はじめに
iPad Airの壊れたロジックボードを交換する際にはこのガイドをご利用ください。
  1. 電子レンジに付着している汚れがiOpenerに付いてしまうことがあるので、使用前に電子レンジの底をきれいに拭き取ってください。
    • 電子レンジに付着している汚れがiOpenerに付いてしまうことがあるので、使用前に電子レンジの底をきれいに拭き取ってください。
    • iOpenerを電子レンジ中央に置きます。
      • 回転型の電子レンジ:iOpenerが電子レンジのターンテーブルで回転しているか確認してください。iOpenerが作動中に留まってしまうと、熱しすぎや焦げてしまいます。
    which temperature must be used for heating? Thx
    fbarletta - 返信
    I found you need to be very patient when using the iOpener. It's worth taking your time, giving the heat time to work on the glue. When I finally got the battery out, there were some strips of glue left behind that I just cleaned off with some isopropanol before installing the new battery.
    By the way, I had to run the iOpener for longer in my microwave for it to get hot enough. When it was too hot to touch, I figured it was hot enough for the batteries.
    Fredrik -
    I didn't find this to be as hard as I had built it up in my mind to be; HOWEVER, saying that I need to say years ago I was the local Nokia service center in my town. But many years ago right after they got rid of analog times. Yeah. A classic installer/repairer mistake when starting something they haven't fixed or installed before is picking up the instructions, flipping through them; maybe even reading a section that is new-then tossing the instructions over the shoulder. "I got this." This usually comes right before something major gets broke. And I can tell you when you try to do it yourself and then mess it up horribly then take it to the repair shop. Well we called that "I can do it myself" syndrome and charged extra to put back together what they brought in in the box. Now knowing all this - I can't stress this enough because I am stupid, stupid, stupid. COVER YOUR SCREEN IN CLEAR BOXING TAPE AND READ ALL THE INSTRUCTION BELOW THROUGH TO THE END BEFORE EVEN ATTEMPTING THIS FIX. Take my advise.
    windizy - 返信
    I didn't have an iOpener, so I used a wheat type heat bag. If you do this though, make sure you put a layer of plastic between your Mac and the bag, or you'll get condensation in places you don't want it.
    Martin Gray - 返信
    I started out using the iOpener but switched to my wife's hairdryer. A heat gun or hair dryer proved to be much more convenient and is a time saviour. You can heat more and the glue becomes more fluid make the next steps with the opening picks much easier
    Jan Van Puymbroeck - 返信
    Use a hair dryer! Watch this vid: https://youtu.be/16GkvjVyOJA It is much easier to do if you heat it from the other side.
    Fletcher Carpenter - 返信
    I wonder how many people actually wrapped in their iPhone into iOpener and put this "sandwich" into microwave??
    putinaspiliponis - 返信
    I know this is obvious, but backup your iPad with iTunes before you start. I'd also turn off your passcode if you have one.
    Laurie Higgins - 返信
    Ther first time you heat up the iOpener for this repair when its room temperature I had to heat it up for more than 30 seconds. I remember I had to heat it up for around 45 seconds. However, after that when you need to reheat it again during the repair 30 seconds will be enough.
    Yousef Ghalib - 返信
    I've been with Samsung for 8 years now!! Never did i have a case on any of my phones My Samsung 8 is 2 months old the case protector around the edge pop off and broke my phone it's like someone put a bullet hole in it
    Sherry Carew - 返信
    Not everybody has a microwave. You need to state how long and at what temperature in a conventional oven.
    Esmond Pitt - 返信
    Hi, the microware have multiple power 1 to 9, what must be used ?
    Regards,
    Cedric
    Cedric VINCENT - 返信
  2. iOpenerを30秒温めます。
    • iOpenerを30秒温めます。
    • 修理作業中はiOpenerが冷めてしまいますので、使用毎に電子レンジに30秒入れて温めてからご利用ください。
    • 作業中、iOpenerを温めすぎないようにご注意ください。温めすぎるとiOpenerを破裂させてしまうことがあります。
    • 膨らんでいる状態のiOpenerは絶対に触らないでください。
    • 適切に温められたiOpenerは約10分間、温かい状態を保ちます。
    May I know the temperate limit about heating iOpener? (maximum 150 degrees Celsius?) thx so much.
    yamayhuang - 返信
    I had to heat mine up for more than 30 seconds. After 30 seconds on high it was only warm. It had to keep trying different times and checking it until it got hot. I think the initial time that I put it in for was over a minute.
    whale13 - 返信
    DO NOT USE IN NON ROTATING MICROWAVE! It will pop a hole. I had it in for 45 seconds the first time. It wasn't very hot inside and I saw it started to leak on the paper towel I put under it. Just a fair bit of advice. I think I will just stick with the heat gun. Loud but useful.
    Alex Jackson - 返信
    I don't own a microwave.
    mdanihy - 返信
    Its again waterproof when you change iphone 7 battery?
    Jon - 返信
    I don't have a microwave???
    Joe Blow - 返信
    30 sec at which equivalent watts setting and what temperature does iOpener heats up to for 30 secs. Only just bought it so needs info before using it. Thanks
    Sam Stieg - 返信
    can i use just ordinary microwave???
    juneseok kwon - 返信
    If I don't have a microwave then I try to use hot air gun so how many munuts i want to heat ?
    Mohideen Rifay - 返信
    I heated mine up for 30 seconds, tested, then again for 30 seconds. It felt adequately hot. Leaving it on the left side, per the instruction, for a minute did not loosen the adhesive. I ended up pulling the suction cup hard enough to shadder the old screen. Moral of the story, I don't think it gets hot enough safely to have an affect.
    Travis Dixon - 返信
    There is a clear problem here with the heating part using the iopener things....no details are given. Whoever is testing them needs to make it clear - What temperature does it need to be? And for which phone models, because they differ in what's needed. It's only £10-15 for a laser guided temp sensor unit, and the designers/repairers should have one of those already for doing these kinds of repairs. Explaining half a repair, is worse than not explaining at all :-(
    assortedrubbish - 返信
    I used a hot water bottle, works well as it covers the whole screen and stays hot for longer.
    dave - 返信
    If I may suggest include your microwave wattage so people can get an idea on time for there own
    Patrick Storey - 返信
    I ended up using a hair dryer. That iOpener thing took forever.
    mark fitzgerald - 返信
    30 seconds sure isn’t cutting it… 45 didn’t get the screen of my iPad air 2 to budge either… even after resting on the ipad for 4 minutes.
    60 seconds in the microwave, the iOpener burst.
    I’ll get a new one and try once more with heating it 45 seconds and repeat that for 30 minutes like others have said here. If that doesn’t work it’ll have to be the heat gun.
    K
    Karl Marble - 返信
    • 電子レンジからiOpenerを取り出します。iOpenerの中央は熱くなっているため、両端の平面になっている部分を持ってください。
    • iOpenerは大変熱くなっていることがあります。必要であれば、オーブン用のミトンカバーをご利用ください。
    Will a hair dryer work for heating the glass?
