メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのMac mini Late 2012を修理する際は、iFixitの修理ガイドをご利用ください。
  1. Mac mini Late 2012 Teardown, Mac mini Late 2012 Teardown: 手順 1、 1の画像 1
    • Good things come in mini packages. This mini is packing:
    • 2.5 GHz dual-core Intel Core i5 or 2.3 GHz quad-core Intel Core i7
    • 500 GB hard drive or 1 TB hard drive configurable to a 1 TB Fusion Drive or 256 GB solid-state drive—upgradable with an extra hard drive or SSD using our dual hard drive kit
    • 4 GB, 8 GB, or 16 GB of DDR3 SDRAM
    • Intel HD Graphics 4000
    • Thunderbolt and HDMI ports
    • SDXC card slot
    • This mini lacks an optical drive, just like its predecessor.
    10 years later and we still don’t have the mini mini.
    Duck - 返信
  2. Mac mini Late 2012 Teardown: 手順 2、 2の画像 1 Mac mini Late 2012 Teardown: 手順 2、 2の画像 2
    • It's beginning to feel like Groundhog Day. The same model number (A1347) has graced the 2011 and 2010 minis.
    • The port layout is consistent with last year's model:
    • 10/100/1000BASE-T Ethernet
    • FireWire 800
    • HDMI (HDMI to DVI adapter included)
    • Thunderbolt (supports high-speed I/O and Mini DisplayPort)
    • Four USB 3.0 ports (an upgrade from last year's 2.0)
    • SDXC card reader
  3. Mac mini Late 2012 Teardown: 手順 3、 3の画像 1 Mac mini Late 2012 Teardown: 手順 3、 3の画像 2 Mac mini Late 2012 Teardown: 手順 3、 3の画像 3
    • Twist and shout!
    • A simple twist of the bottom cover and we're in. That is plus one for repairability.
    • Upgradeable RAM!! Oh, how we've missed you!
    • The 2012 iteration of the Mac mini is equipped with PC3-12800 DDR3 RAM.
    • It's refreshing to see an Apple product with user replaceable/upgradeable RAM.
    Macbooks and iMacs are always easy to upgrade for memory..
    Theun Evers - 返信
    hahaha the link to twist and shout is really funny! i loved that
    Simon Dengler - 返信
  4. Mac mini Late 2012 Teardown: 手順 4、 3の画像 1 Mac mini Late 2012 Teardown: 手順 4、 3の画像 2 Mac mini Late 2012 Teardown: 手順 4、 3の画像 3
    • We're fans of easily removable fans.
    • Easily accessible fans mean soot sprites better run for cover, because cleaning dirty fans is no problem.
    • Need to clean your fan? Directions can be found here.
    Why exactly are you fans of "upgradable fans"? Is there a need or benefit to "upgrading" the Mac mini fan. Isn't the included fan more than sufficient to the task?
    ktbeatty - 返信
  5. Mac mini Late 2012 Teardown: 手順 5、 2の画像 1 Mac mini Late 2012 Teardown: 手順 5、 2の画像 2
    • We remove the fan cowling, eager to get at the Wi-Fi antenna plate.
    • We are really starting to suspect that Dr. Emmett Brown had something to do with this mini as the antenna board and grille look identical to the last two renditions.
  6. Mac mini Late 2012 Teardown: 手順 6、 2の画像 1 Mac mini Late 2012 Teardown: 手順 6、 2の画像 2
    この手順で使用する道具:
    Mac mini Logic Board Removal Tool
    購入する
    • Here we find the legendary Mac mini logic board removal tool in its natural habitat.
    • Note the ease of use as the tool swoops in to release the logic board of the mini.
    You might want to perhaps mention that you cannot fully remove the logic board until you unplug the cable underneath… People need to know that they can only fly the logic board out about a quarter to a half an inch and then need to unplug the cable connecting to the machine.
