メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iView-776TPCII Camera Assembly Replacement
必要な工具と部品
  1. iView-776TPCII Camera Assembly Replacement, Rear Panel: 手順 1、 3の画像 1 iView-776TPCII Camera Assembly Replacement, Rear Panel: 手順 1、 3の画像 2 iView-776TPCII Camera Assembly Replacement, Rear Panel: 手順 1、 3の画像 3
    • Before disassembling your device, make sure that the power is completely turned off.
    • Use the plastic opening tool to release the clips holding the rear panel of the device onto the front section.
    • The clips may take some pressure before releasing.
    • Continue around the entire device until all of the clips have been released.
    FixBotに聞いてみる
    コメントを追加
  2. iView-776TPCII Camera Assembly Replacement: 手順 2、 2の画像 1 iView-776TPCII Camera Assembly Replacement: 手順 2、 2の画像 2
    • Use a spudger to carefully free the speaker from it's housing on the back panel.
    • Place the spudger between the speaker and the rear panel. Use a prying motion to remove the component.
    • Be careful not to apply an over amount of force. If care is not taken, the speaker could break under the pressure.
    FixBotに聞いてみる
    コメントを追加
  3. iView-776TPCII Camera Assembly Replacement, Camera Assembly: 手順 3、 2の画像 1 iView-776TPCII Camera Assembly Replacement, Camera Assembly: 手順 3、 2の画像 2
    この手順で使用する道具:
    Heavy-Duty Spudger
    • The camera module is located in the upper-right corner of the tablet.
    • Loosen the edges of the black tape covering the camera using the heavy-duty spudger.
    • Use the freed edges of the tape to gently remove the camera assembly from its plastic housing.
    • The camera assembly will still be connected to the rest of the device via a ribbon cable. Take care so as not to tear this connection.
    FixBotに聞いてみる
    コメントを追加
  4. iView-776TPCII Camera Assembly Replacement: 手順 4、 2の画像 1 iView-776TPCII Camera Assembly Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    • Use tweezers to lift the cover off the top of the camera's ZIF adapter.
    • When reassembling the device, be sure to fully secure the ribbon cable from the camera back into the ZIF adapter.
    • Pull the assembly away from the motherboard with a set of tweezers to prepare for desoldering.
    FixBotに聞いてみる
    コメントを追加
  5. iView-776TPCII Camera Assembly Replacement: 手順 5、 1の画像 1
    • Use the Portable Soldering Iron tool to heat the leads coming from the camera assembly to the motherboard, thereby breaking the connection.
    • For help on soldering, refer to the iFixit "How To Solder and Desolder Connections" technique guide as necessary.
    • Once heated, use tweezers to pull the wires free from their connections.
    • To ease reassembly, take note of which wire went to the positive and negative terminals.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Cory Gratzer
メンバー登録日: 09/16/15
586 ポイント
5のガイドは作成済み
チーム
IUPUI, Team 2-2, Baechle Fall 2015 IUPUI, Team 2-2, Baechle Fall 2015人のメンバー
IUPUI-BAECHLE-F15S2G2
3 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 27
今までの合計 596
