メインコンテンツにスキップ
iMac Intel 21.5インチ EMC 2805ハードドライブの交換
必要な工具と部品
  1. iMac Intel 21.5インチ EMC 2805ハードドライブの交換, ディスプレイアセンブリ: 手順 1、 1の画像 1
    この手順で使用する道具:
    iMac Intel 21.5" Cardboard Service Wedge
    購入する
    • ヒンジを外すと、iMacはバランスが取れなくなり、作業が難しくなります。iMac Service Wedgeがあれば修理作業は素早く、簡単ですが、なくても対応できます。
    • iFixitの梱包用ボックスを使ってウェッジ用サポートを作ることができます。こちらから組み立てガイドを参照してください。
    • iMacの作業を始める前に、コンピューターの電源を外して電源のキャパシタを放電するため約10秒間電源を押し続けてください。
    • キャパシタの鉛や、電源の裏側にある露出した半田付け接合部分に接触しないよう、特にご注意ください。基盤の端のみを持ってください。
    The wedge is an extremely tight fit for this model. I was worried that the amount of force needed to use it as shown might damage the stand, so I used it with the long side down instead. It worked fine that way and didn’t need anywhere near as much force to insert.
    roberttrevellyan - 返信
    Here’s a good YouTube vid on upgrading the RAM: Can a Normal Person Upgrade the RAM in the 2017 21.5" iMac?
    Dan - 返信
    Here are a couple tips from me:
    1) Expose the adhesive to extreme temperatures. I did this by transporting my iMac in my car, screen-down on a piece of cardboard on a cold February morning (in Chicago). When I went to pick up the iMac, the screen practically fell off the chassis. I would have been distraught by this if I hadn’t already planned this replacement. So it was a happy accident.
    2) Remember to expell the residual power from the power supply by pushing the power button while the iMac is unplugged. This does NOT guarantee it’s safe to touch, but when I accidentally brushed the solder and exposed capacitors, I didn’t get shocked.
    jerrid_foiles - 返信
    Instead of using the wedge, I placed the iMac faced up with the top side (web cam) facing me while I ran the pizza roller around. It worked out great!
    Sam Fung - 返信
    “All iMacs also come with a traditional hard drive” mine doesn’t!! it’s HDD bay is completely empty, no SATA cable or anything. I guess I’ll have to upgrade the PCIe SSD instead.
    Chris Hughes - 返信
    There is no replacement glass for this model, it is part of the LCD and impossible to remove or replace- the entire LCD has to be replaced unfortunately if the glass is cracked or damaged. You will have to Google search for a replacement. Also be careful with some of the lock tight tork screws as I broke one of my screw mounts taking one out.
    Phil Tesone - 返信
    I used this service wedge but also found it a very tight fit. The same stabilization can be achieved by using a big rolled up towel.
    Ernst - 返信
    While this is a good instruction guide, I recommend to also look at OWC’s instruction video about drive installation, before starting the exercise. Those install videos are very detailed and useful.
    Ernst - 返信
    Main advice: TAKE YOUR TIME with the pizza roller.
    Make several passes, until you really feel like there's no more sticker in the way. Stay away from the camera though (approx. 1inch / 2.5cm on both sides). This will reduce the work left with the plastic card. Adhesive is really on the edge of the screen so there is absolutely no need to go any further than the recommended 1cm / 3/8inch depth.
    Where are the sensitive parts?
    Facing your iMac, imagine you're looking at a watch. There are antennas on 1, 2 and 4 o'clock. Do not insert any metal piece there (nor anywhere else, btw). Other than that AND the screen cables underneath the camera, not much danger.
    Froggy Manny - 返信
  2. iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 2、 2の画像 1 iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 2、 2の画像 2
    • ディスプレイの左側の電源付近から、iMac開口ツールをガラスパネルと背面エンクロージャーの間に差し込みます。
    • iMac開口ツール上の回転軸を押し込んでもディスプレイの奥深くまで届きません。もし異なるツールを使用する場合、ディスプレイから9.5mm以上は差し込まないでください。それ以上深く差し込むと、アンテナケーブルに深刻なダメージを与えてしまいます。
    Don’t get too worried about starting exactly where the picture says. The glue is stronger in some parts so just start wherever is easier and then work slowly and patiently around in the direction shown.