    Me berg - 返信
    Yes, as does a heat gun.
    anonymous 4602 - 返信
    I did this repair. I used a hair dryer, I think it works better: gets very hot fast.
    Cobus de Beer - 返信
    • ディスプレイガラスにひびが入ってしまった場合、割れてしまった部分が広がらないようにガラス表面上にクリアテープを貼るなどして、怪我がないようご注意ください。
    • iPadディスプレイ上にクリアタイプのテープを何重にも貼り、全体を覆います。
      • これはディスプレイをこじ開けて引き上げた際に、ガラスの破片が飛び散るのを防ぐことができます。
    • ここに書かれている手順にできるだけ従ってください。しかしながら、ガラスが一旦割れてしまうと、作業を続けていくにつれてひびが広がってしまう可能性があります。この場合、ガラスを取り出すためにはメタル製工具を使用する必要があります。
    • 目を保護するために保護メガネを装着してください。また液晶ディスプレイスクリーンにダメージを与えないようにご注意ください。
    If you add clear packaging tape, it will create bubbles and the suction cup will become inefficient. To me it was impossible to remove the glass with the suction cup. Since the glass was very cracked, I had to resort to some tweaking with strong tape and pull the this off.
    jfmartin67 - 返信
    If your screen is significantly cracked to the left edge, abandon this entire setup, prepare yourself for a 5-6 hour repair, expect a lot of patience, a lot of cursing and some good old American ingenuity. The suction cup and picks will not work. You have to carefully crack the glass yourself (w/out damaging the panel underneath and carefully pull it apart from the inside to the outside edges. Use a hairdryer to soften the glue under the cracked panel along the edges. Then use an exacto-knife to separate the pieces of the glued panel from the frame body, all the way around the device. Watch out for the home button ribbon connector when using the exacto-knife. There will be glue residue left over, carefully apply some goo-gone to a small area of a paper towel and wipe gently around the frame body to loosen the glue. Then use the plastic spudger tool to scrape off the excess glue.
    The iPad repair is VERY difficult. If you are a working adult, hire a pro. This is not for the faint of heart.
    aaroncope - 返信
    The hairdryer option was way faster and easier than the iOpener. Be VERY careful not to damage the LCD- one small mistake will cost you an extra $100!
    Mike Martin -
    If your digitizer is shattered, the tape will help, but you’re going to need extra picks. Or a razor blade. See below.
    Blair Miller - 返信
    Friendly observation that the image on this step is actually of an older ipad model as the side bezels are far too big. I don't know if that matters to anybody but a noob might see it and think this manual doesn't apply to them. : )
    notalawyer - 返信
    I had the same experience. My glass was cracked all the way to the left side and the suction cup would not pull the glass up. The packaging tape also didn't help. The heat caused it to lift. I finally abandoned the tape, used a heat gun aimed very carefully at each broken piece of the screen. The picks did work with patience, but I just pulled off each broken part of the glass. I also found that pulling up on one broken part while heating in front of me would let the next piece pull up. I continued heating and breaking all the way around. Do the right side last. Took about 1 hour to get it off, and another hour to clean the old glue off the frame. BTW thanks to this web site and all the comments! No way I would have done this without all the help here! I am now clean and waiting for my new digitizer. I couldn't free the battery (below), so I left it powered up, and verified it till worked before throwing away the old glass. Vince
    Vince Asbridge - 返信
    Taping with package tape doesn't work. You'll need a very large piece of tape if you go this route.
    Travis Dixon - 返信
    Just finished successful repair. I would add this: most folks will be here because of cracked screen. This is not easy; believe the 'complex' rating on this repair. I put tape on my screen because it was badly cracked. This made the suction cup useless, because it just sucked the tape off the scree.n. I used the razor blade technique which worked great, it should be used in the demo, and a good blade should be in the kit.
    dale kingsbury - 返信
    • 温めたiOpenerをiPadのホームボタンアセンブリの左側サイドに当たるように置きます。
    • iOpenerを約1分間置き、ガラスの下に付けられた接着剤を柔らかくします。
    The iOpener doesn't work because the heat isn't strong enough. I used a hair dryer which proved to be much more efficient.
    jfmartin67 - 返信
    The iOpener didnt work for me either. seems like it gets hot enough but it must not. I spent 30 min with the iOpener, then tried a hair dryer.
    kinchma - 返信
    “At least a minute.” Bullshit. Get the iOpener good and hot, place it on the area you’re going to work on clear side down, and cover it with a towel. Walk away for 2 minutes. Make yourself a drink — you’ll need steady hands later.
    Blair Miller - 返信
    I've done this with an iOpener and at least in my case, it worked fine. You may have to modify the heating instructions though, since not all microwaves are created equal.
    Jeff Suovanen - 返信
    ii i just did this and it took a while but i figured it out it is true this thing doesnt get hot enough BUT heat it 2 times and then the 3rd time when u place it on the ipad put the ipad box on top and then maybe a second ipad on top of the box so it kinda smashes i down but not too much for it to break and then wait for it to turn warm THEN use the succion THEN the gap appears. the glue is super strong on the ipads so yea it will take some time lol
    Joel Tyson - 返信
    Doesn't work. Perhaps include more copy on exactly how to do it?
    Travis Dixon - 返信
    The iOpener does not work. It simply it is not hard enough to soften the glue. The heat hair dryer method does not work either.
    Javier Lozada - 返信
    The goal is simply to weaken the glue enough that you can use your suction cup to open up a tiny gap under the glass, so you can insert an opening pick and slice through the adhesive. It doesn't actually take all that much heat; the picks will do most of the work once you get them in there. iOpeners, hair dryers, heat guns all work fine in my experience—the iOpener is just a bit more foolproof because it won't get hot enough to cook the display panel underneath.
    Jeff Suovanen - 返信
    • iPadは外側からみるとしっかりとしたつくりに見えますが、フロントガラスの下には壊れやすいコンポーネントが存在しています。これらにダメージを与えないためには、各手順で指定されたエリア以外は温めたりこじ開けたりしないでください。
    • この手順を進んでいく中で、次のエリアはこじ開けたり、接触しないように特にご注意ください。
      • 正面カメラ
      • アンテナ
      • ディスプレイケーブル
    Don't assume anything!! I thought I was pulling on the screen connector and I was pulling on an antenna component instead. Didn't ruin its connection range but I sure remember doing it and now my iPad has a little internal flaw only I'm aware of.
