メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
12インチディスプレイを搭載したPowerBook G4 Aluminumラップトップ。2003年にAppleから発売されました。
Why is the screen dim?
I just took it apart to remove a loose screw in the optical drive and now the screen is dim...did I disconnect something? I am also having trouble getting the keys back on (is it a coincidence that one of the keys I removed was the dimmer key and the other is the brightener key)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
4 件のコメント
are you saying that you cannot increase brightness because the key is not working?
さんによる
Thanks for the tips, I tried an external keyboard and proved that the problem is not the keyboard. I think I might have tweaked the display cable when I was putting the computer back together or maybe I mixed up some of the screws, could a too long or too short screw cause a problem?
さんによる
DEAR LEMERISE..THE screen is very dark...if I turn it at a particular angle I can see the icons,etc on the screen.
さんによる
12"...I've ordered a new display cable and when I get it i'll recheck all of my screws to make sure they are the right ones in the right places..thanks for your advise
さんによる
コメントを追加
5件の回答
ベストアンサー
You may go to the system preferences display preferences and check if you can modify the brightness from there. If yes then the keyboard has a problem. Try with an external USB keyboard.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
try turning up the brightness, also charge your battery, the screen dims when the battery lowers, you could try to check the display cable too.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
What is the PowerBook model (speed) ? 12"/15"/17" ?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
You still have video in the screen so the new display cable will not solve the problem. From your description it seems to be a lightning problem related to the inverter cable, inverter board or backlight. You say the screen is dim. Is it completely black or there's still light in it ?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If the long screw you are referring to pinches a cable it can cause problems.
only YOU can tell if you put it together properly - why not take it apart and check - that way you also can check if you damaged a wire by routing it incorrectly.
このアンサーは役に立ちましたか?
スコア -1
コメントを追加
回答を追加する
oliviachas さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 34
今までの合計 2,776
