メインコンテンツにスキップ
« 全てのストーリーへ戻る
iPad Mini 2 Digitizer Repair
Fred L Terry -
iPad Mini Wi-Fi
ストーリー画像
iPad Mini Wi-Fi Front Panel Assembly Replacement
2時間
Difficult
問題
My daughter's iPad Mini 2 had a cracked digitizer panel. The Al case had some been visibly bent causing stress on the digitizer. It was still working, but causing too much distress.
修理
The repair went slowly, but well. The longest part was removing the old digitizer. Once I had it fully disassembled, I was able to bend the Al frame back into near normal. My repair was successful and my daughter was very happy.
アドバイス
The instructions do not say anything about cleaning off the residual adhesive from the frame. I did this carefully and use ethyl rubbing alcohol to loosen the remaining material. Including treated cleaning pads in the kit would be a plus. Also, the recommended procedure for removing the tape from the LCD panel could be improved. I am a EE professor and a pretty good Mr Fixit. I would rate this as a repair only for those with good nerves, decent skill, and patience. I really is not that bad, but the key is to take your time and follow the instructions carefully. Trying to rush this job would lead to disaster. Be sure your work surface is clean and clear. I used a clean towel to ensure that if I dropped a small part (especially the little screws), that it would not bounce away and get lost. Those with older eyes may want light magnifying googles to focus on the smaller pieces.
iPad mini 1/2 Screen Digitizerの画像
$34.99
« 全てのストーリーへ戻る
2 件のコメント
Durepair.com - We do Cell Phone Repair, Computer Repair, Samsung Repair, Cell Phone Unlocking.
patrick_bruen - 返信 共有
Its great to hear that you were able to figure out the repair on your own, and thanks for the recommendation for our future guides re: the cleaning products!
Alexander Lewis - 返信 共有
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 8
今までの合計 233