    Travis Dixon - 返信
    • 温めた側の真ん中から少し上辺りに、吸盤カップを取り付けます。
      • しっかりと吸盤がスクリーンに装着されるにはカップがスクリーン上に完全に平らに付いているか確認してください。
    • iPadを片手で押さえながら、背面ケースをフロントパネルのガラスから離すために吸盤カップを上部に向けて引っ張りあげます。
    In this picture above, the glass isn't cracked at all so it helps the suction cup to be effective as it is hermetic. With cracked display, it won't work.
    jfmartin67 - 返信
    Suction cup would not work for me. No amount of heating with iOpener or hair dryer would allow even the slightest gap to form. I ended up looking at some YouTube videos and used a razor blade. I put the razor blade perpendicular to the top glass, right at the edge of the glass and pushed down until the blade went down 1/4". Then heated some more and pried up the glass enough to put in an opening pick. I spent a lot of time working with the suction cup. Glue was just too strong.
    kinchma - 返信
    It's funny that iFixit changed the image they used. Even they themselves realized how stupid it was to try a suction cup on taped up surface. C'mon guys! You should at least make foot notes for your readers and let them know what to do if the glass is already shattered. It's a slow methodical process that involves working with a iOpener type tool. I personally have one that looks like a prison shank (lol)
    Scott S - 返信
    Not sure what you are referring to there—I see no evidence in the document history of the photos having been changed. Suction cup + packing tape can work, but it depends how badly the glass is broken and the quality of the tape. Sometimes it takes a couple attempts. You can also skip the suction cup and try using tape alone to pull on the panel, if your tape is sticky enough. There are no guarantees though, which is why we have the disclaimer right in Step 4 that the procedure can be pretty fussy if you're working with a shattered panel. Depending on where it's broken and how badly, you're going to have to improvise.
    Jeff Suovanen -
    Jeff, the change is evident from image 4, where all the surface is taped up. In this picture you show a clean not broken surface and yes, the suction cup works...
    Simone Gabbriellini -
    Ah, I see what you're saying! I can understand why you guys would assume that, but in reality the entire guide was originally photographed using an intact panel. We later added a step showing how to protect yourself if you have a shattered panel (with photos to go along with, obviously). I'm afraid it wouldn't be practical to re-shoot the entire guide every time we make a small change like that.
    Jeff Suovanen -
    The suction cup is useless if your glass is shattered. Use a new, sharp razor blade, and insert it vertically between the edge of the glass and the metal back of the iPad. Don’t worry about pressing too hard — there’s a lip that stops the blade from going in too far and damaging anything. You’ll probably have to do this several times, but eventually the blade will “bite” into the edge of the glass well enough for you to pry it up. Insert a pick underneath the razor, then remove the razor and continue as directed.
    Blair Miller - 返信
    After having to read several comments on this screen removal and the clear packing tape, I too have to agree that the tape method does not work well at all if your screen is already shattered. I combined several methods, with lots of patience to remove the screen on my iPad Air 2. What I found it very helpful was the heat gun used for paint removal. The heat gun generates a lot of concentrated heat at lower air velocity, unlike generic hair dryer, so you must be very careful not to ruin the electronics, and risk burning your hands and anything around it. My heat gun that I purchased from Home Depot had a nozzle to direct and focus the heat on a small area. That was helpful in working small area at a time. This method work thoroughly well.
    Taiji Saotome - 返信
    It would work if you leave iopener in microwave for 1 minute.
    Don’t trust the instruction from ifixit.
    you can put iopener in microwave for 1 minute without any harm.
    Note. you have to make sure that it is in cold position before you put it into microwave.
    phongsiri nirachornkul - 返信
    Suction cup didn’t work for me either, went the razor blade route (using an exacto knife blade) with very minimal damage to the aluminum shell. Be warned, if your screen has cracked along the edge (as it almost 100% certainly has if you’re reading this guide), the screen will continue to shatter and splinter as you make your way around the edge. That’s when having the screen taped up well will be to your advantage. There’s also a good chance you’ll have to re-insert the razor blade on the other side of a fracture and start the lifting process again, but keep going, being sure to avoid the points called out in this guide and you should be fine.
    Also, do not apply the suction cup to an area of the screen with cracks and no tape. If you’re near the edge you run the risk of brutally shattering that area of the glass if the glass gives before the suction cup.
    Micah Sledge - 返信
    In order to get this to work for me I had to heat the IOpener to over 104 C - I needed to get the screen over 40 C before the adhesive would loosen.
    Also I had to put the ipad on a towel - the granite countertop it was on was sucking the heat out too fast.
    Jack Williams - 返信
    This step was brutal on my nerves - read about too many people ruining their iOpener and I don’t have a heat gun. I had to keep heating the iOpener incrementally hoping I wouldn’t pop it. … but if you’re patient, persistent, and cautious, you can definitely tell when you’re seeing separation. The iOpener ended up being WAY hotter than 30 seconds was getting me - borderline scorching my hands.
    William Thompson - 返信
    • 吸盤カップによって引き上げられた際に出来る隙間に開口ピックを差し込みます。
      • 開口ピックをディスプレイ横にある黒い外縁よりも深く差し込まないでください。このピックを深くまで差し込んでしまうと液晶ディスプレイを傷つけてしまうことがあります。
    • 吸盤カップのプラスチック部分の持ち手を引っ張り、吸盤力を緩めてディスプレイアセンブリから外します。
    コメントを追加する
    • iOpenerを再び温めて、同じ箇所に置きます。
      • 修理作業中、 iOpenerを温めすぎないようにご注意ください。 iOpenerを再度温める際は、少なくとも前の作業から2分ほど待ってから行ってください。
    This says "Always wait at least two minutes before reheating the iOpener", however the iOpener itself has a warning printed upon it that says wait at least 10 minutes. And that 10 minutes warning is also mentioned in Step 2 above.
    Scott - 返信
    Sorry about that! We fixed the text on this step. The two-minute interval was for an older version of the iOpener—the text printed on your iOpener will have the correct interval, which is indeed ten minutes. It can burst if overheated or reheated too quickly.
    Jeff Suovanen -
    • 2番目の開口ピックを1番目に差し込んだ開封ピック付近に挿入し、iPadの端に沿って接着剤を剥がしながら下側に動かします。
    You guys really need to show how it's done when your iPad isn't perfect like the one pictured above.. C'mon..
    Scott S - 返信
    This is for BATTERY REPLACEMENT not CRACKED SCREEN REPLACEMENT!!
    Corey Barcus -
    How do you slide the picks when the glass is broken? Even with the glass taped, it pulls away from the tape rather than the housing. I've just further shattered the glass with my attempts.
    chrisweiler - 返信
    • 続けて接着剤を剥がしながら、開口ピックディスプレイの横から下に向かって動かしていきます。
    • 開口ピックが接着剤に絡まり動かなくなった場合は、ピックをiPadの横に沿って"回転させながら"接着剤を剥がしていきます。
    This gives a false illusion to the difficulty of these repairs when you guys make guides using perfect devices. What about devices with dinged corners? A reader is gonna slap on a new screen and shatter it the second they apply pressure thinking it will fit into a dented corner lol
    Scott S - 返信
    • 1番最初に差し込んだピックを手に取り、iPadの上部端に向かってスライドして動かします。
    • フロントガラスを通して開口ピックの先端が見えたら、びっくりしないでください。ーピックを少しだけ外側へ引いてください。ほとんどの場合は問題ありませんが、奥まで差し込みすぎないように注意してください。液晶ディスプレイ上に接着剤が付いてしまった場合、取り除くのが難しいためです。
    I managed to get a couple of fingerprints on the LCD.
