メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
How much maximum RAM does it take?
I was wondering how many slots are there and how much total maximum RAM it can take.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
5件の回答
ベストアンサー
There are two RAM slots that you can fill with 4 GB RAM chips for a total of 8 GB. In the these series:
Only this series of the 17" MacBook Pro support 16 GB MacBookPro8,3
The older 17" MacBook Pro's MacBookPro3,1 only supports 6 GB of RAM
Replace or upgrade the RAM in your desktop, laptop, or game console for faster performance. Low Profile / 204 pin / 1066 MHzの画像
製品
PC3-8500 4 GB RAM Chip
$27.99
このアンサーは役に立ちましたか?
スコア 5
コメントを追加
What happens if you try to install 16 GB of RAM in a model that only supports 8 GB?
I've seen before certain restrictions to be not true. Just wondering if that's just not 'recommended' instead of really not compatible. thanks!
This is the specs of my MacBook Pro:
  • Model Name: MacBook Pro
  • Model Identifier: MacBookPro5,2
  • Processor Name: Intel Core 2 Duo
  • Processor Speed: 2.66 GHz
  • Number of Processors: 1
  • Total Number of Cores: 2
  • L2 Cache: 6 MB
  • Memory: 8 GB
  • Bus Speed: 1.07 GHz
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Here is the series your system is part of: MacBookPro5,2
The limit of your system is what the PCH can address which sadly is only 8 GB in this series.
さんによる 共有
コメントを追加
You can install 16GB RAM in the 17" 2011 Macbook Pros if they have been updated to OS-X Mavericks (previously limited to 8GB max).
Here are the only 17" models that can support 16 GB: MacBookPro8,3
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
And have the latest EFI firmware!
さんによる 共有
Dan, Yes! forgot to mention that!! :)
さんによる 共有
Unfortunately, I wasn't able to do this. I have a mid-2010 15-inch MBP 6,2 with a 2.66 GHz i7, running the latest EFI firmware from Apple's official firmware page. The 16GB kit I installed (from Crucial, 2x8GB) either caused a kernel panic on bootup, a freeze on bootup, or would eventually cause sudden shutdown when more than 8GB was addressed after running normally for a little while. I've researched this for quite a bit, and I can't seem to resolve why some people have been able to get this to work, and others haven't. I'd appreciate any clues you might have!
さんによる 共有
You can now go up to 16GB with two 8 GB modules (very expensive) in the early 2011 models once you have updated the systems firmware.
さんによる 共有
You can install 2x8 Gb RAM, for a total of 16 Gb.
It's ok. The MBP works fine (and quick).
さんによる 共有
コメントを追加
My MacBook Pro is one of the MacBookPro5,2 series. I wasn't notified automatically about the EFI upgrade...
Although I upgraded to Maverick and I can see so much improvement...
I would DEFINITELY put more RAM tomorrow if i could...
I just can't know if mine will accept it or not... since the EFI hasn't been proposed by apple
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Here's the link to the Apple TN EFI & SMC firmware updates for Intel-based Macs Double check your system, it maybe you have the newest already.
さんによる 共有
And only the newer Unibody i5/i7 models can be upgraded to 16GB the older models can't. I would double check your system with Apple before you buy any modules. Do get a good name brand of module.
さんによる 共有
コメントを追加
Last 3 digits of mine are 8YA. Can anyone tell me how much I can install?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Plug in your systems serial number here: EveryMac - Lookup We can't use the last 3 digits any more to identify your system. Open the URL it offers up for your systems details and what it the RAM limit.
さんによる 共有
コメントを追加
回答を追加する
keshmir さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 34
今までの合計 16,655
