メインコンテンツにスキップ
2011年後期モデル番号A1278 / 2.4 GHz i5 or 2.8 GHz i7 プロセッサー
591回答 すべてを表示
Help to identify burned capacitor on mainboard
Hello
Looking at my father-in-Laws MacBook Pro unibody A1278 unibody. He accidently spilled cofee onto the keyboard.
The computer seems to run just fine now 1 month later, however the backlit on the keyboard is gone and many keys on the keyboard are not working correctly.
It is a 820-2936b board.
On the mainboard a single capacitor is burned, can you help me to identify it please:
I managed to find this picture showing the capacitor in your guides, but cannot read the text:
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Stokholm - That component is a SMD Capacitor not an IC.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Stokholm, that is reference designator C6603 and is a 100UF 20% 6.3V TANT capacitor. The case is a A L1 and something like this or on here should work. the capacitor is not part of your keyboard backlight, but of the Speaker Amp circuit. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
6 件のコメント:
Thank you very much for the detailed answer.
I will get the keyboard and capacitor replaced, thanks to you it is possible to install the correct one.
さんによる
Can I use a size B (3528) with the same specs instead of the size A (3216) - there is enough space on the board.
さんによる
It might be possible, but make sure that the cap will meet the solder pads on the board. If it does, you can most certainly use it. Thank you for accepting my answer and best of luck to you.
さんによる
I received a new keyboard and backlight, it all work very well now. I haven't replaced the cap yet, as I am still waiting for it to be delivered. Can it be dangerous to use it with the burned cap?
さんによる
Since it is already burned out your circuit already has failed, so that is no longer a danger. I would however replace it as soon as you can:-)
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Stokholm さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 909
