メインコンテンツにスキップ
« 全てのストーリーへ戻る
The Missing Hard Drive
stephenjoly99 -
MacBook Pro 13" Unibody Early 2011
ストーリー画像
  • 画像番号1
  • 画像番号2
  • 画像番号3
MacBook Pro 13" Unibody Early 2011 Hard Drive Cable Replacement
25分 - 1時間
Moderate
問題
The problem was that my hard drive was not visible anymore. It wasn't booting properly so I booted to my second HD and it wasn't reading my primary HD (my SSD). Because of this I took it to the apple store to see what they though, took it to canada computers and replaced the SSD and then I saw on the apple support forums that replacing the HD cable fixes the problem.
修理
So I took to the internet where I found iFixIt and bought the cable from there and managed to fix the problem. The procedure was very easy and my problem was solved. The only hard part was to move my primary SSD from the optical drive caddy back to the primary bay. That took some time.
アドバイス
The entire thing was actually very simple, like I mentioned, but I would only recommend doing this is you are 100% sure that the HD cable is the problem. Try to reformat your drives and switch bays to be sure.
MacBook Pro 13" Unibody (Early 2011-Late 2011) Hard Drive Cableの画像
$34.99
« 全てのストーリーへ戻る
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 78
