メインコンテンツにスキップ
« 全てのストーリーへ戻る
Samsung Galaxy Note 3 - Charging Assembly Replacement
Angie Willmorth -
ストーリー画像
Samsung Galaxy Note 3 Motherboard Replacement
15分
Easy
問題
The USB port was damaged after years of use
修理
The repair was straight forward and went well.
アドバイス
The link for the replacing the charging assembly is for removing the motherboard. Replacing the charging assembly does not require removal of the motherboard.
Here is what I did. Using the instructions for removing the mother board stop after step 6, "Removing the Back Chassis". Then you undo the antenna clip at the USB assembly side only, and disconnect the two cables on the USB assembly that connect it to the motherboard. Then as per your instructions in the tear down “Use spudger to remove the USB board with proper strength because the USB board is stuck with glue.”
Galaxy Note 3 (T-Mobile) Charging Assemblyの画像
$24.99
« 全てのストーリーへ戻る
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 366