    Richard Cook - 返信
    As this guide doesn’t cover replacing the adhesive strips, I found referring to the following was useful (noting that it’s not for the same model of iMac, so the modification they mention wasn’t necessary): iMac Intel 21.5インチ EMC 2544の接着ストリップの交換
    Alan Digby - 返信
    It is very easy to crack the glass in front of the LCD during this step. I used the guitar pick, maybe it was too thick… crack is just on the frame but anyway it is disappointing :(
    Nikolay - 返信
    This part of the exercise should be done with extreme patience. I took my sweet time with the opening tool, rolling it through the entire panel and enclosure gap over and over again, until I was very sure no parts were sticking together anymore. And when I thought I was I done, I decided to do it over again.
    Ernst - 返信
    You can "warm up" the adhesive before try to cut it with the tool using a hair dryer. Heat the edges for about a minute, keep moving it so you don't cause stress in the glass. Also the above note.. use the tool and then the cards. Do not use a guitar pick or other objects as the thickness will cause you to break the front glass, which is a bonded part of the display (expensive).
    Carl Schultz - 返信
    Merci pour ce conseil
    bry nicolas -
  3. iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 3、 3の画像 1 iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 3、 3の画像 2 iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 3、 3の画像 3
    • ピザカッターのようにツールを使いますー隙間に沿ってスライスしながら、フォーム製接着剤を切り込んでください。
    • カット用の車輪の裏の持ち手をしっかり持って内側に押し込んでください。もし外向きに引っ張ると車輪がハンドルから外れてしまいます。
    • ツールをディスプレイの左側に沿って下側から上部に向けてスライスします。
    Erreur de traduction: "de bas en haut" et non de" haut en bas" sur le côté gauche de l'écran
    Moreau - 返信
    If re-opening a screen that was opened and re-attached using iFixit’s adhesive strips, I would strongly recommend heating it first with an iOpener, heat gun or hair dryer. 20 minutes after attaching with the iFixit adhesive I tried to open it again with the pizza slicer to fix something and cracked the screen on the left-hand side.
    plasticpool - 返信
  4. iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 4、 3の画像 1 iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 4、 3の画像 2 iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 4、 3の画像 3
    • 左側コーナー上部周辺までスライスします。
    Ne pincez pas l’écran avec l’autre main. Vous exercez une pression inutile sur le verre et empêchez la roulette de couper le joint.
    phfoglia - 返信
  5. iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 5、 2の画像 1 iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 5、 2の画像 2
    • ディスプレイ上部左側から接着剤を切開します。
  6. iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 6、 2の画像 1 iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 6、 2の画像 2
    • ディスプレイ上部に沿って開口ツールをスライスします。
    • すでに切開した箇所も、接着剤が完全に切断されているか確認するため、複数回に渡って前後にスライドしてください。
    In this step can I cut along the display without make any damage to the front camera?
    arisnordico - 返信
    Hi! Actually - there is no need to cut the tape around the camera area - there is no tape to cut at all! And so, the way go is easy - just pass 10 mm to the left and to the right from camera and start cutting!
    P.S. Just did the whole procedure to replace a RAM and to add SSD on PSIe an hour ago! Seems to be different reading the instructions... you know - 2/10 and so on. But it's really not that hard, trust me. I'll give it 5/10.
    P.P.S. By the way there is one trick to pass the difficult steps. Any action which requires pulling smth (motherboard, speaker, power supply unit) from the narrow crack (or should i say - slit?) at the bottom of your Imac is really not so easy.
    And the trick is to first remove a thin metal stripe with some kind of insulation on it which held by 5 small (very small!!) screws at the bottom of your Imac. After you done it - it's easy to pull everything! Pay attention to the fact that one of this 5 screws at the center are more shortly than others.
    dv1977 - 返信
    I did all steps like this manuell but now the Display wont work only some colered strips are to see! Whats happend??
