学生によって寄稿されたWiki
iFixit学生教育プログラムに参加している素晴らしい学生チームが、このWikiを作成しました。
HP 15-g029wm Troubleshooting
This HP Laptop was released around 2013 and uses Windows 8.1.
Laptop Not Charging
The laptop is connected to power, but not charging.
Not Using an Original or Certified Charger
Check the serial number of the Cord and Adapter. Both should match up to these:
AC Cord: 490371-001
Adapter: 741727-001
If the above serial numbers do not match, it is recommended that a replacement charger be ordered from an Authorized Parts Retailer.
The AC Adapter has Physical Damage
The AC adapter is a part of the charger which plugs into the laptop. Take this part and carefully visually inspect it to determine if the brick at the end has any damage.
The portion of the brick that connects to the DC adapter may have had its prongs bent or broken off. If that section appears fine, the part that plugs into the laptop may be bent.
A tell-tale obvious sign of a faulty charger is melted or misshapen plastic along any part of the charging cord and brick. The brick should be rectangular with smooth edges.
If damage is found please contact HP for a replacement part or click here.
The DC Adapter and Connector have Physical Damage
The DC adapter is a part of the charger which plugs into the wall. Take this piece and see if the electrical plug prongs are bent or missing.
On the other end, there will also be an electrical connector that connects to one side of the brick AC adapter.
If the plastic on there is melted or damaged. CAUTION: DO NOT PLUG IN. Contact HP for a replacement part or click here.
Cord Fraying
If you notice the cord of the laptop has exposed wiring or cuts into the plastic stop use.
This is most common in two areas the part that plugs into the laptop itself and then the wall plug area.
If there is notable physical damage contact HP for a replacement part or find a replacement part here directly from HP.
Obstruction in Power Port
If you notice debris in your laptop's power port, use compressed air to remove any debris.
Hold the canister upright; otherwise, you may get water in the port causing water damage.
If this doesn’t work take a toothpick or a dental pick and gently use it to scrape out any debris. AVOID USING metal tools for this procedure.
Overheated Laptop/Battery
Check the laptop bottom and side air exhaust vents for debris. Carefully clear it out by using compressed air, then a microfiber cloth. This can be done by following this video tutorial.
Then, verify you are using a manufacturer (HP) certified/original charger.
[AC Co rd: 490371-001 & Adapter: 741727-001]
The battery is dead
A battery replacement is necessary and you need to purchase it from HP directly by clicking here.
For a detailed guide on how to replace the device battery click here.
Laptop Overheating
This is a hardware failure causing an overheating condition of the laptop. This may appear as a distorted display, physically very hot laptop, or uncommon loud screeching/grinding sounds.
Obstruction of Ventilation Vents
Check the laptop's vents for debris and clear it out by flipping the laptop over, bottom side up.
Next, check the vents in the middle and on the side for debris. If debris is found, then remove it with Compressed air, a toothpick, a microfiber towel, or other tools.
AVOID using metal tools. They may cause damage to your device.
Foreign Material Obstructing the Cooling Fan
Check the condition of the cooling fan by following the cooling fan replacement guide, to open the bottom of the device to reach the cooling fan. Do not remove the cooling flan to clean it unless you're having trouble doing so.
If there is debris stopping the fan from moving, remove it carefully with Compressed air, a toothpick, a microfiber towel, or other practical tools available to you.
Failing Cooling Fan
Replace the cooling fan if it is not operating properly by following this guide.
Unresponsive Screen
The display screen does not power on or respond to input.
Faulty or Loose Power Source
Inspect and secure the power supply to the screen by following the battery replacement guide.
If there is a problem with the screen specifically, it may have to do with the cords. You can replace the screen following this guide.
If you need to fix the cords connected to the screen you can follow this guide to remove the screen, but you will need to replace the cords on your own. It may be easier to replace the screen with a new one or take it to a business to fix the cords.
If you have no experience with fixing a screen's connecting cords, then you will need to locate a tutorial elsewhere. iFixit may have a guide on their site.
Software BIOS Corrupted
Verify BIOS is operating correctly through diagnostic troubleshooting by following this guide.
Dirty Display
Carefully clean the display screen of any grime by using a microfiber cloth on the screen.
If there is debris inside the computer follow this guide to gain access to the device's inner workings and components.
Damaged Display
If the screen is cracked or otherwise damaged, replace it by following this guide. The parts can be found [here: 15.6-inch diagonal HD BrightView LED-backlit display (1366x768).
Computer Freezes
The laptop randomly crashes, or the system frequently stops responding when in use.
Unstable Power Supply that Leads to Memory Errors
Check the power supply on the left side of the laptop, ensure the laptop is properly connected, and check the battery is working correctly.
Laptop is Overheating
Ensure air circulation in the room is good.
Visually inspect the hot air exhaust vents located on the bottom and sides of the laptop.
Ensure that the exhaust fan vent is not obstructed. If you notice debris in the laptop vents or fan, clear it by spraying compressed air at an angle into the vents/fan until debris is cleared.
If needed, gently and carefully use a microfiber towel, toothpick, or other slim tool to loosen debris. This may look like dirt or dust in the vent or fan.
Lastly, visually inspect and clean the CPU by following this guide to gain access to the device's inner workings/components to prevent it from becoming clogged with dust and other particles. Carry out the same procedure for the exhaust fan.
Insufficient Storage/Memory is Full
Firstly, free up space on the hard drive.
If that fails, install a new or higher capacity RAM to the laptop by following this guide.
Replacement parts can be found here.
Random Shutdowns
The laptop may immediately shut down when rebooting or shuts off while in use.
Computer Overheating due to Dirty/Damaged Fan
Clean bottom and side air exhaust vents by carefully removing debris with compressed, a toothpick, a microfiber towel, or other tools. Do not use metal tools for this.
You can do this by lubricating the computer fan with dry graphite. Follow this video tutorial for a visual walkthrough of the process.
Replace your device's cooling fan by following this guide.
Faulty/Damaged Battery
Replace your device's Battery by following this guide.
Out-of-date system BIOS
Update laptop System BIOS here.
Damaged Motherboard
Replace the Motherboard by following this guide.
0 件のコメント
