はじめに
If your iMac was configured with a solid state drive or Fusion Drive it includes a blade SSD on the back of the logic board. Use this guide to access and remove the SSD.
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply.
必要な工具と部品
この手順で使用する道具:iMac Intel 27" Cardboard Service Wedge$4.99
With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs can be completed with the iMac laying down, but are faster and easier with an iMac service wedge.
If you are using the iFixit cardboard service wedge, follow these assembly directions to put it together.
この手順で使用する道具:Plastic Cards$2.99
Set the iMac face-up on a table.
Starting from the top right corner of the iMac, insert a plastic card between the display and frame.
With the cards inserted as shown near the corners, gently twist the cards to increase the gap between display and case.
If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the adhesive in the problem area.
Begin to lift the top of the display up from the frame.
If there is a wire or cable underneath adhesive tape, always pull the tape off first.
If the cable is glued to the chassis, use a heated iOpener or a hair dryer to soften the adhesive first. You can then slide an opening pick underneath the cable to loosen it. Never pull directly on the delicate connectors.
Slide an opening pick underneath the foam cushion pieces to separate them from the display, and gently pull them off. You may need some double sided tape to re-attach them to the new display.
Use a Phillips screwdriver to remove the nine 3.2 mm screws securing the support bracket.
You may need to peel up the display adhesive lining the bottom edge of the iMac enclosure to access the screws.
Use the tip of a spudger to disconnect the fan cable's connector from its socket on the logic board.
Use the flat end of a spudger to disconnect each of the four antenna connectors from the AirPort/Bluetooth card.
Leftmost
Top
Upper right
Lower right
Pull up on the SATA power cable connector to disconnect it.
Unplug the SATA data cable connector by depressing its locking tab and pulling straight up on the connector.
Remove the SATA cable from the logic board assembly to get it out of the way and prevent it from being damaged.
To reassemble your device, follow these instructions in reverse and use our Adhesive Strips Guide to reattach the display glass.
63 の人々がこのガイドを完成させました。
15 件のコメント
Guys, After I replaced the HDD with a SATA SSD in my about my mac on storage it doesn't say Flash Storage but Solid State Drive. Can I change that writing into Flash Storage. I will have problems reselling it, people may think it was defective and repaired. If anyone knows how to do that please let me know. Thanks
Theres no way to change this, its because flash storage and Solid state drive are similar but not identical tech, just be honest when you resell and say you replaced the drive.
I'm having trouble finding out what kind of SSD the 2013 27" iMac uses, as well as where to buy one. Trying to add one to an iMac that was configured without one when shipped. I read that this model still has the port available, and I'd like to make a fusion drive. Can anyone give me a good source for buying one?
Hi Andrew. Did you do it? Can add the ssd disk?
thanks!
I'm trying to do the same thing Andrew! I have a late 2012 model that has a 1.2TB Fusion Drive,, which is the original 1TB drive with a 200GB Crucial solid state drive, and it's AMAZING! I want to do the same thing to my late 2013 27" iMac, but I heard it doesn't have the same port available as in the late 2012. Does anyone know this for sure?
benjibliss - 返信