    What's the best way to clean 'em off?
    What's the safest way?
    Mike McIntosh - 返信
    What I’ve read, and seems to work, is gentle circular pressure with a very clean, dry microfiber cloth. Lacking that, use a TINY drop of water ON THE CLOTH, not on the LCD. Small amounts of alcohol can be used, in my experience, but only if the above don’t work, and with better results if used in small amounts and applied to the cloth, not the LCD.
    Bonnie Baxter - 返信
    • iOpenerを再び温め、iPadの上部端、正面カメラの上に置きます。
      • 修理作業中、iOpenerを温めすぎないようにご注意ください。前の作業から少なくとも2分間置いて温めてください。
    • 形を自由に変化できるiOpenerをお持ちの場合は、上部左端と上部先端を同時に温めるよう曲げてください。
    コメントを追加する
    • 開口ピックをiPadの左端上部にスライドさせて接着剤を剥がします。
    コメントを追加する
    • 開口ピックをiPadの上部端に沿ってスライドさせます。カメラの手前で止めます。
    • 3番目の画像はフロントカメラがiPadのどの位置に内蔵されているかを示したものです。
      • 開口ピックを正面カメラ上にスライドしないでください。レンズ上に接着剤を伸ばしてしまうとカメラにダメージを与えてしまいます。次の手順は正面カメラを傷つけないで作業を進めるためのアドバイスを記しています。
    コメントを追加する
    • ピックを少し外側に向かって引き出し、上部端に残っているわずかな先端を正面カメラ上部に沿って動かします。
    コメントを追加する
    • 正面カメラを過ぎた位置でiPadの中に開口ピックの先端を残して作業を止めます。
    • 2番目のピックを取り出して、正面カメラの左側に差し込みます。それからiPadの左端に向かって接着剤を剥がしながらスライドします。
    コメントを追加する
    • 先ほどの(1番目の)ピックをiPadの奥まで差し込み、正面カメラの右側から角に向かってスライドします。
    コメントを追加する
    • iPadの角に3本のピックを残したまま、正面パネルの接着剤が再び付着するのを防ぎます。
    • iOpenerを再度温め、iPadの残りのサイド端にーボリュームボタンとロックボタンに沿って、これを置きます。
    コメントを追加する
    • iPadの上部右端周辺に開口ピックをスライドさせて接着剤を剥がします。
    • このピックを接着剤が再び付着しないよう残し、新しいピックを次の手順で使用します。
    コメントを追加する
    • 新しい開口ピックを差し込み、これをiPadの右端の真ん中までスライドさせます。動かしながら接着剤を剥がします。
    • iPadの下部からディスプレイケーブルが装着されています。ここでiPadの下から4.5インチあたりの位置で作業を止めます。
    Why there’s such an obsession with not damaging the cables is beyond me. Be careful, so as not to damage what the cables are connected to. But the cables are part of the replacement digitizer, so if you nick or even slice through them (like I did with the one closest to the bottom) don’t worry about it.
    Blair Miller - 返信
    Keep in mind that some people are here to open an intact display to replace internal components! In those cases, keeping the cables un-harmed is quite important ;)
    Sam Lionheart -
    My digitizer WAS ok and I was only replacing the battery I wasn't careful enough when coming around the side with the pics and got a hold of the cable just enough with the pic to pull it off the underside of the panel. The battery replacement went great other than now I have to replace the digitizer. :(
    BE CAREFUL WITH THIS STEP!!!
    Dylan Bouterse - 返信
    And if you are replacing the digitizer, you have to reuse the fingerprint sensor home button. I sliced through mine and now I’ll not have fingerprint sensor. Each home button is matched to the main board and if switched out you will loose that sensor ability.
    David - 返信
    • 開口ピックを挟んだままで、iOpener を再び温めてiPadのホームボタン端の上に置きます。
    コメントを追加する
    • 左側中央に差し込んでいる開口ピックを左側下部の角に向かって、接着剤を剥がしながらスライドしていきます。
    • 左側下部の角でピックを残したまま止めます。これ以上こじ開けないでください。iPadにピックを挟んだままにします。
    • 3番目の画像はiPadの下部分に装着されている2本のアンテナとホームボタンの様子です。
      • 次の手順ではこれらのコンポーネントにダメージを与えないために、どこからこじ開ければよいのかを教示しています。iOpenerを温めて、指定された場所をこじ開けてください。
    コメントを追加する
    • 接着剤が再付着しないように、開口ピックを左側下部の角に挟んだままにします。
    • 新しいピックを手に取り、左側アンテナの上をゆっくりと滑らせます。ホームボタン手前で止めます。
      • iPadの中央に向けて、外側のエッジのみをピックでスライドさせます。中央から外側に向かってピックを戻さないでください。この方向に動かすとアンテナにダメージを与えてしまうことがあります。
      • 開口ピックを2回以上スライドする必要がある場合は、左端外側から中央に向かってピックを再挿入して、作業を継続してください。
    • 次の手順に移る前に、ピックを中央付近で挟んだままにします。
    コメントを追加する
    • 再び新しい開口ピックを手に取り、前回の手順で止めたピックの右側に差し込みます。
    • ホームボタンと右側のアンテナ上をスライドさせます。接着剤を剥がすため、ピックの先端のみを使って動かします。
    コメントを追加する
    • 接着力が弱くなるため、開口ピックを右側下部の端に挿入します。
      • 左側のアンテナと同様に、外側の端から中央に向かってスライドします。中央から外側に向けて動かすと、アンテナを傷つけてしまうことがあります。
    I think you’re missing a step here where you explicitly direct the reader to slide the pick from the bottom right corner towards the home button.
    Fin Hirschoff - 返信
    • iOpenerを再び温めて、iPadの音量コントロール側の端に沿って配置します。
    コメントを追加する
    • この手順では特に慎重に作業を進めてください。時間をかけてゆっくりと、接着剤が温かく柔らかくなっているか確認します。開封ピックを使って接着剤全体を剥がします。必要に応じて、作業を止めて iOpenerを再び温めることも考慮してください。
    • 音量コントロールの反対側の両角にはピックを挟んだままにします。ガラスを持ち上げるように、ピックを少しひねります。ディスプレイケーブルの端に沿って留められた接着剤が剥がれます。
    • かなりの接着力が残っている場合は、ピックをそのままの場所に残して iOpenerを再び温め、問題の箇所に当てます。
    You will end up having to scrape the outter ledge to remove the old screen. I bled and got glass shards everywhere. Good luck!
