Will not sleep when closing lid
Hi;
The noted Macbook will sleep automatically per settings in System Preferences and when > Sleep is selected. However, when the lid is closed it will not sleep and the back-lit Apple logo on the cover stays lit.
I've tried creating a new user - issue remains. Tried a clean install of Mavericks - issue remains.
This Macbook recently received a new screen (from iFixit) which in all other respects works fine, and there were no issues during installation.
Is this a hardware or software issue? Any pointers for further differential diagnosis are welcomed.
Thanks!
この質問は役に立ちましたか?
5 件のコメント
Did you replace the LCD alone or did you switch out the complete lid assembly?
Dan さんによる
Dan;
I replaced the entire display assembly. I ordered here on iFixit, but noted that it had a screen glass labeled MacBook Pro rather than MacBook. My understanding is that they are the same internally
tjod さんによる
Almost the same ;-} Still different enough. The MacBook & MacBook Pro have different locations in the lid that holds the lid magnet that tells the system when the lid is closed.
Dan さんによる
That's interesting, and would certainly explain the behavior.
tjod さんによる
This is really frustrating. I was trying to decide whether to replace the LCD or the display assembly. Given the difficulty of removing the glass, I decided to get the full assembly and practice with the glass on the old one when I could take more time with it.
It sure would be good of iFixit to send the *exact* part ordered or at least explain the differences if the exact replacement is not available.
tjod さんによる
