メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iView-776TPCII Motherboard Replacement
必要な工具と部品
    1. iView-776TPCII Motherboard Replacement, Rear Panel: 手順 1、 3の画像 1 iView-776TPCII Motherboard Replacement, Rear Panel: 手順 1、 3の画像 2 iView-776TPCII Motherboard Replacement, Rear Panel: 手順 1、 3の画像 3
      • Before disassembling your device, make sure that the power is completely turned off.
      • Use the plastic opening tool to release the clips holding the rear panel of the device onto the front section.
      • The clips may take some pressure before releasing.
      • Continue around the entire device until all of the clips have been released.
      FixBotに聞いてみる
      コメントを追加
    2. iView-776TPCII Motherboard Replacement: 手順 2、 2の画像 1 iView-776TPCII Motherboard Replacement: 手順 2、 2の画像 2
      • Use a spudger to carefully free the speaker from it's housing on the back panel.
      • Place the spudger between the speaker and the rear panel. Use a prying motion to remove the component.
      • Be careful not to apply an over amount of force. If care is not taken, the speaker could break under the pressure.
      FixBotに聞いてみる
      コメントを追加
    1. iView-776TPCII Motherboard Replacement, Battery: 手順 3、 1の画像 1
      • Insert the flat side of the standard spudger underneath the battery and use a prying action to loosen the glue holding it to the digitizer.
      • Do this all around the battery until it comes off.
      • The glue is strong, so some force may be required. However, be careful not to apply so much pressure that the battery bends or breaks.
      • At this point, do not attempt to fully remove the battery, since it is still connected to the motherboard.
      FixBotに聞いてみる
      コメントを追加
    2. iView-776TPCII Motherboard Replacement: 手順 4、 1の画像 1
      この手順で使用する道具:
      • Use the Portable Soldering Iron tool to heat the leads coming from the battery to the motherboard, thereby breaking the connection.
      • For help on soldering, refer to the iFixit "How To Solder and Desolder Connections" technique guide as necessary.
      • Once heated, use tweezers to pull the wires free from their connections.
      • To ease reassembly, take note of which wire went to the positive and negative terminals.
      FixBotに聞いてみる
      コメントを追加
    1. iView-776TPCII Motherboard Replacement, Wi-Fi Antenna: 手順 5、 2の画像 1 iView-776TPCII Motherboard Replacement, Wi-Fi Antenna: 手順 5、 2の画像 2
      • Detach the end of the Wi-Fi antenna from the tape on the edge of the shell.
      FixBotに聞いてみる
      コメントを追加
    2. iView-776TPCII Motherboard Replacement: 手順 6、 1の画像 1
      この手順で使用する道具:
      • Use the Portable Soldering Iron tool to heat the lead coming from the Wi-Fi antenna to the logic board, thereby breaking the connection.
      • Once heated, use tweezers to pull the wire free from its connection.
      FixBotに聞いてみる
      コメントを追加
    1. iView-776TPCII Motherboard Replacement, Camera Assembly: 手順 7、 2の画像 1 iView-776TPCII Motherboard Replacement, Camera Assembly: 手順 7、 2の画像 2
      この手順で使用する道具:
      Heavy-Duty Spudger
      • The camera module is located in the upper-right corner of the tablet.
      • Loosen the edges of the black tape covering the camera using the heavy-duty spudger.
      • Use the freed edges of the tape to gently remove the camera assembly from its plastic housing.
      • The camera assembly will still be connected to the rest of the device via a ribbon cable. Take care so as not to tear this connection.
      FixBotに聞いてみる
      コメントを追加
    2. iView-776TPCII Motherboard Replacement: 手順 8、 2の画像 1 iView-776TPCII Motherboard Replacement: 手順 8、 2の画像 2
      この手順で使用する道具:
      • Use tweezers to lift the cover off the top of the camera's ZIF adapter.
      • When reassembling the device, be sure to fully secure the ribbon cable from the camera back into the ZIF adapter.
      • Pull the assembly away from the motherboard with a set of tweezers to prepare for desoldering.
      FixBotに聞いてみる
      コメントを追加
    3. iView-776TPCII Motherboard Replacement: 手順 9、 1の画像 1
      • Use the Portable Soldering Iron tool to heat the leads coming from the camera assembly to the motherboard, thereby breaking the connection.
      FixBotに聞いてみる
      コメントを追加
    1. iView-776TPCII Motherboard Replacement, Motherboard: 手順 10、 3の画像 1 iView-776TPCII Motherboard Replacement, Motherboard: 手順 10、 3の画像 2 iView-776TPCII Motherboard Replacement, Motherboard: 手順 10、 3の画像 3
      • Remove the three 2.2mm Phillips head screws using a screwdriver to loosen the motherboard from the shell.
      • Check "Screwdriver Best Practices" as needed for help on how to properly use a screwdriver with your device.
      FixBotに聞いてみる
      コメントを追加
    2. iView-776TPCII Motherboard Replacement: 手順 11、 2の画像 1 iView-776TPCII Motherboard Replacement: 手順 11、 2の画像 2
      この手順で使用する道具:
      • Use the 45 degree tweezers to lift the black section of the digitizer ZIF adapter to release the ribbon. Gently pull the ribbon cable out of its socket.
      • When reassembling the device, be sure to fully secure the ribbon cable back into the ZIF adapter.
      FixBotに聞いてみる
      コメントを追加
    3. iView-776TPCII Motherboard Replacement: 手順 12、 3の画像 1 iView-776TPCII Motherboard Replacement: 手順 12、 3の画像 2 iView-776TPCII Motherboard Replacement: 手順 12、 3の画像 3
      • Use the 45 degree tweezers to lift the black section of the LCD ZIF adapter to release the ribbon. Gently pull the ribbon cable out of its socket.
      • The motherboard is now separated from the digitizer and front panel and can be safely removed from the device.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
4人の作成者と共同で作成されました。
Cory Gratzer
メンバー登録日: 09/16/15
586 ポイント
5のガイドは作成済み
チーム
IUPUI, Team 2-2, Baechle Fall 2015 IUPUI, Team 2-2, Baechle Fall 2015人のメンバー
IUPUI-BAECHLE-F15S2G2
3 メンバー
24のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 33
今までの合計 940