    Eric Hemingway - 返信
    Hey Eric,
    Thanks for the tip! As mentioned above, this is this teardown is an educational first look at the device, and is not meant to be used as a guide. Our actual Mac mini guides have much more detailed instructions for properly completing repairs.
    Arthur Shi -
    Some years ago, I managed to remove the Logic Board from the case without the removal tool. I find it difficult to do the same now. But I can't wait days for delivery of the tools. Alternate method should be demonstrated.
    Ivan - 返信
  7. Mac mini Late 2012 Teardown: 手順 7、 3の画像 1 Mac mini Late 2012 Teardown: 手順 7、 3の画像 2 Mac mini Late 2012 Teardown: 手順 7、 3の画像 3
    • The first component off the logic board assembly is the speaker assembly.
    • The speaker cable was arranged in a twisted pair, probably to reduce EMI that could distort the sweet, iconic tones of the Apple startup sound.
  8. Mac mini Late 2012 Teardown: 手順 8、 3の画像 1 Mac mini Late 2012 Teardown: 手順 8、 3の画像 2 Mac mini Late 2012 Teardown: 手順 8、 3の画像 3
    • The Wi-Fi board, labeled BCM94331PCIEBT3B, stands no chance against our spudger as we make it truly wireless.
    • Removing the EMI shields allows us to peek at the ICs on the communications board:
    • Broadcom BCM4331 802.11 a/b/g/n Wi-Fi chip
    • Broadcom BCM20702 Bluetooth 4.0 transmitter
    • SiGe 5503A 2304A Dual Band 802.11a/b/g/n Wireless LAN Front End
    • SiGe 2598L
    • P2303A TUB2P
    • 7871 1228 C6050
    SiGe 2598L - SE2598L 2.4 GHz Power Amplifier with Power Detector
    hardegor - 返信
    Which antenna is for the bluetooth? J0, J1, or J2?
    Dondy Razon - 返信
  9. Mac mini Late 2012 Teardown: 手順 9、 2の画像 1 Mac mini Late 2012 Teardown: 手順 9、 2の画像 2
    • The heat sink is next to go.
    • Apple has really keyed in on their boomerang-style heat sink abilities—and for that, we applaud them. We know boomerangs can be tough to master.
    • Similar, again! We have not tried installing old 2011 mini parts in the 2012 mini, but we are certainly not ruling out the possibility!
  10. Mac mini Late 2012 Teardown: 手順 10、 3の画像 1 Mac mini Late 2012 Teardown: 手順 10、 3の画像 2 Mac mini Late 2012 Teardown: 手順 10、 3の画像 3
    • A series of screws and tightly wrapped antenna cables secure the rear I/O panel shield to the logic board.
    • A few twists of our precision aluminum driver with a T6 Torx bit and some cable de-routing is all it takes to remove the shield.
  11. Mac mini Late 2012 Teardown: 手順 11、 1の画像 1
    • Some mini players on the top of the not-so-mini logic board:
    • Cirrus Logic 4206B Audio Controller
    • SMSC USB2512B USB Hub Controller
    • Broadcom BCM57765 gigabit ethernet and memory card controller
    • Intel L232TB45 Thunderbolt Port Controller
    • LSI L-FW643E-2
    • DELTA 8904C-F Filter
    Hi everybody :)
    Does anybody knows the exact specs of the L232TB45 TB controller?`
    Thx beforhand
    Killy
    Killy - 返信
    Are you sure that the late 2012 Mac Mini comes stock with a SMSC USB2512B USB Hub Controller? I looked it up and this is a USB 2.0 High Speed Hub Controller. How is this possible when the 2012 Mini has USB 3.0 ports, and 3.0 devices read out as having a speed of 5Gb/s (from Mac's System Profile) when connected to the Mini's USB ports.
