メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iMac Intel 20" EMC 2266 Optical Drive Replacement
必要な工具と部品
  1. iMac Intel 20" EMC 2266 Optical Drive Replacement, Access Door: 手順 1、 1の画像 1
    • Lay your iMac front side down on a table with the lower edge facing yourself.
    • Loosen the single Phillips screw in the center of the access door.
    • This screw is captive in the access door.
    • Remove the access door from your iMac.
    FixBotに聞いてみる
    コメントを追加
  2. iMac Intel 20" EMC 2266 Optical Drive Replacement, Glass Panel: 手順 2、 2の画像 1 iMac Intel 20" EMC 2266 Optical Drive Replacement, Glass Panel: 手順 2、 2の画像 2
    この手順で使用する道具:
    Heavy-Duty Suction Cups (Pair)
    $16.95
    • The glass panel is fixed onto the front bezel with fourteen magnets around its perimeter.
    • Stick two suction cups to opposing corners of the glass panel.
    • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
    FixBotに聞いてみる
    コメントを追加
  3. iMac Intel 20" EMC 2266 Optical Drive Replacement: 手順 3、 1の画像 1
    • Gently pull the glass panel straight up off the iMac.
    • The glass panel has several positioning pins around its perimeter. To avoid shearing these pins off the glass panel, be sure to only pull straight up during removal.
    • Be meticulous about cleaning the LCD and the inside face of the glass panel before reinstallation, as any fingerprints or dust trapped inside will be annoyingly visible when the display is on.
    • When replacing the glass, be sure there's nothing between the glass and the frame. Stray cables could be damaged or crack the glass.
    FixBotに聞いてみる
    コメントを追加
  4. iMac Intel 20" EMC 2266 Optical Drive Replacement, Front Bezel: 手順 4、 1の画像 1
    • Remove the following 12 screws securing the front bezel to the rear case:
    • Eight 13 mm T8 Torx.
    • Four 25 mm T8 Torx.
    • On the 24" iMac Intel Model A1225, the bottom center two screws are long (26mm), four on sides (two left, two right) are medium (18mm), and the remaining 6 (four top, two bottom corners) are short (14mm).
    FixBotに聞いてみる
    コメントを追加
  5. iMac Intel 20" EMC 2266 Optical Drive Replacement: 手順 5、 2の画像 1 iMac Intel 20" EMC 2266 Optical Drive Replacement: 手順 5、 2の画像 2
    • The front bezel is still attached to the iMac by the microphone cable.
    • Gently lift the front bezel from its top edge off the rear case.
    • Once the top edge of the front bezel has cleared the rear case, rotate the front bezel toward the stand and lift it off the rear case.
    • Rotate the front bezel away from the rest of the device and lay it above the top edge of the iMac.
    • When reinstalling the front bezel, start at the lower edge and make sure it is flush with the rear case before lowering the top edge onto the iMac.
    FixBotに聞いてみる
    コメントを追加
  6. iMac Intel 20" EMC 2266 Optical Drive Replacement: 手順 6、 1の画像 1
    • Disconnect the microphone cable connector, removing tape as necessary.
    • For the front bezel to sit properly, be sure to tuck the microphone cable and connector into the void next to the camera board.
    FixBotに聞いてみる
    コメントを追加
  7. iMac Intel 20" EMC 2266 Optical Drive Replacement, Display Panel: 手順 7、 1の画像 1
    • Pull the LCD temperature sensor connector straight up off its socket on the logic board.
    • (located at the top of the logic board on the 24")
    FixBotに聞いてみる
    コメントを追加
  8. iMac Intel 20" EMC 2266 Optical Drive Replacement: 手順 8、 2の画像 1 iMac Intel 20" EMC 2266 Optical Drive Replacement: 手順 8、 2の画像 2
    • Remove the two T6 Torx screws securing the display data cable to the logic board.
    • Use the attached black tab to pull the display data cable connector straight away from the logic board.
    FixBotに聞いてみる
    コメントを追加
  9. iMac Intel 20" EMC 2266 Optical Drive Replacement: 手順 9、 2の画像 1 iMac Intel 20" EMC 2266 Optical Drive Replacement: 手順 9、 2の画像 2
    • Remove the eight T8 Torx screws securing the display panel to the rear case.
    • Lift the display panel from its left edge and rotate it toward the right edge of the iMac.
    FixBotに聞いてみる
    コメントを追加
  10. iMac Intel 20" EMC 2266 Optical Drive Replacement: 手順 10、 2の画像 1 iMac Intel 20" EMC 2266 Optical Drive Replacement: 手順 10、 2の画像 2
    • With the display panel still lifted, disconnect the four inverter cables.
    • During reinstallation, place the four inverter cable connectors in voids between components attached to the rear panel so the display panel will sit flush on the edges of the rear case.
