Display suddenly has pink hue?
This is an early 2009 MacBook Unibody. When using it recently, the display suddenly turned pink. All images and text are visible just with a pink/magenta hue that is uniform across the display. It is almost like the color balance settings were changed but I have confirmed they are normal. I tried resetting the PRAM and SMC with no change. I reseated the connector on the CPU side with no change. Connecting an external monitor (e.g. my TV) works perfectly so it seems to be isolated to the MacBook display. The computer otherwise functions normally. Talk on the internet suggests it may be a bad cable between the display and computer but wanted to gather suggestions here first. Thank you!
この質問は役に立ちましたか?