    Can anybody help me ? Maybe the connector cable is broken?
    djfanta - 返信
    Check both connectors, probably one of them not seated well
    pzhivulin -
    You can add a SATA SSD if you already have a PCIe SSD Factory?
    kaserlik - 返信
    If you're changing cracked EMC 2638 display to new assembly, there's two more steps:
    Step 24: Use the tip of a spudger to flip up the metal retaining bracket on the display data cable.
    Carefully pull the display data cable from its socket on the display assembly.
    Step 25: Use the tip of a spudger to unplug bracket of the thermal sensor small cable near display data cable.
    Carefully remove scotch tape covering thermal sensor. Using iSesamo or flat tip of the spudger carefully peel the thermal sensor away.
    pzhivulin - 返信
    omg - forgot to switch the termal sensor from the old display...
    now fan runs like crazy...
    Andrei Balotescu -
    The key thing is to never put any force on the opening tool when working through the tape. Just roll it back and forth with ease.
    Ernst - 返信
  7. iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 7、 3の画像 1 iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 7、 3の画像 2 iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 7、 3の画像 3
    • ディスプレイ上部の右側コーナー周辺までツールをスライドしながら、接着剤を切開します。
  8. iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 8、 2の画像 1 iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 8、 2の画像 2
    • ディスプレイの右側に沿ってツールを上部から下側に向けてスライドします。
  9. iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 9、 2の画像 1 iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 9、 2の画像 2
    • ディスプレイ右側の下部まで開口ツールをスライドさせて、ここで作業を終えます。
    • ここでもう一度、ディスプレイ全体に沿って開口ツールをスライドさせ、接着剤をスライスできたか確認しましょう。
    Yes, do it many times to loosen the adhesive.
    Noah Ralston - 返信
    Would be good data to show the 3 areas (wifi antennas where the "tape" is larger and covers them. The rest of the "tape" is 1.4" and easy. Also after removing the display, be sure to remove the old "tape" from both the display and the rubber parts of the case. Use the spudger to start an end and it should pull off easily. Careful on the baackside of the display as you can scratch off the black paint/covering.
    Carl Schultz - 返信
  10. iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 10、 3の画像 1 iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 10、 3の画像 2 iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 10、 3の画像 3
    • 開口ツールがディスプレイ上の接着剤の大部分を切断できても、ディスプレイはわずかにケースに装着されたままです。残りの接着剤から完全に乖離するため、プラスチックカードを使用してください。
    • iMacのフロント側を上向きにしてテーブル上に置いてください。
    • iMac右側の上部から、ディスプレイとフレームの間にプラスチックカードを差し込みます。
    • 9.5mm以上はプラスチックカードを差し込まないでください。内部コンポーネントにダメージを与えてしまいます。
    this step is extremely important NOT to stick in the cards too far….. doing so, you risk a 600 euro replacement as I experienced………
    Edgar Broekema - 返信
    I drew a 3/8” line on my cards with a marker first.
    Max Romano - 返信
    I’m reading this on the EU store, please change all measurements to cm/mm.
    Morgana Devina - 返信
    @ifixit The next batch of cards you create should have a line printed on the card 3/8” in from the edges. Would make a nice reference.
    Richard Giratd - 返信
    Here’s where OWC provides glass removal suction cups, which is a better solution than plastic cards.
    The suction cups help to easily lift the glass panel, without risking the damaging of any internal wiring that the plastic cards could cause.
    Ernst - 返信
    Better to remove stand wedge at this point? Can’t see from pics
    derekrobinson - 返信
  11. iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 11、 2の画像 1 iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 11、 2の画像 2
    • ディスプレイとフレームの間に隙間を作るように、丁寧にプラスチックを外側に向けてひねります。
    • ディスプレイのガラスに圧力がかからないように注意しながら、ゆっくりと動かします。約6mm程度の隙間ができれば十分です。
    This part must be done very carefully or you can damage the flat cable from display, despite it was under a iron cover.
