メインコンテンツにスキップ
« 全てのストーリーへ戻る
Bulging corners
dienerd -
MacBook Core 2 Duo
ストーリー画像
  • 画像番号1
  • 画像番号2
MacBook Core 2 Duo Inverter Replacement
2時間
Difficult
問題
The display on my wife's old MacBook would darken to a black screen at the worst possible moment. The iFixit site helped me figure out it was the Display Inverter. I ordered the parts but didn't get to the task until three months later.
修理
At first I felt a bit intimidated by the nearly 50 steps for tear-down, but I dove in with confidence. An ice cube tray held the little screws I removed and kept them in order. After two hours, the MacBook was running once again. Now that I've used it for the past month, the symptoms are gone. But, two minor problems remain. (1) the back side of the hinge now has bulging corners (see images) - a reassembly error, and (2) when the angle of the display gets to about 80°, it goes to sleep - the internal switch that triggers display sleep is probably just a bit out of position. The repair was a success.
アドバイス
I would have appreciated a "heads-up" with the addition of a comment in the directions when the hinge is removed regarding its reassembly. How do you avoid bulging corners?
Spudgerの画像
Spudger
$3.99
Plastic Cardsの画像
Plastic Cards
$2.99
MacBook Display Inverterの画像
$14.99
« 全てのストーリーへ戻る
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 16
今までの合計 113