    Travis Dixon - 返信
    • ディスプレイケーブルの端に沿って、接着剤をゆっくりと剥がしながら、ディスプレイを上げていきます。
    コメントを追加する
    • フロントパネルのガラスを固定したままで、開口ピックを使って最後の接着剤を切り離します。
    • ディスプレイケーブルにダメージを与えたり、切断しないように作業は十分注意しながら行ってください。
    コメントを追加する
    • 全ての接着剤が外れたら、本を開く状態のようにフロントガラスを開いて作業台上で休めましょう。
    • 再装着の間は、ケースに残っている接着剤の残りをガラスクリーナなどイソプロピルアルコールで綺麗に拭き取ってください。(そしてフロントガラスを再利用する際はこれも綺麗に拭き取ります)プレカットされた接着ストリップを使って接着剤を交換します。
    my replacement digitizer has rigid flex with adhesive tape where the connectors extend. how does this “fold” back inside the frame?
    David - 返信
    • 液晶ディスプレイのネジを覆っているテープを全て取り出します。
    コメントを追加する
    • 液晶ディスプレイに留められた次の#00プラスネジを取り外します。
      • 4.0 mm ネジー3本
      • 4.8 mm ネジー1本
    Use the provided replace screen case's square compartments to place your screws into as you remove them. Really helpful and you likely won't mess up.
    Travis Dixon - 返信
    I tape a stripe of double sided tape on my workbench. You can place the screws on the tape on the location where the screw would be if it was in the screen assembly. In this step, your screws would be in the four corners of the tape stripe, with the longest screw (4,8mm) in the upper left corner. The other screws from the next steps can also be placed on the tape this way.
    Brecht Bocket - 返信
    • 液晶ディスプレイをを完全に取り外さないでください。幾つかのケーブルがホームボタン上でiPadに繋がっています。正面カメラの端から持ち上げてください。
    • スパッジャーの平面側の先端を使って、液晶ディスプレイを指で掴めるぐらいの高さまで押し上げます。
    • 本のページをめくるように、iPadの液晶ディスプレイをひっくり返ます。カメラ付近から持ち上げて、ホームボタン上を軸にひっくり返します。
      • 液晶ディスプレイケーブルにダメージを与えないように特別に注意しながらディスプレイをひっくり返します。
    • ディスプレイケーブルに作業ができるよう、液晶ディスプレイを開いたままにします。
      • 液晶ディスプレイを柔らかくて、防塵機能のついた清潔な表面上に置きます。
    Got a cracked screen from toddler stepping on the iPad. My repair went well, everything worked. Except I scratched the LCD. It seems to scratch easily.
    At this step, be careful when folding over the screen, as it may scratch on the aluminum frame (third picture). When they say “soft lint free surface” that is needed, specifically where the LCD meets the frame. Place a thin cloth like sunglass cleaning cloth over the edge of the frame.
    Cobus de Beer - 返信
    • ロジックボードにバッテリーコネクターを留めている2.3 mm#000 プラスネジを1本外します。
    • バッテリーコネクターの下に開封ピックを差し込んで、ロジックボードから接続を外します。
    after inserting the tab between the battery, im having an issue with the battery taking a charge. charging port sees a cord plugged in, but this connection between battery and logic board is gone. any ideas?
    Matt - 返信
    Hi were u able to fix this issue? I accidentally fried out the shield that secured the battery connector..now the ipad wont turn on :(
    Drew -
    Not having the isolation pick, I used 2 thin guitar picks instead, which did the job fine.
    goodcyning - 返信
    I couldn't disconnect the battery connector - I applied some force, nothing happened and I was afraid of applying too much force - so I just left it connected and I was very careful not to short out any terminals with metal tools. I completed the repair without any other issues and the iPad now seems to be working fine.
    Peter Gray - 返信
    A little explanation here would be nice. Also, there wasn't a battery isolation pick in my kit. You should address this.
    dougintexas - 返信
    Mine was missing. Made one with scissors but still didn't do the trick. I just worked with the batteries still plugged in.
    Travis Dixon - 返信
    Couldn’t get the battery terminal disconnected so I continued with repair. I didn’t short anything but now it won’t do anything. It worked before, just a cracked glass to replace. Any solutions?
    Tech-ER - 返信
    • ディスプレイケーブルのブラケットから 1.4 mm #000プラスネジを取り出します。
    コメントを追加する
    • スパッジャーの平面側先端を使って、ディスプレイケーブルのブラケットをロジックボードからまっすぐ引き上げます。
    • ディスプレイケーブルコネクターはブラケットの底面に接着されています。ブラケット下の奥までスパッジャーを押し込まないでください。コネクターにダメージを与えてしまうことになります。
    bough my digitizer from ebay and have everything done up to this step. The screwdriver the kit came with said to be a #000 but it stripped the screw on the plate... I have tried rubber bands, tape and paper to no avail...anyone got an idea on how to remove the screw. Also I am currently studying in St. Kitts and they lack some products found in the US.
    originalpaintballpanda2 - 返信
    I'm sure you've moved past this by now, but I've had some success with stripped screws using a comparable, if slightly larger flathead screwdriver. The screwdrivers that come in those kits tend to suck quite a lot... iFixit actually has a guide for stripped screws: ネジ山が潰れたネジを取り出す方法
    goodcyning -
    Does anyone know where I could purchase a replacement display cable bracket?
    gwarren - 返信
    Note:Be rly carefule with unplugin homebutton-connection.
    The plug-connection (Homebutton) is not similar to the plug connections the basic-plugs got.
    The homeputton-plug-connection is sensetiv and cant unplug easly.
    IPad - 返信
    • 液晶ディスプレイを取り出します。
    Andddddd continue this iFix folks! It's not a matter of working backwards. Most people must have cracked screens and end up having to rip the screen off and won't have a chance to inspect connections.
    Travis Dixon - 返信
    • ホームボタンのリボンケーブルコネクターを覆っているテープを外します。
    コメントを追加する
    • スパッジャーの平面側先端を使って、ホームボタンのリボンケーブルZIF コネクター上にあるタブを上向きに引き上げます。
    • ホームボタンのリボンケーブルをZIF コネクターからまっすぐ外します。
    I got through the repair, only to have the new screen give me problems that I can not find solutions to any where. The digitizer is working on its own without my input, it will start apps, switch windows, etc. I have pulled up the new screen and checked my ribbons and cables seem to be fine. ANY IDEAS??
    Moses Roman - 返信
    Moses Roman
    Same exact problem that I have. I think it has something to do with the glass touching the ipad. Something like on the iPad mini, where you had to cover some areas beside the home button.
    I would love to see a real solution, as im stuck with unhappy customers and frustrated me :)
    Bilal Kinali - 返信
    I had mine replaced TWICE by a local repair shop. Soon noticed both times that the iPad would soon go haywire after a few minutes use with random clicks, ghost typing, opening apps, etc.
    The iPad Air's such a poor quality, un-durable product anyway. I only had my screen replaced in the first place because it cracked with no apparent drop or trauma and Apple wouldn't replace.
    daviddesignbristol - 返信
    I have also the same issue, does anyone know what the problem is?
    Please give us some feedback.