    Cassio Machado - 返信
  12. iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 12、 3の画像 1 iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 12、 3の画像 2 iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 12、 3の画像 3
    • 残りの接着剤を乖離させながら、iMacの上部右側コーナーからディスプレイ中央に向けてプラスチックカードをスライドします。
    • iSightカメラ手前で止めてください。これ以上進むとダメージを与えてしまいます。
    You don't need to do it like this, simply open the iMac bendidng the LCD completely and use the pizza cutter to remove the adhesive.
    Felix - 返信
    Using glass removal suction cups will avoid running this risk of damaging the camera (or any wiring).
    Ernst - 返信
  13. iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 13、 2の画像 1 iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 13、 2の画像 2
    • 接着剤が再装着するのを防ぐため、ディスプレイ上部右側コーナー付近にプラスチックカードを差し込んだままにします。
  14. iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 14、 3の画像 1 iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 14、 3の画像 2 iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 14、 3の画像 3
    • 2枚目のプラスチックカードをiMac上部左側付近のディスプレイとフレームの隙間に差し込みます。
  15. iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 15、 2の画像 1 iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 15、 2の画像 2
    • ゆっくりとカードを上向きにツイストして、ディスプレイとフレームの間の隙間を広げます。
    • 反対側も同様に、接着剤が乖離するようにゆっくりとツイストします。ディスプレイのガラスに余分な圧力がかからないようご注意ください。
  16. iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 16、 3の画像 1 iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 16、 3の画像 2 iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 16、 3の画像 3
    • プラスチックカードを中央に向けてゆっくりとスライドして、iSightカメラの手前で止めます。
  17. iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 17、 2の画像 1 iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 17、 2の画像 2
    • プラスチックカードを左側上部コーナーの裏側に差し込みます。
  18. iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 18、 3の画像 1 iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 18、 3の画像 2 iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 18、 3の画像 3
    • コーナー付近に差し込んだ2枚のプラスチックカードを手に取り、ディスプレイとケースの間の隙間を広げるようにカードを外側に向けてツイストします。
    • もし接着剤が剥がれていない箇所がある場合はツイスト作業を止めて、どちらかのカードを使って接着剤を切断します。
    • フレームからディスプレイ上部を持ち上げます。
    • 約5cm程度以上は、ディスプレイを持ち上げないでください。ディスプレイデータケーブルやパワーケーブルが基板に接続されたままの状態です。
  19. iMac Intel 21.5インチ EMC 2805ハードドライブの交換, ディスプレイアセンブリケーブル: 手順 19、 3の画像 1 iMac Intel 21.5インチ EMC 2805ハードドライブの交換, ディスプレイアセンブリケーブル: 手順 19、 3の画像 2 iMac Intel 21.5インチ EMC 2805ハードドライブの交換, ディスプレイアセンブリケーブル: 手順 19、 3の画像 3
    • ピンセットを使ってディスプレイデータケーブル上のメタル製固定ブラケットを掴んで持ち上げます。
    • 丁寧に基板上のソケットからディスプレイデータケーブルを引っ張ります。
    • ソケットからまっすぐディスプレイデータケーブルのコネクタを引っ張ります。
    Does anyone know where to find a replacement display cable for the 2014?
