Hello,
I see this all the time, in short it is Back Light Bleed. This is where over time and a lot of use the backlight elements start to bleed, and the backlight is no longer even through out the display, therefor you see a slightly different shade over that part of the screen.
Now sadly this cannot be repaired and the only way to get rid of it is to replace the LCD. This guide shows you how to remove the display assembly from the MBP but I would go even further and strip down the assembly to replace the LCD it self.
There are a lot of LCD available on ebay at good prices.
Next the following site can provide you with the list of compatible LCDs from multiple manufactures, don't buy from them just find the part number and search on eBay, just enter your MBP serial number hit enter and then click parts when your model appears http://www.thebookyard.com
Please let me know how you get on and as always if you ever need any help just ask.
Cheers
Brendan Mills
If this Answer is helpful please remember to return and mark it Accepted.
