メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル番号A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5または3.4 GHz Core i7プロセッサ、ID iMac13,2
What RAM modules will it hold?
I have a new iMac on order and plan on installing extra RAM as soon as it arrives rather than paying for Apple's overpriced RAM. I see that many high-performace modules have heat sinks or heat dissipators on them. Is it likely these will fit into the new slimmer iMac body? Has anyone seen how much room is around the RAM slots? Or can it be estimated from the pictures available?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
7件の回答
最も参考になった回答
It's PC3-12800 RAM, 200 Pin DIMM cards. So it's laptop ram, not desktop. Pretty standard RAM once you get to it.
Check your model number to see what is available per slot. There are two slots. Use everymac.com for help.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
http://support.apple.com/kb/HT5523
This lists the specifications that the RAM must comply with to be compatible.
http://support.apple.com/kb/HT5540?viewl...
This shows the procedure to upgrade the RAM.
The 27" and the 21.5" iMacs are different in that the 27" has a dedicated RAM compartment, accessible from the rear WITHOUT tearing open the screen.
Hope this helps!
EDIT: To find out what RAM your computer will work with go to http://www.crucial.com/uk/systemscanner/
and download the tiny application (Windows or Mac).
After it's run it will send you to a webpage with an analysis of your computer and links to buy compatible RAM.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Nobody posted just how easy this upgrade is:
iMac Intel 27インチ EMC 2546 RAMの交換
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
" I see that many high-performace modules have heat sinks or heat dissipators on them. Is it likely these will fit into the new slimmer "
They will not fit nor are they necessary as they are adequately cooled by design.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
For installing or replacing memory iMac (27-inch, Late 2012):
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Wes - Your just duplicating what Oliver offered above. The bester thing here would be to up Olivers' score as being the best answer
さんによる
コメントを追加
From the question "I see that many high-performance modules have heat sinks or heat dissipators on them."
Keep in mind that iMac's use SODIMM memory (often referred to as Laptop) for at least the last 10 years. The high performance modules you are referring to are desktop PC memory.
Also starting with 2012 models the 21" iMac is does not have a memory access plate. To not void your warranty you would need to take the 21" unit to an authorized service center or to apple to upgrade a 21" memory. The 27" iMac still has the access plate and is therefore user upgradable.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
While Apple uses Laptop over Desktop memory they often meet or beat the same desktop spec'ed systems. mmm... no real difference ;-}
さんによる
コメントを追加
If you ordered 21.5" new iMac, unfortunately you would hardly be able to upgrade RAM that it will take 1600MHz DDR3 memory. I don't mean you can't but it's a big task. The new iMacs don't have Memory Room on the bottom of the housing that you could have an easy access with a screwdriver. Now that Apple has gone farther towards thinner framework, the memory resides inside the housing making it difficult to play with. You have to use heat-gun to pry-up the front glass just to access the memory. The LCD and glass are infused together. Boy, you have a lot of work ahead. If you broke the glass while prying, you have no idea what costs you are inviting in. It's frustrating. Here's the teardown that may help you locate and decide if you wanna do it.
このアンサーは役に立ちましたか?
スコア -1
コメントを追加
回答を追加する
nevilleward さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 23
今までの合計 4,855