    PN: 923-00047
    PBMedic is out of stock
    Brian Hernandez - 返信
  20. iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 20、 2の画像 1 iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 20、 2の画像 2
    • 片手でディスプレイを掴みながら、もう一方の手でディスプレイのパワーケーブルの接続を外します。
    • コネクタに簡単にアクセスできるようディスプレイを持ち上げますが、ケーブルを伸ばしすぎて接続部分にストレスを与えないようご注意ください。(約20cm程度)
  21. iMac Intel 21.5インチ EMC 2805ハードドライブの交換, ディスプレイ: 手順 21、 2の画像 1 iMac Intel 21.5インチ EMC 2805ハードドライブの交換, ディスプレイ: 手順 21、 2の画像 2
    • ディスプレイを左右均等に持ち上げます。
    • この時点でディスプレイ底に沿って接着ストリップがまだ付いています。これがヒンジのようにフレームとディスプレイを固定しています。ディスプレイを上下に数回揺らすと、この接着ストリップを緩めることができます。
  22. iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 22、 3の画像 1 iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 22、 3の画像 2 iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 22、 3の画像 3
    • 必要に応じて、プラスチックカードを使って接着ストリップの残りの部分を切断してください。
    • 下端ディスプレイの接着ストリップ片側の端にある小さなタブをつかみ、接着剤をiMacの上部に引き寄せて剥がします。
    • この手順をもう一方の接着ストリップにも同じ作業を繰り返して、取り除きます。
    • もし、どちらかの接着ストリップを外す前に切断してしまった場合は、プラスチックカードで残りの接着剤を除去してください。
    Anyone else notice this iMac is different than the one in Step 20. The cables are in different places. I just saw one on YT like this, in a different country.
    Thomas Tommy - 返信
  23. iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 23、 3の画像 1 iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 23、 3の画像 2 iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 23、 3の画像 3
    • ディスプレイをフレームから持ち上げて、iMacから外します。
    • 片側をゆっくりと持ち上げて、接着剤を剥がしながら外してください。
    • ディスプレイの取り扱いには特にご注意ください。ーディスプレイは大型で重量があり、ガラス製です。
    • ディスプレイを交換用ディスプレイに交換する場合、古いものから新しいパーツへコンポーネントを移植する必要があります。
    • 再組み立ての際は、新しい接着剤をインストールするためにディスプレイ用の接着剤ガイドを参照してください。
  24. iMac Intel 21.5インチ EMC 2805ハードドライブの交換, ハードドライブブラケット: 手順 24、 1の画像 1
    • リア筐体にハードドライブブラケットを固定している次のネジを外します。
    • 左側ハードドライブブラケットから21 mm T10トルクスネジー2本
    • 9 mm T10トルクスネジー1本
    • 27 mm T10 トルクスネジー1本
    Pay attention to this photo and where the fan is. It is 180° from where the previous step shows it is oriented to you.
    Max Romano - 返信
  25. iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 25、 2の画像 1 iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 25、 2の画像 2
    • iMacから左右のハードドライブブラケットを外します。
  26. iMac Intel 21.5インチ EMC 2805ハードドライブの交換, ハードドライブアセンブリ: 手順 26、 3の画像 1 iMac Intel 21.5インチ EMC 2805ハードドライブの交換, ハードドライブアセンブリ: 手順 26、 3の画像 2 iMac Intel 21.5インチ EMC 2805ハードドライブの交換, ハードドライブアセンブリ: 手順 26、 3の画像 3
    • ロジックボードに最も近い端からハードドライブを持ち上げ、わずかに引き出します。
    • ハードドライブはSATA電源/データケーブル1本で接続されています。iMacから完全に取り外さないでください。
    During the reassembly process I found it very difficult to plug the power/data cable on to the new hard drive. On my machine it’s very short and the fact that the cable comes into the plug from below at 90 degrees means it’s hard to keep straight on to the drive. I found this process could be made much easier by undoing 2 x T10 screws and CAREFULLY (there are cables attached) moving the adjacent speaker assembly a little away from the drive, reattaching once done. Hope this helps
    Jerry Frost - 返信
    Moving the speaker helped tremendously! Thanks
    lucas -
  27. iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 27、 3の画像 1 iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 27、 3の画像 2 iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 27、 3の画像 3
    • スパッジャーを使い、SATA電源、データコンボケーブルの接続を外します。
  28. iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 28、 1の画像 1
    • iMacからハードドライブを取り出します。
    I found that there is one more torx screw underneath the hdd when you take it out. If you remove this it seems to be easier to reattach the SATA cable to the new drive.