    Ricardo Ayala - 返信
  12. Mac mini Late 2012 Teardown: 手順 12、 1の画像 1
    • The rear side of the logic board:
    • Intel HM77 (SLJ8C) platform controller hub
    • Intel V227C254 2.5 GHz dual-core i5
    • SMSC 1428-7 system management bus temperature sensor
    • Parade PS8401A HDMI/DVI level shifter
    • LM4FS1AH
    Hello,
    Intel E224B809 platform controller hub
    are not comercial names, what are the comercial names of that Intel chipset and Intel processor?
    Regards
    nickeditor - 返信
    The Mac Mini uses somewhat custom parts, they don't have direct counterparts in Intel's main OEM and retail lines.
    Rich Mingin -
    If you wanted to know what is kind of close, the CPU is very similar to, but not identical to a i5-3210M.
    The chipset is much harder to classify, since it doesn't have a lot distinctive features to differentiate it. It's probably similar to the Mobile Intel® HM76 Express Chipset (Intel® BD82HM76 PCH).
    Rich Mingin -
    Does anyone know what the connector is for located about 1.5 inches below the processor and platform controller hub? It's also present on the 2011 version but not used.
    Paul - 返信
  13. Mac mini Late 2012 Teardown: 手順 13、 2の画像 1 Mac mini Late 2012 Teardown: 手順 13、 2の画像 2
    • Tucked away neatly near the rear of the mini is the hard drive.
    • Our model came with a 500 GB Hitachi hard drive.
    • The mini is one of the Macs launched with the Fusion Drive.
    • Apple's Fusion Drive is not to be confused with the Impulse Fusion Drive of Star Trek.
    Wheres the ssd?It that a non fusion drive model, or it is build into the hard drive?
    Honam1021 - 返信
    Can you verify the data rate of the I/O is it SATA-3?
    Dan - 返信
    Based on the spec of Mac mini 2012, looks like 500GB is not fusion drive, I think.
    http://store.apple.com/us/browse/home/sh...
    Liang Qi - 返信
    What is the maximum hard drive height if one is looking for a replacement? I see the drive you have is 7mm, but is there any wiggle room to go higher?
    Jerad - 返信
    MacRumors: Apple's New Fusion Drive Works on Older Macs
    http://www.macrumors.com/2012/10/31/appl...
    Liang Qi - 返信
  14. Mac mini Late 2012 Teardown: 手順 14、 3の画像 1 Mac mini Late 2012 Teardown: 手順 14、 3の画像 2 Mac mini Late 2012 Teardown: 手順 14、 3の画像 3
    • Next up, we displace the power of the mini.
    • It is beginning to feel repetitive to say how repetitive Apple is in the design of the mini; nonetheless, the power supply appears identical to last year's model.
    • In this case, we have to say that repetition is a good thing, as the mini continues to be one of the most repairable devices that Apple produces.
    • Just like last year, the power supply provides 85 watts to the Mac mini—that's the same kind of electric juice as the AC adapter for a 15" or 17" MacBook Pro.
    We can clearly see this is an international PSU. Switching power supply, 110-240V, meaning it can be used in Norway, UK as well as USA. Using the proper cord of course, which is so different.
    amazonborga - 返信
    So, are you saying I might be able to run one of these things off a macbook pro battery? I might have a bad battery and want to test.
    Nathan Morris - 返信
  15. Mac mini Late 2012 Teardown: 手順 15、 3の画像 1 Mac mini Late 2012 Teardown: 手順 15、 3の画像 2 Mac mini Late 2012 Teardown: 手順 15、 3の画像 3
    • We were especially curious to see if this new Mac mini is still compatible with our dual hard drive upgrade kit, so we got to testing it!
    • Following along with our own guide for the 2011 model was a snap, and everything fit perfectly.
    • After a quick reassembly, we booted this guy up for the first time—with 50% extra storage. Success!
  16. Mac mini Late 2012 Teardown: 手順 16、 2の画像 1 Mac mini Late 2012 Teardown: 手順 16、 2の画像 2
    • Mac mini Mid 2012 Repairability: 8 out of 10 (10 is easiest to repair).