    Elektromic - 返信
    Have seen this with multiple repairs where the digitizer was replaced. In each case it was a problem with the digitizer cables where it gets tucked under the glass near the edge of the frame. Not yet sure if they are badly made digitizers or if the cable gets damaged trying to tuck it under frame during installation.
    RayM - 返信
    To avoid the digi sending the ipad crazy. In the same way you tape the copper/silver edges on the back of the glass for the iPad Mini. You tape all the way around, making sure not to dirty the protective cover when placing back down after taping one edge.
    Make sure all the metal surround is cover by tape, but careful not too go over the edges too much. It will be visible when using the device.
    Like i said earlier, the real skill is not too dirty the screen when lifting the protective sheet.
    Have fun!
    Josh - 返信
    Thanks man, I'll give it a try. Any idea what kind of tape should I buy?
    Luis Tamborrell -
    Kapton tape otherwise known as heat tape or polyamide tape
    Neil Davis -
    • スパッジャーの平面側先端を使ったり、指の先を使って、丁寧に2つのデジタイザーケーブルコネクターをソケットからまっすぐ引き上げます。
    • iPadを傷つけないように、コネクターのみ接触してください。ロジックボード上のソケットには触らないでください。
    コメントを追加する
    • 背面ケースに留められた接着剤からホームボタンのリボンケーブルをゆっくりと丁寧に剥がします。
    THIS PICTURE IS PERFECT AND PERTANANT TO THE NEXT STEP REGARDING “GHOST OR PHANTOM TOUCH” - See that foam around the edges? For some reason, the ifixit replacement digitizer doesn’t come with it (but it does come with new adhesive applied already.) With your screen, also purchase their “tesa tape” : Tesa 61395 Tape / 4 mm - it comes in different widths fyi. I choose 4mm as advised by a staff member.
    scottgogos - 返信
    • フロントパネルアセンブリを取り外します。
    • 組み立てている間に、きれいな画面を保つためにフロントパネルアセンブリの内側の埃や指紋をふき取ってください。
    • もしも画面をタッチしていないにも関わらず反応してしまう等の不具合が新しい画面で生じるようであれば、カプトン(ポリアミド)テープのような非常に薄い絶縁テープをパネルの裏のオレンジで囲まれた部分に貼ることで解決することが出来ます。iFixitのパネルは適切な絶縁が施された状態で出荷されているため、テープを追加で貼る必要はありません。
    • 適切な絶縁が行われていないと、デジタイザーのこれらの部分が他の部品に触れタッチ入力に不具合を生じる可能性があります。
    • 絶縁テープは裸眼では見ることはできず、多くのiPadで見られる粉塵防止用のものとは異なります。
    In your conclusion, which doesn't have a comments area, you say to reverse the procedure - simple enough, BUT what about the sticky adhesive residue along the edges of the (a) the just-remove-glass (if re-using) and (b) along the 'inside' edges of the iPad chassis? Typically Apple says to remove the adhesive residue (careful) with alcohol wipes (lint free & 98% isopropyl). Thanks for the instructions!
    Joe Kazura - 返信
    the hardest part of this repair for me is actually aligning the ribbons (especially on the aftermarket version) so they don't jumble and cause the glass to mush away from the adhesive leaving a gap. Would would be very helpful to see how to fold the ribbon cables back on the aftermarket digitizers. They are slightly different than the originals, or at least they appear different. This repair is super useful but we could really use a step 44 because re-assembly has a sequence and a folding technique.
    TJ Hellmuth - 返信
    The ribbon cable is a little tricky to figure out. But if you look closely at the old ( Broken) screen you will see they stick to the underside of the screen thin the remaining ribbon slides down into the ipad between the display and ipads frame.
    I used a heat gun and suction cups to loosen screen.
    This was a very good ifix ii
    Rowell - 返信
    Reassemble huh? What about how to move the home button to the new panel?
    xsubguy - 返信
    It is not as simple as reverse disassembly steps, the ribbon cables need to be tucked into the pocket on the side of the iPad. There is tape on them that has to adhere to the side of the digitizer too. Mine did not make it all the way down into the gap, and stuck on the other adhesive, now I have a gap by these two cables. To tuck these into this area is difficult at best. I now need to remove the glass, hoping it does not shatter and purchase more tape.
    Other than this the task was not bad.. BTW: YES People use the capton tape
    Randall Hooper - 返信
    I’ve read that people are putting glue at each corner. I haven’t figured out what glue. One person said Glue Dot 1” 16lb, another said rubber cement, 1 video shows 5 min epoxy… Heard that some sort of glue (not super glue) needs to be used to avoid the glass lifting later on. And to use 3m red tape along the edges. I’ve been searching for which glue because I still have an ipad air to do screen replacement on.
    tsolorio - 返信
    Would be helpful if the tape were listed in the master supplies for the guide. I got the whole kit overnighted, but then had to wait a week to get the tape from Amazon (since I wasn’t going to shell out another $50 for overnight shipping). Otherwise, it’d be nice to know if the displays through iFix it included the foam or not—mine didn’t.
    Micah Sledge - 返信
    Second the concern about the foam. I bought the full repair kit, but was surprised there wasn’t already polyimide tape on the digitizer or in the kit. At least mention that it needs to be purchased extra.
    Ronny Barlow - 返信
    @baron9 The displays we sell have the proper insulation and don’t require any tape. That note is more for folks who use our guides while buying the parts from somewhere else. (They tend to complain here, even though it’s the part that’s at fault, not the guide.) I’ve updated the instructions to try to make things a little more clear. Sorry about that!
    Jeff Suovanen -
    • iPadの端に近いアンテナケーブルの下にスパッジャーを滑り込ませ、アンテナケーブルコネクターの接続を外すため引き上げます。
    Skip to the step 98 or even 100 if you just need to replace the power button - I think you should even consider this to replace volume buttons. I am fixing mine right now and screwed up the speaker cable. I did follow the instruction but totally missed the cable right below the tape. I proceeded further, but I just realized I didn't have to go through all the troubles. I wish ifixit.com can manage this type of direction clearly so that dis-assembly is minimum.
    msgfromside3 - 返信
    After you replace the Digitizer if you are getting random key presses it is likely to be because Kapton tape has not been applied to the edges of the digitizer. You need to cover the silver strip around the edge of the digitizer with kapton tape before reassembling. Works every time.
    Richard - 返信
    This is my first ipad and when the battery dies, it will be my last, way overrated and no options like memory cards or mini usb ports, and the battery thing is ridiculous,I wish I would have never bought this knowing this stuff , and way over priced.
    Gary - 返信
    It always helps to Google something before buying it. "iPad Air reviews" in Google would have saved you. I just find it funny how in this day and age, people STILL make "purchase mistakes" because they didn't take the time to research the several-hundred-dollar device they are about to commit to purchasing. You should have seen the amounts of research I did before buying my $1,399 Asus G751JY laptop. I'm absolutely pleased with it and am happy I don't deal with issues other people have. Just be weary, buddy. ALWAYS GOOGLE.
