How to remove dash panel to replace Radio
Trying 2replace the cd deck. Dash seems simple to remove but the trim panel wraps round the ignition hole. How do I remove the panel without damaging it?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Dee brown, check on here for a broken down service manual. the instrument cluster removal is described in the "BO" file. Hope this helps, good luck
このアンサーは役に立ちましたか?
That was exactly what I needed. Truly, truly, appreciate it. Got a few other things 2do on this car as well & this has all the answers. Thank u, oldturkey03. Ur a scholar & a gentleman
you are welcome :-)
hey I have the same problem. what do you do to unlock the clips
過去 24時間: 0
過去 7 日: 1
過去 30 日: 12
今までの合計 7,191
