Why is there no sound?
The volume is up fully and will not produce any noise! Help!
You might have a bad speaker or audio jack. In the case of the speaker you would need to check the connection between the speaker and motherboard. If it was due to the audio jack, cleaning it with an air duster may help. Check out the Troubleshooting page if you any issues.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 8
過去 30 日: 32
今までの合計 7,172
4 件のコメント
What is the exact model of phone you have? That way I will be able to further help you know what the exact problem is with your phone.
computeripodrepair さんによる
@computeripodrepair, LeapFrog LeapPad2 Explorer is a childrens learning tablet, not a phone!
oldturkey03 さんによる
Andrew Gough, what have you tried so far? how long has this been going on? Has anything happened just prior to it failing?
oldturkey03 さんによる
My daughter own is the same problem no sound
asheena lawson さんによる
