メインコンテンツにスキップ
« 全てのストーリーへ戻る
Back in Business!
Ronald Mitchum -
iPhone 5c
ストーリー画像
iPhone 5c Battery Replacement
10分
Moderate
問題
The battery that I bought from New Egg was crap
修理
Went great, Great kit, everything included. Did it before with another kit which was not as good.
アドバイス
If you do not take off the screen, just make sure it is supported at a bit less than 90 degrees, so you can use both hands. Small screws on the battery hold down, the magnetic drivers in the kit work very well. In the previous replacement I had trouble getting the OEM battery out, the tabs broke off, so just take a heat gun or hair dryer on low and carefully heat the underneath of the case a bit, if it feels hot it is too hot, heat only the battery side, the battery will start to give way using one of the kit tools, take a lot of time to do this maybe 10 minutes off and on. I work under a magnifying light.
iPhone 5c Batteryの画像
iPhone 5c Battery
$29.99
« 全てのストーリーへ戻る
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 115
