メインコンテンツにスキップ
20-inch, 23-inch, and 30-inch aluminum LCD displays introduced by Apple in June 2004. Models A1081, A1082, and A1083 respectively.
99回答 すべてを表示
Need a good source for taking apart a 23" HD Cinema display
Does anyone have a good source (an Apple service manual would be ideal) of instructions for taking apart a 23" Apple HD Cinema Display (Aluminum)? I've poked around online but haven't found anything great. Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 6
1件のコメント
I have the Cinema Display take apart. Email me at fedguy2@ pacbell .net
さんによる
コメントを追加
8件の回答
ベストアンサー
Try this link. Ralph
http://docs.google.com/viewer?a=v&q=cach...
このアンサーは役に立ちましたか?
スコア 3
8 件のコメント:
Oh my. Any bets on how long that stays online before Apple's legal team has their way with it?
さんによる
I don't think so (or they aren't able to properly use a search engine).
oh, somewhere between the n and the t is one of the search results ;-)
さんによる
On the basis of Kyles remarks the OP should download this material now. Ralph
さんによる
can you reup please?
さんによる
Try this: service
さんによる
3件以上のコメントを表示
コメントを追加
Once inside, check the VR3 3.3VDC REGULATOR center pin to make sure it is putting out 3.3v, bad one will put out about 4vdc. It is very common problem with this 23" aluminum case.
See my pictures here:
http://s807.photobucket.com/albums/yy352...
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Hi
I have a blank screen (No Lights or display) I have followed your advice and tested the VR3 Regulator. Center pin is 1.96 DCV and Right pin 5.1. Assuming this show that it is faulty I was wondering the part number i should order and maybe where you were able to source it.
Also being surface mount is there any issues with DIY or would it be worthwhile finding a new board.
Thanks in advance
さんによる
コメントを追加
i've found a korean website - but the main focus is "looking inside" and not the "show others how to do it": CLICK
and a disassembling "guide" for the 20" CLICK
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
The first link is for an acrylic monitor but the one at the bottom is what I need. Thanks.
さんによる
コメントを追加
I have the 23 dvi version if you need another manual let me know.
Apple Cinema Display 23" HD DVI Manual
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thank you for the link and pdf!
さんによる
コメントを追加
All manuals.
http://tim.id.au/laptops/apple/
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
lokk at this master from Cile he helped me sure //// A1097 Broken Power Adaper fix for a 23" Apple Cinema HD Display. copy and look at Youtube good lycka
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Does anyone still have this display service source pdf around? I need to take mine apart and can't find the service manual anywhere...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Add me to the list of people needing a dissassembly guide. My new-to-me display has mould on the inside of the screen :( Heartbreaking.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
jasonnrogers さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 29
今までの合計 35,974