    • (combined into one plug in on the 24")
    • Be sure to keep track of the cables, as they do not have proprietary sockets. Mismatched cables can cause screen issues.
    FixBotに聞いてみる
    コメントを追加
  11. iMac Intel 20" EMC 2266 Optical Drive Replacement, Optical Drive: 手順 11、 2の画像 1 iMac Intel 20" EMC 2266 Optical Drive Replacement, Optical Drive: 手順 11、 2の画像 2
    • Peel the strip of EMI tape off the edge of the rear case.
    FixBotに聞いてみる
    コメントを追加
  12. iMac Intel 20" EMC 2266 Optical Drive Replacement: 手順 12、 1の画像 1
    • Remove the two T10 Torx screws securing the optical drive to the rear case.
    FixBotに聞いてみる
    コメントを追加
  13. iMac Intel 20" EMC 2266 Optical Drive Replacement: 手順 13、 1の画像 1
    • If necessary, remove the piece of tape holding the thermal sensor wires to the hard drive.
    FixBotに聞いてみる
    コメントを追加
  14. iMac Intel 20" EMC 2266 Optical Drive Replacement: 手順 14、 1の画像 1
    • Pull the optical drive thermal sensor connector straight away from its socket on the logic board.
    • When removing this connector, it is helpful use your thumbnails to push the ears on either side of the connector toward the top of your iMac.
    FixBotに聞いてみる
    コメントを追加
  15. iMac Intel 20" EMC 2266 Optical Drive Replacement: 手順 15、 1の画像 1
    • Lift the left edge of the optical drive slightly and pull it away from the right side of the rear case.
    FixBotに聞いてみる
    コメントを追加
  16. iMac Intel 20" EMC 2266 Optical Drive Replacement: 手順 16、 1の画像 1
    • Insert a spudger between the optical drive connector and the optical drive.
    • Twist the spudger to slightly separate the optical drive connector from the optical drive, then use your fingers to pull the connector away from the drive.
    FixBotに聞いてみる
    コメントを追加
  17. iMac Intel 20" EMC 2266 Optical Drive Replacement, Optical Drive: 手順 17、 1の画像 1
    • Remove the piece of foam tape covering the optical drive thermal sensor.
    FixBotに聞いてみる
    コメントを追加
  18. iMac Intel 20" EMC 2266 Optical Drive Replacement: 手順 18、 1の画像 1
    • To remove the optical drive thermal sensor, use the tip of a spudger to lift the center finger of the thermal sensor bracket while applying slight tension to the thermal sensor cable.
    • If the thermal sensor is stuck to the optical drive, skip to the next step.
    FixBotに聞いてみる
    コメントを追加
  19. iMac Intel 20" EMC 2266 Optical Drive Replacement: 手順 19、 1の画像 1
    • Use the flat end of a spudger to pry the optical drive thermal sensor bracket up off the adhesive securing it to the optical drive.
    • If the adhesive gets dirty or will not stick to your new optical drive, place some double-sided tape under the two semicircular ears of the thermal sensor bracket.
    FixBotに聞いてみる
    コメントを追加
  20. iMac Intel 20" EMC 2266 Optical Drive Replacement: 手順 20、 1の画像 1
    • Use a spudger to remove the small piece of EMI foam from the bottom of the optical drive.
    • Don't forget to transfer this to your new drive.
    FixBotに聞いてみる
    コメントを追加
  21. iMac Intel 20" EMC 2266 Optical Drive Replacement: 手順 21、 1の画像 1
    • Peel the EMI tape off the optical drive.
    • Don't forget to transfer this to your new optical drive.
    FixBotに聞いてみる
    コメントを追加
  22. iMac Intel 20" EMC 2266 Optical Drive Replacement: 手順 22、 2の画像 1 iMac Intel 20" EMC 2266 Optical Drive Replacement: 手順 22、 2の画像 2
    • Remove the two T10 Torx screws from both sides of the optical drive (four screws total).
    FixBotに聞いてみる
    コメントを追加
  23. iMac Intel 20" EMC 2266 Optical Drive Replacement: 手順 23、 1の画像 1
    • Use the tip of a spudger to press each of the optical drive bracket tabs out of their slots on the bottom of the optical drive.
    FixBotに聞いてみる
    コメントを追加
  24. iMac Intel 20" EMC 2266 Optical Drive Replacement: 手順 24、 2の画像 1 iMac Intel 20" EMC 2266 Optical Drive Replacement: 手順 24、 2の画像 2
    • Rotate the optical drive bracket slightly away from the optical drive.
    • Pull the optical drive bracket away from the open end of the optical drive, minding any tabs that may get caught.
    • If you have a disk or anything else stuck inside your optical drive, we have a guide to fix it.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
12 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Walter Galan
710,363 ポイント
1,203のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 49
今までの合計 27,490