    jeffjeffmurray - 返信
  29. iMac Intel 21.5インチ EMC 2805ハードドライブの交換, ハードドライブ: 手順 29、 2の画像 1 iMac Intel 21.5インチ EMC 2805ハードドライブの交換, ハードドライブ: 手順 29、 2の画像 2
    • ハードドライブの上部左側からハードドライブのスリーブを剥がします。
  30. iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 30、 2の画像 1 iMac Intel 21.5インチ EMC 2805ハードドライブの交換: 手順 30、 2の画像 2
    • 続けてハードドライブに留められた接着剤をハードドライブのスリーブから剥がします。
    • ハードドライブからスリーブを取り出します。
    • ハードドライブのみが残ります。
    Followed the instructions in this guide using the included tool that I got with the strips. Everything worked great. Put in a brand new Samsung 850 Evo 250GB Drive. The guide makes it sound a little bit more complicated but everything went pretty smooth. Just took it slow and easy.
    Michael Conrad - 返信
    About torx is this good or what should I buy? https://www.amazon.it/gp/product/B00CIIM...=oh_aui_search_detailpage?ie=UTF8&psc=1
    Matteo Raggi - 返信
    If replacing with an SSD, do you just use a mount? (I’ve don't this replacement in 27” models and the hard drive doesn’t have a silicone casing so I’m wondering how to get around this)
    Arispa Weigold - 返信
    Great guide. I wanted to upgrade my late 2012 as much as I could to accommodate my large iTunes library. So with a little bit of cutting on the rubber hard drive cushion, I put a 15mm 5 TB hard drive and replaced the 120GB blade SSD with OWC’s 1 TB blade SSD. Now have 5.95 TB of fast usable space with my fusion drive.
    tednmandy - 返信
    No temperature sensor issues on this? I know the 27” needs a temperature sensor adapter.
    Chris Harding - 返信
    I couldn’t get the SATA cable connected again with the rubber sleeve on. Luckily my iMac had it in two separate pieces to stick to the long sides only, so I plugged it in first and carefully attached the bumpers after.
    Max Romano - 返信
    What’s the trick to connect the SATA cable to the disk?? There’s very little play in the connector. Am unable to position it properly to get a connection. Maybe my fingers are too large.
    Also, the photos are a bit misleading with regard to disconnecting the data display cable - show tweezers pulling on the distal end of the cable, which, is very fragile. Pictures should be improved and better description of that step added.
    George Guess - 返信
    Success! For those contemplating this, it takes some persistence and a perfect diagonal positioning of the SATA cable connector to attach the hard drive. Geez - Apple always seems to make things so easy for us average joes and janes.
    George Guess - 返信
    I was very impressed with the instructions above, took my time and was patient all through. I had to spend some time in the installation of the OS, care is required and attention to restoring a good backup is necessary. I had great success and would recommend undertaking this task. Many thanks IFIXIT.
    Liam Foster - 返信
    Successfully replaced harddrive when original crashed in Big Sur upgrade. Excellent instructions.
    Heikki Hanhimaki - 返信
    Is the hard drive you remove accessible once removed? Can you pull data off the drive once removed? Great job explaining the removal process.
    Paul - 返信
    Paul, you would have to get a external case inclosure to install the drive into. There are USB and SATA versions.
    B Jack - 返信
    Since I unplugged a SATA cord to remove, will I need a SATA case? Gonna connect to new 24” iMac (M1) and try and grab the pics and music.
    Paul -
    The IFIXIT kit I bought included a SATA case, which I used to pull the data off the old hard drive which was on its last legs. Thank you, IFIXIT!
    This was my first attempt at opening an iMac for anything but RAM upgrade (when it was possible easily on older iMacs). I too took it easy and slow. Replacing the hard drive was the easiest part of all this! The hardest part, which I'm still struggling with, was unplugging and replugging the display data and power cables. I was able to install an OS on the new SSD but in order to close the machine I had to unplug the display cables, and it seems that one of them did not seat properly, since the computer starts up but the display is black. Sigh. I will have to do the cutting and pasting of the glue strips all over again. Apple really doesn't want us doing these repairs.
