メインコンテンツにスキップ
iPhone 16 Back Glass Installation
必要条件のみ
この修理ガイドは、他のガイドの前提条件として使用されます。それ自体は不完全で、単独で使用されることはありません。
必要な工具と部品
  1. iPhone 16 Back Glass Installation, Remove the back glass adhesive: 手順 1、 3の画像 1 iPhone 16 Back Glass Installation, Remove the back glass adhesive: 手順 1、 3の画像 2 iPhone 16 Back Glass Installation, Remove the back glass adhesive: 手順 1、 3の画像 3
    • Be careful not to damage any of the spring contacts as you clean the frame.
    • This is a good point to test your repair before sealing up your phone. Connect the battery and back glass, power on your phone, and make sure it works as expected. Power it back down, disconnect the battery and back glass, and continue reassembly.
    • The adhesive remaining on your phone is difficult to remove and leaves residue. If you have trouble removing the adhesive, apply some heat using a hair dryer or heat gun.
    • Use the pointed end of a spudger to press and roll the adhesive until you can grip it with a pair of tweezers.
  2. iPhone 16 Back Glass Installation: 手順 2、 2の画像 1 iPhone 16 Back Glass Installation: 手順 2、 2の画像 2
    • Use the tweezers to pull the adhesive off of the phone.
    • Repeat the previous step and this step until all of the adhesive is removed.
  3. iPhone 16 Back Glass Installation, Clean the frame: 手順 3、 3の画像 1 iPhone 16 Back Glass Installation, Clean the frame: 手順 3、 3の画像 2 iPhone 16 Back Glass Installation, Clean the frame: 手順 3、 3の画像 3
    この手順で使用する道具:
    Microfiber Cleaning Cloths
    $3.99
    • Any leftover residue will compromise your iPhone's seal. Be sure to clean the frame thoroughly.
    • Wrap a microfiber or lint-free cloth over the point of a spudger and apply a few drops of high-concentration isopropyl alcohol (over 90%) to the cloth.
    • Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
    • Wait a few minutes before proceeding to make sure any excess alcohol has evaporated.
  4. iPhone 16 Back Glass Installation, Clean the black glass: 手順 4、 2の画像 1 iPhone 16 Back Glass Installation, Clean the black glass: 手順 4、 2の画像 2
    • If you're not reusing your back glass, skip this step.
    • Apply a few drops of high-concentration isopropyl alcohol (over 90%) to a microfiber or lint-free cloth and wipe around the perimeter of the back glass to prepare the surface for new adhesive.
    • If any clips on the back glass are bent, gently straighten them with your fingers.
  5. iPhone 16 Back Glass Installation, Orient the adhesive: 手順 5、 2の画像 1 iPhone 16 Back Glass Installation, Orient the adhesive: 手順 5、 2の画像 2
    • Orient your replacement adhesive over the frame with the larger blue liner on the underside and its pull tab in the bottom-right corner.
    • The color of your liner and the pull tab locations may be different on your adhesive.
    • Use features such as the camera cutout and notches along the edges to visualize how the adhesive will lay in the frame.
  6. iPhone 16 Back Glass Installation, Expose the bottom edge of the adhesive: 手順 6、 1の画像 1
    • Use the pull tab to begin peeling the back liner off of the adhesive starting from the bottom, but do not remove the liner all the way.
  7. iPhone 16 Back Glass Installation, Apply the adhesive: 手順 7、 3の画像 1 iPhone 16 Back Glass Installation, Apply the adhesive: 手順 7、 3の画像 2 iPhone 16 Back Glass Installation, Apply the adhesive: 手順 7、 3の画像 3
    • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
    • Hold the blue liner out of the way and align the adhesive with the bottom edge of the iPhone.
    • Lay the bottom edge of the adhesive into its recess in the frame, making sure the iPhone's spring contacts are aligned with their cutouts in the liner.
  8. iPhone 16 Back Glass Installation: 手順 8、 3の画像 1 iPhone 16 Back Glass Installation: 手順 8、 3の画像 2 iPhone 16 Back Glass Installation: 手順 8、 3の画像 3
    • Continue peeling the back liner off of the adhesive while pressing the adhesive into place along the edges of the iPhone's frame.
    • If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with new adhesive.
    • If your adhesive is misaligned and you don't have another set handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive, but keep in mind that your iPhone's water resistance will be compromised until you install new adhesive.
  9. iPhone 16 Back Glass Installation, Press the adhesive into place: 手順 9、 3の画像 1 iPhone 16 Back Glass Installation, Press the adhesive into place: 手順 9、 3の画像 2 iPhone 16 Back Glass Installation, Press the adhesive into place: 手順 9、 3の画像 3
    • Use the flat end of a spudger to press the adhesive into place around the perimeter of the frame.
    • Be careful not to touch the spring contacts sticking through the pink liner.
  10. iPhone 16 Back Glass Installation, Remove the pink liner: 手順 10、 3の画像 1 iPhone 16 Back Glass Installation, Remove the pink liner: 手順 10、 3の画像 2 iPhone 16 Back Glass Installation, Remove the pink liner: 手順 10、 3の画像 3
    • Use the small pull tab in the top-right corner to remove the pink adhesive liner.
  11. iPhone 16 Back Glass Installation: 手順 11、 2の画像 1 iPhone 16 Back Glass Installation: 手順 11、 2の画像 2
    • Once the top liner is removed, there should be three narrow liners on top of the adhesive with pull tabs near the bottom edge.
    • Your pull tabs may be in different positions.
