メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iOpener (Legacy) Instructions
必要な工具と部品
  1. iOpener (Legacy) Instructions, iOpener (Legacy) Instructions: 手順 1、 3の画像 1 iOpener (Legacy) Instructions, iOpener (Legacy) Instructions: 手順 1、 3の画像 2 iOpener (Legacy) Instructions, iOpener (Legacy) Instructions: 手順 1、 3の画像 3
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
    FixBotに聞いてみる
    コメントを追加
  2. iOpener (Legacy) Instructions: 手順 2、 1の画像 1
    • Heat the iOpener for one minute.
    • If you are using a new, liquid-filled iOpener, only microwave your iOpener for 30 seconds, and be sure to follow the appropriate guide.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional minute at a time.
    • Be careful not to overheat the iOpener during the repair. Always wait at least two minutes before reheating the iOpener.
    FixBotに聞いてみる
    コメントを追加
  3. iOpener (Legacy) Instructions: 手順 3、 1の画像 1
    • Remove the iOpener from the microwave, holding it by the printed tag.
    • If your iOpener has no tag, grab it by a corner, or handle with an oven mitt to avoid burning yourself.
    • The bag will be very hot, so be careful when handling it. Use an oven mitt if necessary.
    FixBotに聞いてみる
    コメントを追加
  4. iOpener (Legacy) Instructions: 手順 4、 1の画像 1
    • Lay the iOpener flat on the edge of the device, over an adhesive seal you wish to heat. Smooth the iOpener along the surface to ensure good contact with the device.
    • Let the bag sit on the device for approximately 90 seconds before attempting to open the front panel.
    • At this point you should be able to begin prying under the screen with a plastic opening tool. Be sure to see your device's specific guide for where and how to do this.
    • Throughout the procedure you may need to reheat the iOpener. To prevent overheating the iOpener, always wait at least two minutes before microwaving again. Do not microwave the iOpener for more than one minute at a time.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
26 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Andrew Optimus Goldheart
メンバー登録日: 10/17/09
515,338 ポイント
407のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
28,236のガイドは作成済み
2件のガイドコメント
It's now a couple of years since I got my iOpener but I never got to use it. I've had to destroy it.
It is essentially a wheat bag (although the seeds in it are not wheat) that has brought some sort of insect into my home, probably from China where it was made.
I was going to report it to Australian Quarantine when I found it has been replaced by the mark 2 that does not involve importing undeclared biological matter.
Jeff Armstrong - 返信 共有
this opener is dangerous. After taking it our of the micro wave the outer skin was burst. I got first degree burns. This item should not be used without protection! Chinese $@$*!
Dimitrios Mitrentsis - 返信 共有
コメントを追加
統計データ:
過去 24時間: 11
過去 7 日: 55
過去 30 日: 283
今までの合計 28,697
