g/cpkAAOSwF...
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
9件の回答
ベストアンサー
Officially, these are not compatible; looking at the flexes, they are a little different. However I saw the other day an answer from a repair tech that indicated they were interchangeable (Can the iPhone 6 Plus camera fit in the iPhone 6?). I haven't tried myself but checking on a few vendor websites, none of them list them as compatible.
Hopefully someone will answer definitively otherwise, you will have to try it yourself and report back so we can all benefit.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Very cool, yea, you mean the last post on your link? Interesting.. Hopefully he can chime in with more info.
さんによる
It’s working
さんによる
コメントを追加
最も参考になった回答
yes it works, we use them sometimes when we runout of 6 front cams.
このアンサーは役に立ちましたか?
スコア 3
5 件のコメント:
Ok, so eventhough the cable itself is shaped a little different, it still fits? Good to know. And I think the 6s front cam is higher mexapixel right?
さんによる
And, while I'm here asking, how about the rear camera>? WOuld a 6s rear camera work to replace an iphone 6 rear camera?
ALso, will the iphone 6 be able to use additional megapixels the 6s cams have??
さんによる
I'll try for you next time I get chance but I don't think the rears are interchangeable.
さんによる
Ever find out if the rears cams from 6s and 6 are compatible yet? Never found out.
(update: I still didn't get around to installing yet, but I will soon. The 6s front cam/proximity sensor cable into an iphone 6. As mentioned by Chris is works. My next question is, I'm assuming it will work better since the 6s front cam does have higher megapixel? Hope it's not scaled down due to hardware and it will perform better than the old cam?)
さんによる
DO NOT TRY IT !!! i tried to see if i could put a better camera on my 6 but the processor just gets really hot and starts burning.
さんによる
コメントを追加
Hi there, Gideon Here I am a Zambian and I am from swaping the iphone 6s 4.7” front facing camera with the cable to iphone 6 4.7” and it works and the camera has improved thank you for trusting me
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
この回答は他の質問に帰属しています。
I do not believe that these parts are compatible.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have done exactly that and yes it works, really wasn't expecting it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
この回答は他の質問に帰属しています。
But do you get use of all megapixels on the 6S front camera, or will it only use the 1.2 mp which the iPhone 6 normally has?
I have also tried it and can confirm that it works with the 6S front camera on the iPhone 6, but don’t know if it works the other way around though (6 front camera on iPhone 6s), I guess it should?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Can 6 front cam work on 6s,this has not been answered yet,anyone?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Can 6 front cam work on 6s?
This has not been answered yet,anyone?
さんによる
コメントを追加
Can i use an iPhone 6s rear camera on iPhone 7?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Yes they are compatable.
このアンサーは役に立ちましたか?
スコア -1
3 件のコメント:
Great to hear. I still didn't get around to installing yet, but I will soon. The 6s front cam/proximity sensor cable into an iphone 6. As mentioned by Chris is works. My next question is, I'm assuming it will work better since the 6s front cam does have higher megapixel? Hope it's not scaled down due to hardware and it will perform better than the old cam?
さんによる
Does it cause any issues swapping a 6s front cam into the 6?
さんによる
What about swapping 6s rear with 6
Does it work
さんによる
コメントを追加
回答を追加する
Jason さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 15
過去 30 日: 36
今までの合計 11,823