    Scott S -
    If you just want to replace the battery, skip to step 99. You can easily get to most sides of the battery without removing all other components. It worked for me. Good luck!
    Thomas Van den Dries - 返信
    • 右側のアンテナケーブル周辺に背面ケースに付けられた2つの大きな覆われたテープがあります。
    • 背面ケースからこのテープを剥がします。
      • アンテナテープを剥がしたら、このテープを再組み立ての際に利用するため、これをそのまま残しておきます。
    コメントを追加する
    • アンテナケーブルは小さなメタル製ブラケットによってスピーカーに固定されています。ブラケットは永久にアンテナに圧接されており、内蔵スピーカーに接着剤で留められています。
    • 丁寧に開封ピックを内蔵スピーカーとアンテナケーブルのブラケットの間に差し込みます。
    • ピックをホームボタン側にスライドさせ、接着剤を切断します。
    • ブラケットの下に留められたテープが剥がれるまで、スピーカーからブラケットを離します。
    The pick was not thin enough but the razor worked.
    Moon & Snow - 返信
    • 次の#000プラスネジを右側のアンテナから取り出します。
      • 2.3 mmネジー1本
      • 1.4 mmネジー2本
    コメントを追加する
    • アンテナとスピーカーアセンブリの間にスパッジャーの平面側先端を差し込みます。
    • アンテナに付けられたフォーム製接着剤を切断するためにホームボタン側へスパッジャーをスライドさせます。
    コメントを追加する
    • iPadから右側のアンテナを取り出します。
    コメントを追加する
    • 左側アンテナケーブルの下にスパッジャーを差し込み。アンテナケーブルコネクターの接続を外すため、上向きに引き上げます。
    コメントを追加する
    • 右側スピーカーケーブルのコネクターを覆っている左側アンテナケーブル周辺に5箇所テープで覆われたパーツがあります。
    • アンテナケーブルを邪魔にならないように折り曲げて固定します。
    コメントを追加する
    • スピーカーケーブルの曲がり具合はテープを最後まで剥がす作業を難しくしています。
    • 代わりに、スピーカーのすぐ下のテープを取り、剥がしてケースの端から外します。
      • ピンセットでの作業中、テープのみを掴んで剥がすようご注意ください。ケーブルの下に接触しないでください。
    コメントを追加する
    • ホームボタンからテープを剥がして、スピーカーケーブルのコネクターをテープから出します。
    コメントを追加する
    • スパッジャーの先端を使って、右側スピーカーケーブルコネクターの固定フラップを引き上げます。
    • このZIFコネクターからスピーカーケーブルをまっすぐスライドさせます。
    コメントを追加する
    • 背面ケースにスピーカーを留めているテープを剥がします。
    コメントを追加する
    • 液晶ディスプレイのバッファテープを背面ケースから丁寧に剥がします。
    コメントを追加する
    • 背面ケースに留められたスピーカーより2.2 mm の#000プラスネジを取り外します。
    コメントを追加する
    • 指の爪やスパッジャーの平面側先端を使って、背面ケースの角付近にある内蔵スピーカーのくぼみに差し込みます。
    • スピーカーを下向きに引き、背面ケースの角から離します。
    It is really not necessary to remove either speakers for a logic board swap.
    sergeymkl - 返信
    • スパッジャーを使って、スピーカーを背面ケースの角の底から取り出します。
    • 右側のスピーカーをiPadから取り出します。
    コメントを追加する
    • 上部コンポーネントケーブルのブラケットに留められた1.4 mm #000プラスネジを3本取り外します。
    コメントを追加する
    • 上部コンポーネントケーブルのブラケットを取り出します。
    • iPad Air Wi-Fiモデル/セルラーモデルをお持ちの場合は、iPadはわずかに異なります。ヘッドホンジャックを取り出すためには、2本多くネジを取り外さなければなりません。
    コメントを追加する
    • 背面ケースに留められた左側アンテナケーブルが2本のテープによって覆われています。
    • 背面ケースからのこのテープを剥がします。
    コメントを追加する
    • 注意しながら開封ピックを内蔵スピーカーとアンテナケーブルブラケットの間に差し込みます。
    • ピックをホームボタンの間にスライドさせ、接着剤を切断します。
    • ブラケットの底のテープが綺麗に取れるまで、スピーカーをブラケットから押し出して離します。
    コメントを追加する
    • 次の#000 プラスネジを外します。
      • 1.4 mm ネジー2本
      • 2.3 mmネジー1本
    I didn’t need to take the left antenna and speaker out. If you just get the wire and tape out of the way so you can unplug the speaker flex cables and take out the lightning connector, then you should still be able to get the logic board out. the left speaker isn’t in the way at all.
    Reed Deemer - 返信
    • スパッジャーの平面側の先端をアンテナとスピーカーアセンブリの間に差し込みます。
    • スパッジャーをホームボタンの間にスライドさせて、アンテナに留められたフォーム製接着剤を切断します。
    コメントを追加する
    • iPadから左側アンテナを取り出します。
    コメントを追加する
    • 左側のスピーカーケーブルコネクターを覆っているテープを取り出します。
    コメントを追加する
    • スパッジャーの先端を使って、左側のスピーカーケーブルコネクター上の固定フラップを押し出します。
    コメントを追加する
    • ZIFコネクターからスピーカーケーブルをまっすぐにスライドさせます。
    コメントを追加する
    • 背面ケースに留められたスピーカーよりテープを剥がします。
    コメントを追加する
    • 背面ケースにスピーカーを留めている 2.2 mmの #000プラスネジを取り出します。
    コメントを追加する
    • 左側のリボンケーブルを丁寧に押し上げます。すると内蔵スピーカーがスライドして動くため、バッテリーが見えてきます。
    コメントを追加する
    • 背面ケースのコーナー付近のスピーカーのくぼみにスパッジャーの平面側先端や指の爪を差し込みます。
    • スピーカーを下向きに引き、ケースの角から離します。
    コメントを追加する
    • スパッジャーを使って、背面ケースの端の底からスピーカーを引き出します。
    • iPadから左側のスピーカーを取り出します。
    コメントを追加する
    • スパッジャーの平面側先端を使って、正面カメラのコネクターをロジックボードから接続を外します。
      • コネクターのみ接触してください。ソケットには触らないでください。
    • 正面カメラケーブルが邪魔にならない位置に折り曲げておきます。
    コメントを追加する
    • スパッジャーの平面側先端を使って、ロジックボードから背面カメラのコネクターの接続を外します。
      • コネクターのみに接触してください。ソケット自体には触らないでください。
    • 背面カメラケーブルを邪魔にならない位置に折り曲げます。
    コメントを追加する
    • スパッジャーの平面側先端を使って、ヘッドフォンジャックのコネクターをロジックボードから外します。
      • コネクターのみ接触してください。ソケット自体には触らないでください。
    • ヘッドフォンジャックケーブルを邪魔にならない位置で折り曲げます。
    コメントを追加する
    • スパッジャーの平面側の先端を使って、マイクケーブルのコネクターをロジックボードから外します。
    コメントを追加する
    • 上部ボタンのアセンブリーケーブルコネクターを覆っているテープを外します。
    コメントを追加する
    • スパッジャーの先端を使って上部ボタンアセンブリーケーブルコネクターの固定フラップをひっくり返します。
    コメントを追加する
    • 上部ボタンアセンブリケーブルをまっすぐ ZIFコネクターからスライドして外します。
    コメントを追加する
    • Lightningポートに留められた3.3 mm #000プラスネジを2本外します。
    NOTE for others who might miss this: this picture is looking down, out the bottom of the iPad. There are four other screws near the lightning port, two for the speakers and two for the port. You see these four easily, looking down at the battery and motherboard. These two are additional to those, and perpendicular to them. Both pairs of lightning port screws, one set perpendicular to the other, must be removed.
