メインコンテンツにスキップ
My ipads wifi is greyed out but bluetooth still works?
hi there i have problem with my ipad 2 after screen replacement/ i think the wifi board has been damaged. what will i need to change to get this fixed? the whole wifi board or just a chip on it? and can you give me a link where i could buy it from thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
I would start by replacing the wi-fi/bluetooth antenna. Both antennas are part of the same component. They are EXTREMELY easy to damage during disassembly for replacing the digitizer or any other internal component. You can purchase the antenna here and then follow this guide.
Update
Yes, replacing the wi-fi board would be my next step. The only source that I've found for them is eBay.
Update
Yes, I believe that's the one you need.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
hi jousha, well i just have replaced the antenna but no luck, i think the wifi board needs replacing?
さんによる
コメントを追加
By iPhone 3g/gs (I hope that similar is on iPod) is important that the screw on mjute holder catches the flat cable to the frame of the phone to the antenna had grounding. If the screw is not well tight Wi-Fi will not work.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Yes I would try the wifi ant, make sure you don't buy the board. That is hidden and rarely is the cause of the problem. To replace the wifi it requires removing 4 screws and connecting the wifi into the area next to the board. Super easy!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I have replaced the wifi antenna on a1395 and still the wifi is greyed out and Bluetooth is not working as well. What should I do next??
さんによる
コメントを追加
回答を追加する
momomomo さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 6
今までの合計 1,909
