メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
1.86GHzもしくは2.13GHzプロセッサ、フラッシュストーレッジは128GB もしくは256GB
Location of Hall Effect [Lid] Sensor
I have a late 2010 MacBook Air that has suddenly started sleeping every few seconds. I suspect a problem with the Hall Effect sensor falsely indicating the lid is closed. I could not find much information on the location. With some experimentation, it appears this is on the left side of the laptop, where the I/O board is located. Is the Hall Effect sensor part of the I/O board? In other words, is replacing the I/O board a likely solution?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Remove the I/O board, you'll see a small sensor on a stack of thickened PCB
このアンサーは役に立ちましたか?
スコア 5
8 件のコメント:
Thanks. To clarify: The short answer is, "yes." I found the sensor attached to the top-facing side of the I/O board, on a riser as Tom described. I was able to verify that powering-up the laptop with the I/O board removed did eliminate the sleep problem--but, of course, introduced an array of new problems. Unfortunately, cleaning and reattaching everything did not resolve the issue which returned with the I/O board reinstalled, But, I'm anticipating that a replacement will resolve the issue.
さんによる
My replacement I/O board arrived yesterday, and did indeed resolve this problem. Thanks again.
さんによる
Hi, i have the same problem with a1502 mac pro. The MacPro went to sleep randomly and waked up soon with open lid. Do you have any part number or picture of the up side of the logic or io board?
さんによる
Here's the IFIXIT guide to replace the I/O board: MacBook Air 13" Late 2010 I/O Board Replacement. Often I find I need to replace the I/O cable as that sometimes gets damaged. As to a picture of the other side not much to see here: I/O logic bod from Mid 2011 model which is almost identical The Hall sensor is the square block just under the cable harness. I would try using a magnet placing it near the left side Tab key to see if it goes into sleep mode.
さんによる
Thanks for your quick help. I think i can't solve this an simple part replace.
さんによる
3件以上のコメントを表示
コメントを追加
回答を追加する
Kevin Barr さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 26
今までの合計 7,733
