メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2004年6月にAppleから発表された、20インチ、23インチ、30インチのアルミニウム製液晶ディスプレイ。モデル番号はそれぞれA1081、A1082、A1083です。
Flashing LED Fault Indicator
Hi,
I have a faulty 23" Apple Cinema HD Display that powers up but no video is shown. However, led power light flashes 3 times. Does the 3 flashes of the power LED indicate the nature of the fault as I can repair if I know what was wrong.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
4件の回答
ベストアンサー
So I've found a solution for this issue with the Short / Long / Short blinking sequence (aka "Make sure you are using the correct power adapter with the display").
I've found the solution on youtube: http://www.youtube.com/watch?v=aH5xgo1u3...
Basically, all you have to do is isolate the middle pins of the symmetric proprietary connector on the power adapter, using scotch tape. I just did it, it worked. Just make sure the pieces of scotch tape are really narrow and cover both middle pins and only these.
このアンサーは役に立ちましたか?
スコア 19
12 件のコメント:
Thank you so much!!!! <3
さんによる 共有
Totally worked. Thanks a ton!
さんによる 共有
I can’t believe such a simple fix works! Thank you.
さんによる 共有
Thanks. Really helpful.
さんによる 共有
I could not believe when I saw my Apple monitor display coming alive again, whoever shared the tip of covering the middle connectors is a genius, I am glad I did google first. In addition, this is saving me a trip to the Apple store.
さんによる 共有
7件以上のコメントを表示
コメントを追加
leematheruk, check first on what Apple suggest, watch for the blinking sequence :"short, short, short-->The display is detecting wrong video format or an unsupported resolution.
Verify that your equipment is compatible and restart the computer. If the issue continues, reset the PRAM.
short, long, short -->Make sure you are using the correct power adapter with the display. This alert will only appear on displays built in 2004 or later which require an external power adapter.
short, short, long -->The display is detecting a backlight error. Check your display's power connections and restart the computer. If the problem continues, contact Apple or an Apple Authorized Service Provider. this of course could be caused by failed components on the LCD circuit board. You will have to open it up and take a look at the board, check for burned/broken components. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 5
4 件のコメント:
ther is i youtub video a man from nicaruga show how to reparair tape the kontakt om the mail the is five pover in kontak bloch the mittel it ithe onvetor on the sreen bloch it and it woks ( for me in five month no problem
さんによる 共有
My display was accidentally unplugged from my laptop while on and now I have the short long short but i'm using the same power adapter that came with the display and i just plugged it back in. I've tried restarting etc but still short long short. Any suggestions?
さんによる 共有
Nevermind, i fixed it with the scotch tape jam, worked great!
さんによる 共有
the short short long indicates a power connection problem and Esger Jellema below solved it just take the connector on your power supply (the one that looks like a usb c type connection ) and unplug it ...and reverse the input 180 degrees and presto no more problem!
さんによる 共有
コメントを追加
I had the short short long flash and flipping my computer power plug 180° solved it for me.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Hi, when you say, "flipping your power supply" do you mean replacing it or something else? I have that same issue with on of my 24-inch cinema display....
さんによる 共有
been struggling to find out how to fix my 30in cinema from the short short long and WALAA! your fix did it just reversed the type c looking plug in to the power block and presto no more annoying flashes was worried that it was a failing backlight or component
Thanks so much for posting
Cheers!
さんによる 共有
コメントを追加
@davesherry I mean take the power plug out of the wall socket, turn it 180 degrees and put it back, so the live wire is on the other pin.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
That's not possible if your using a grounded plug ....ie three prong cord??
さんによる 共有
It is with European plugs.
さんによる 共有
コメントを追加
回答を追加する
leematheruk さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 33
過去 30 日: 108
今までの合計 40,262
