メインコンテンツにスキップ
13インチアルミ製Unibody, 2.0 or 2.4 GHz Core 2 デュオプロセッサモデルです。
574回答 すべてを表示
Display suddenly has pink hue?
This is an early 2009 MacBook Unibody. When using it recently, the display suddenly turned pink. All images and text are visible just with a pink/magenta hue that is uniform across the display. It is almost like the color balance settings were changed but I have confirmed they are normal. I tried resetting the PRAM and SMC with no change. I reseated the connector on the CPU side with no change. Connecting an external monitor (e.g. my TV) works perfectly so it seems to be isolated to the MacBook display. The computer otherwise functions normally. Talk on the internet suggests it may be a bad cable between the display and computer but wanted to gather suggestions here first. Thank you!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
ベストアンサー
Try connecting to an external monitor to see if it shows up there. If it does your GPU is having problems, if not your LCD display and/or the display cable is bad.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
As mentioned in my question, there are no issues on an external monitor. Colors are normal.
Is there anyway to tell if its the cable versus the display? Thanks
さんによる
コメントを追加
最も参考になった回答
It sounds like a problem with the display cable. You're going to need a new display cable. Apple only sells the display as an assembly.
Since Apple does not sell this as a individual part, you will have to either buy a used one that's tested to work or buy a damaged display assembly from eBay. If you have any local small businesses who do 3rd party Mac repair, they may have a damaged assembly with a good cable they are willing to give you for a few bucks, or even for free if they want it gone.
You can find a cable and guide here, along with the link to the full display assembly:
13" Unibody LVDS Display Cable
MacBook Unibody Model A1278 LVDS Display Cable Replacement
MacBook Unibody (Model No. A1278) Display Assembly
MacBook Unibody (A1278) Display Assemblyの画像
製品
$99.99
13" Unibody LVDS Display Cableの画像
製品
$34.99
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Did Apple have issues with this design? The Display Assembly was already replaced once under AppleCare in Dec. 2011 and this computer has seen LIGHT use the past 1.5 years.
さんによる
Nick - I won't say flawed, more a physical limit as no electrical harness could withstand constant flexing. Apples design is better than most, and more often than not most people don't flex there displays to the point of failure before they get a new system. Yes, a small group do, and it sounds like you and Zuren are in that group.
さんによる
コメントを追加
回答を追加する
zuren さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 10
今までの合計 32,863