    Amacl - 返信
終わりに
デバイスを再組み立てするには、これらのガイドを逆の順番に従って作業を進めてください。ディスプレイガラスを再装着するには、 接着ストリップの装着ガイドを参照してください。
71 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
翻訳を始める ›
作成者
5人の作成者と共同で作成されました。
Walter Galan
694,692 ポイント
1,203のガイドは作成済み
19 件のコメント
Is there a problem with the fan if I install SSD?
asrugo770 - 返信
Yes. There is a thermal sensor, which is going crazy after replacement.
And also have a problem with kernel_task after upgrade...
markeev -
is there a solution about the termal sensor and the kernel_task issue?
Roberto Bonilla - 返信
i have the same problem, CPU 700 %…
roro974 - 返信
I’ve run into the same thing: fans are running constantly with a new 1 TB 2.5” drive that I pulled from a 2012 iMac. I can use MacsFanControl as a 3rd party fix, but if anyone has a better (command line?) solution, I would be grateful!
Aaron Schine - 返信
SSD Fan Control is doing the job perfectly !
Jose Vilar -
Thank you for posting this. Awesome! I am an IT Admin at a school and have Techie Students that help with the smaller things. One of the iMacs went bad. I had him follow this guide and he was able to replace the hard drive successfully!! Thank you!
Patti Braun - 返信
What do you have to do with the temp sensor to make the fans behave normally after installing a SSD in an originally hard drive based iMac?
Andrew spoelstra - 返信
Install the SSD into the HD bay and download the SSD Fan Control application to avoid fan noise (easier, but less legitimate)
Install the SSD into the HD bay with the OWC thermal sensor (Extremely difficult, considerably more expensive, but works properly). Link for thermal sensor: https://eshop.macsales.com/item/OWC/DIDI.... Link for SSD Fan Control: http://exirion.net/ssdfanctrl/
pfrohwein - 返信
You should have installed the OWC inline thermal sensor.
MacFans is the only other solution.
rockpiano54 - 返信
This guide is for the Mid-2014 21.5” 2808 machine, which does not have any thermal sensor on the STANDARD 2.5’” HDD. I just completed mine, and it’s totally silent, no fan issues as I’m typing this. I suggest some of the peeps above are posting in the wrong guide, and may have 27” machines with 3.5” HDD with the thermal sensor issue. A great guide, well written and illustrated, excellent 10/10.
Phil Reed - 返信
Exactly. I just replaced my HD with an SSD and absolutely no fan noice.
Also a 21.5” imac a1418 emc 2805.
Pretty straight forward repair.
Christian Tørring -
I’ve just replaced the internal HDD by a Samsung 850 Pro SSD 256 GB. There is no need for any special cable, thermal sensor or additional software, the SSD runs fine. Model is a Mid 2014 iMac 21.5”, EMC 2805, 1.4 GHz i5, no Fusion Drive.
kriechel -
The issue with the fan is easily sorted with the software solution SSDfancontrol is free and works 99% of the time for me.
macfixer - 返信
Outstanding kit by iFixit for replacing the HHD.
Great guide, I followed it step by step and had no problem but one: when reinserting the cable into the new SSD, I had no room for my fingers. I had to loose the black plastic cover to the left in order to have a bit more room and succeeded.
Then, I added an extra check before sealing the screen, powering on the Mac just to be sure I reconnected correctly the screen cables.
Now the Mac is super fast!
Aran Banjo - 返信
Good guide, thank you very much :-)
Dariusz - 返信
Thanks for the manual and the parts/tools to do this repair. It took me a lot more time than listed though :-)
David Shelton - 返信
Pour faciliter le décollage, après avoir passé la roulette, j'insére tout autour des bandes de plastique dur de 2cm de large découpées sans un classeur en plastique. Ceci évite que ca recolle et l'écran se lève sans difficulté
Ordysouris - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 42
過去 30 日: 202
今までの合計 55,317
