メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
1996年にTexas Instruments社から発売された人気のグラフ計算機。
Why is my screen faint?
My calculator was working fine until this morning during a test the screen turned super faint. It didn't die because I can still (almost) see the numbers.
The batteries are new but I tried other ones just in case.
Any ideas?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
My TI83 has a similar problem. When I switch ON, the screen has vertical lines where the pixels don't come on. The calculator works fine except for the vertical blank lines. When I use the calculator for some minutes, some of the vertical blanks become functional again. But there are always one or two lines that remain. Some thermal-related problem?
さんによる
コメントを追加
2件の回答
ベストアンサー
Janessa, try to adjust the brightness. The contrast on your screen might have reset to dark. You can adjust it by pressing "2nd" and the "up" arrow (or "2nd" and "down" arrow) repeatedly. Hope this helps.
このアンサーは役に立ちましたか?
スコア 10
8 件のコメント:
Holy $@$* you just saved my life
さんによる
thank you so much
さんによる
Thanks! That worked great
さんによる
Tried changing brightness/contrast, but the screen is still faint, I am hardly able to see the numerics on it.
Any other remedy?
even unable to find a service centre in Mumbai
さんによる
Just reset the calculator!!
さんによる
3件以上のコメントを表示
コメントを追加
Check the battery contacts to see if you have some corrosion on them.
Did you spill anything or stress it with some weight resting on it?
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Tried removing and cleaning the battery contacts, but the screen is still faint, I am hardly able to see the numerics on it. Any other remedy?
Any other remedy?
さんによる
コメントを追加
回答を追加する
Janessa さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 42
今までの合計 26,003
