メインコンテンツにスキップ
« 全てのストーリーへ戻る
Fan Replacement
ctjewett -
MacBook Air 11" Mid 2011
ストーリー画像
MacBook Air 11" Mid 2011 Fan Replacement
15分
Moderate
問題
Old fan was making all sorts of noise. I didn't even realize my Mac had a fan for years until this fan started to go, and then it was obvious as a blue sky.
修理
Overall, it was a pretty easy repair, but a tad trickier than a standard PC laptop due to the tight tolerances and incredibly small parts. If you can put the Mac in a shallow box so no screws get lost in the process, it'll probably help considerably.
アドバイス
The only super tricky part was sliding the new fan's ribbon cable into the slot. I used the spudger and pushed on the only small crease I could find to slide it into the slot. I suggest powering it on while still apart to verify functionality, then power it off and finish stitching everything back together.
MacBook Air 11" (Mid 2011-Early 2015) Fanの画像
$19.99
« 全てのストーリーへ戻る
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 4
今までの合計 128