    • If you don't see these pull tabs, you may have accidentally removed the thin liners in the previous step. If the adhesive is clean and properly aligned, you may proceed, just be careful not to touch anything to the exposed adhesive until you are ready to install the back glass.
  12. iPhone 16 Back Glass Installation, Connect the charging coil: 手順 12、 3の画像 1 iPhone 16 Back Glass Installation, Connect the charging coil: 手順 12、 3の画像 2 iPhone 16 Back Glass Installation, Connect the charging coil: 手順 12、 3の画像 3
    • Prop up the back glass along the right edge of your iPhone, using a box or similar sturdy object to support the screen.
    • Use the flat end of a spudger or your finger to connect the charging coil press connector.
  13. iPhone 16 Back Glass Installation, Connect the battery: 手順 13、 2の画像 1 iPhone 16 Back Glass Installation, Connect the battery: 手順 13、 2の画像 2
    • Use the flat end of a spudger or your finger to connect the battery.
  14. iPhone 16 Back Glass Installation, Install the cover: 手順 14、 3の画像 1 iPhone 16 Back Glass Installation, Install the cover: 手順 14、 3の画像 2 iPhone 16 Back Glass Installation, Install the cover: 手順 14、 3の画像 3
    • The connector cover has two hooks that slide into slots on the logic board.
    • Lay the connector cover on the phone so the hooks are slightly to the left of their slots in the logic board.
    • Use your finger to press the connector cover down and to the right until both hooks slide into their slots.
  15. iPhone 16 Back Glass Installation, Install the cover screws: 手順 15、 2の画像 1 iPhone 16 Back Glass Installation, Install the cover screws: 手順 15、 2の画像 2
    • Use a tri-point Y000 driver to install the two 1 mm‑long screws securing the middle connector cover.
  16. iPhone 16 Back Glass Installation, Remove the final adhesive liners: 手順 16、 3の画像 1 iPhone 16 Back Glass Installation, Remove the final adhesive liners: 手順 16、 3の画像 2 iPhone 16 Back Glass Installation, Remove the final adhesive liners: 手順 16、 3の画像 3
    • As you remove the liners in this step, the adhesive will be fully exposed. Make sure nothing touches the exposed adhesive.
    • Use the blue tabs to remove the liners from the bottom, left, and top edges of your iPhone. Wait to remove the liner along the right edge.
  17. iPhone 16 Back Glass Installation: 手順 17、 2の画像 1 iPhone 16 Back Glass Installation: 手順 17、 2の画像 2
    • Without letting the back glass touch the adhesive, hold the back glass over the phone so you can access the final liner along the right edge of the phone.
    • Use a pair of tweezers or your fingers to remove the final liner along the right edge of the phone.
  18. iPhone 16 Back Glass Installation, Place the back glass: 手順 18、 3の画像 1 iPhone 16 Back Glass Installation, Place the back glass: 手順 18、 3の画像 2 iPhone 16 Back Glass Installation, Place the back glass: 手順 18、 3の画像 3
    • Hold the back glass above the phone and align it with the frame.
    • Lay the glass straight down onto the frame and press until the clips engage.
    • Press around the perimeter of the back glass to engage all clips.
  19. iPhone 16 Back Glass Installation, Heat the back glass: 手順 19、 3の画像 1 iPhone 16 Back Glass Installation, Heat the back glass: 手順 19、 3の画像 2 iPhone 16 Back Glass Installation, Heat the back glass: 手順 19、 3の画像 3
    • To help the adhesive bond, apply heat to the edges of the back glass using an iOpener, hair dryer, or heat gun until it's hot to the touch.
    • Firmly press around the perimeter of the back glass.
    • If you have screen vise clamps, use them to strengthen the bond of your new adhesive. If not, keep reading for more ways to secure the back glass.
  20. iPhone 16 Back Glass Installation, Press the back glass: 手順 20、 3の画像 1 iPhone 16 Back Glass Installation, Press the back glass: 手順 20、 3の画像 2 iPhone 16 Back Glass Installation, Press the back glass: 手順 20、 3の画像 3
    • To evenly compress your iPhone and strengthen the bond of the back glass to the frame, you need to account for the camera bump.
    • If you have the box your iPhone came in, take the lid and place it on a flat surface.
    • If you don't have your original box, skip this step for an alternate method.
    • Place your iPhone screen-side-up in the lid of your box with the camera bump in its recess.
    • Find something close to the size of your iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
    • Leave the objects in place for at least thirty minutes. The lighter the objects, the longer they should be left. Ideally, leave them stacked overnight.
  21. iPhone 16 Back Glass Installation: 手順 21、 2の画像 1 iPhone 16 Back Glass Installation: 手順 21、 2の画像 2
    • If you don't have the original box for your iPhone, follow the next three steps for another method to evenly compress the back glass.
    • Place the iPhone screen-side-down on a soft, flat surface.
    • Apply tape to the back glass to protect its finish.
  22. iPhone 16 Back Glass Installation: 手順 22、 3の画像 1 iPhone 16 Back Glass Installation: 手順 22、 3の画像 2 iPhone 16 Back Glass Installation: 手順 22、 3の画像 3
    • Place two layers of coins or similarly thick objects on the tape along the edges of the back glass.
    • Evenly distribute the coins and make sure they are at least as thick as the camera bump.
  23. iPhone 16 Back Glass Installation: 手順 23、 1の画像 1
    • Stack multiple books or other heavy objects on your iPhone.
    • The coins may leave an impression on the bottom object, so don't use anything valuable.
ゴール
Spencer Pennington
メンバー登録日: 09/09/23
16,968 ポイント
113のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,418のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 4
今までの合計 35
