メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2.4GHz、2.7GHz、または2.8GHzクアッドコアIntel Core i7プロセッサ(Turbo Boost使用時最大3.8GHz)、6MB共有L3キャッシュ。2013年2月発売。
MacBook Pro Retina Display Activation?
Is there an activation code for Macbook Pro Retina Display, because I have 2 MBPr and one display were dead (black), in order to be sure that only the display is defect I use the display from the othe laptop to test, but when I put the display back to the second laptop it doesn't work. And I'm wondering if there are activation codes for the MBPr to work with the installed display.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
Ouch!
So while there is certainly the possibility that I am wrong (although in this case, I doubt it), it sounds like... you either:
1. shorted the logic board fuse for the backlight of the one you returned it to (where you originally took the screen from)
2. damaged the pins on the cable from the display
3. damaged the port on the logic board for the cable from the display
4. didn't seat the cable properly and need to re-seat it.
As far as the activation, there is none. I know this for a fact. HOWEVER, Apple DOES keep a record of the serial number from the display and which System Serial it's supposed to be tied to. However, they only record it from the macs that come into their stores for work or repair. They do not record the data from the macs off the assembly lines. Just FYI
さんによる
コメントを追加
2件の回答
最も参考になった回答
Ouch! So while there is certainly the possibility that I am wrong (although in this case, I doubt it), it sounds like... you either:
4. didn't seat the cable properly and need to re-seat it. As far as the activation, there is none. I know this for a fact.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I have never heard of there being activation codes for Apple hardware installations. I recommend double checking the connections.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Dan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 14
今までの合計 1,414