    • No proprietary screws are found within the device.
    • You can easily upgrade your RAM and hard drive, as well as add a secondary drive.
    • There's no glue anywhere inside that needs to be removed while disassembling the mini.
    • The CPU is soldered to the logic board and not user-upgradeable.
    • While not difficult to do, you still have to remove almost all the internals in order to replace the power supply.
    2012, not 2011
    "Mac Mini Mid 2011 Repairability: 8 out of 10"
    Paul - 返信
16 件のコメント
Hello,
I see that Mac mini Late 2012 have a Hitachi HTS545050A7E362 HDD
What kind of SATA connection have that Hitachi HDD?
And what kind of SATA connection have Mac mini Late 2012? SATA II or SATA III?
Regards
nickeditor - 返信
Can you add in an SSD with your dual drive kit to see if Fusion turns on somehow?
Below - 返信
Can you confirm that you can add a second hard drive if you choose the fusion drive option? I believe Apple have used that extra space in the mac mini to pack in the 128GB SSD for the fusion drive.
Roy - 返信
when reinstalling the heatsink did you notice the heatsink does not 100% connect to the platform hub?
even when screwed down tight and new thermal paste applied there is still a paper thin gap between heatsink and platform controller hub
can anyone else confirm this???
thanks
kevin
beanieboy182@hotmail.com
kevin - 返信
I noticed this too
Victor -
Thank you very much for all the outstanding articles. I am trying to get a very neat and clean HTPC and I wander if the Mac Mini 2012 logical board and ac adapter will fit in the Mac Mini 2010 case in order to have Core i5 or Core i7 with an optical drive.
miyoshis - 返信
I don't have audio output from headphone jack but ok using usb headphone
Daniel Bellard - 返信
Hi, I was wondering what your licensing policies are for your images, I am interested in embedding one of your images onto my website in the future. Is there an embed option? If not, how much would I have to pay per image?
Richie Zhang - 返信
anybody know about s/n CO7JFACFDWM, its 4gb ram
michael costa - 返信
Hi anyone know how to take the VGC out as mine has stopped working and want to try a possible fix. Thanks! (Mac mini 2012)
Karl johnson - 返信
Hi, i just came over this teardown, great job! does anyone know what this port is used for? https://d3nevzfk7ii3be.cloudfront.net/ig... you see it in the middle, there is a little connector, im just wondering for what this port is.
Marco - 返信
The second HD has separate connector?
massimo.cata2012 - 返信
Will it support NVMe SSD? I mean I see now in Catalina for NVMExpress section: “This computer doesn't contain any NVMExpress devices. If you installed NVMExpress devices, make sure they are connected properly and power on.” Am I correct that instead of SATA SSD I may install there NVMe SSD?
Thanks in advance!
Mike Also - 返信
I miss the Temperature sensors in this setup … any hint where I could find more information on those ?
My mini is running hot. Hot enough to shut down instead of spinning up the fan. SMCFan Controls helps as a workaround.
Darko IVANCAN - 返信
Hi There I was wondering if I could pick someone's brains on something. I just bought a really cheap Mac Mini late 2012. All is working which is quite a finding. I decided to open the little beast to change its HD from a spinning one to an SSD and I found some mangled pieces inside. This little Mac has probably had a really bad drop in the past and it was seriously messed about. Still, all vital parts seem intact, and the machine is working. However, When I was changing the HD I noticed a loose wire.... Looking at pics on this site, I think that the loose wire belongs to the IR connector which is - I think, broken. Since I plan not to use the IR sensor, it will not affect the workflow in any way. The thing is, if I post a pic, can anyone confirm that the loose wire is IN FACT from a broken IR connector? Many many thanks for your help
Miguel Ribeiro - 返信
コメントを追加
統計データ:
過去 24時間: 16
過去 7 日: 149
過去 30 日: 654
今までの合計 403,612