    Bonnie Baxter - 返信
    • 次の手順ではiPadの背面ケースのロジックボードに留められた接着剤を柔らかくするためiOpenerを使って熱を当てます。
    • iOpenerを何度も温めて指定されたそれぞれの場所に少なくとも1分以上配置し、接着剤を柔らかくします。
    • 接着剤は黒色のフォーム製テープで6箇所あります。この手順を参照しながら、各部分に熱を当てて、こじ開けていきます。
    コメントを追加する
    • 温めたiOpenerをiPadの背面カメラ端の上に置きます。少なくとも1分そのままにして、背面ケースに留められた接着剤を柔らかくします。
      • 1分間以上あてても特に問題ありませんが、背面ケース上に長い時間置く場合はiOpenerを再度温める必要があります。
    コメントを追加する
    • これから出てくる幾つかの手順を完成させるには、常に接着剤が柔らかくなっているか確認をしてからロジックボードに留められた接着剤をこじ開ける作業を始めてください。柔らかくなっていない場合は、iOpener を再度温めて、背面ケースの裏側にあててください。
    • 正面カメラとバッテリーの間のロジックボードの底に開封ピック(ギターピック)をゆっくりと差し込みます。
    • ピックを正面カメラコネクター側にスライドさせます。そして、ロジックボードのベンドの箇所で止めます。
    コメントを追加する
    • 開封ピックをロジックボードの底に差し込み、正面カメラから背面カメラまでスライドさせます。
    コメントを追加する
    • iPadの底側の端に温めたiOpenerを載せます。
      • 繰り返し、背面ケースにに留められた接着剤を柔らかくするため、iOpenerを少なくとも1分置いてください。
    コメントを追加する
    • Lightningコネクターケーブルは背面ケースに接着剤によって留められています。この接着剤を剥がすには、ケーブルとケースの間に開封ピックをスライドさせます。Lightningコネクターケーブル自体を切断しないようにご注意ください。
    • ロジックボードと重なるLightningケーブル部分の下に開封ピックを差し込みます。
    • ケーブルのベンド周辺とその下部をピックでスライドさせます。
    コメントを追加する
    • 引き続き、ケーブルの底に開封ピックをスライドさせ、ケーブルがLightningコネクターのカーブに差し掛かる手前で止めます。
    • ゆっくりと丁寧に動かします。もし、開封ピックが簡単に動かない場合は、接着剤を再度温めてから再試行してください。過度な力でスライドしてしまうと、手が滑ってしまいLightningコネクターケーブルに傷をつけてしまうことがあります。
    コメントを追加する
    • ついに、ケーブルの底に留められた最後の接着剤を剥がすため、Lightningコネクター本体とバッテリーの間に開封ピックを差し込みスライドさせます。
    There are two screws holding the lightning connector to the rear case, I didn’t see them in this guide. I recommend removing them before you attempt to remove the lightning connector, otherwise you’ll look like an idiot struggling with it for around 1/2 an hour like I just did.
    Will Young - 返信
    • Lightningコネクターを背面ケースの奥からまっすぐと引き上げます。
    there were two screws holding the lightening connector in place on my iPad
    Nate Czupinski - 返信
    Yep! In this guide those screws are removed in Step 82, but you can remove them at any point prior to taking out the Lightning connector.
    Jeff Suovanen -
    • 背面ケースの左側、ロジックボードがある位置に温めたiOpenerを載せます。
      • 背面ケース左側全体の接着剤が柔らかくなるまで少なくとも1分間、iOpenerを置いてください。
    コメントを追加する
    • プラスチック製開封ツールをロジックボード上部の長方形をした隙間に差し込みます。背面ケースからロジックボードを上方にこじ開けます。
    • 開封ツールをロジックボードの底に差し込んだまま、ロジックボードの上部端を接着剤から取り除くため隙間の始まる先端から終わりまでスライドします。
    コメントを追加する
    • EMIシールド付近の長方形をした隙間の下部端からロジックボードをこじ開けます。
    • ロジックボードの端を丁寧に持ち上げます。作業の途中でかなりの抵抗力を感じたら、こじ開ける作業を中止してiOpenerを再度配置してください。
    コメントを追加する
    • ロジックボードとバッテリーの間のロジックボード側の底に開封ピックを差し込みます。
    • 接着剤を切断するためにロジックボードの中心部分から開封ピックをスライドさせます。
    • バッテリーを開封ピックで切断しないようにご注意ください。傷が入ってしまったバッテリーは大変危険です。作業中、抵抗力を感じたらiOpenerを再度温めて、裏返したこの部分に置いてください。
    コメントを追加する
    • ロジックボードの先端から先までピックをスライドさせます。
    • 接着剤が切断できたら、ピックを使ってロジックボードのバッテリー側を背面ケースに対して上向きにこじ開けます。
    コメントを追加する
    • 続けてロジックボードをバッテリー付近の端に沿って押し上げます。開封ピックがロジックボードの反対側の端まで到達したら作業を止めます。
    • ロジックボードの外側の端を背面ケースに留めている接着剤を切り離します。
    コメントを追加する
    • iPadからロジックボードを取り出します。
    Nice guide, thank you, very helpful. There would be no way to guess where the glue stripes are located and a couple of connectors are very difficult to spot. I don't see any need to remove the antennas and the speakers though, they are not really an obstacle to remove the board and can be left in place. The lightning connector is secured in place by two other two horizontal screws which are not shown in the guide.
    Thanks again !
    arbaman - 返信
    This is a bear of a job, and I wouldn’t have had any hope of completing it without this guide. THANK YOU for all your hard work!!!!
    Bonnie Baxter - 返信
まとめ
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
30 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
95%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 貢献してみませんか?
翻訳を始める ›
Sam Lionheart
メンバー登録日: 2012年10月18日
341,678 ポイント
535のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
114 メンバー
7,032のガイドは作成済み
I have Problem to disconect the accu from mainboard.
Have you got i idea for me?
Thank you very much for answer
christian - 返信
コメントを追加する
統計データを表示:
過去 24時間: 25
過去 7 日: 131
過去 30 日: 568
今までの合計 37,273
